Home » Eclipse Projects » EclipseLink » Howto map a map?
Howto map a map? [message #666821] Fri, 22 April 2011 16:07 Go to next message
Martin Taal is currently offline Martin Taal
I have a field/member which has this type;
public Map<String, Writer> getWriters() {
return writers;
the key of the map is not a property of the writer, so a join table is needed. How do I map this using an orm xml file?
I tried this:
<orm:one-to-many name="writers">
<orm:map-key-class class="java.lang.String"/>
<orm:join-table/>
<orm:cascade>
<orm:cascade-all/>
</orm:cascade>
</orm:one-to-many>
But then I get this:
The field [BOOK.WRITERS_KEY] in this expression has an invalid table in this context.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Howto map a map? [message #666853 is a reply to message #666821] Sat, 23 April 2011 07:01 Go to previous messageGo to next message
Hmm this seems to work fine:
<orm:map-key-column table="_1303556303411"/>
<orm:join-table name="_1303556303411"/>
<orm:cascade>
<orm:cascade-all/>
</orm:cascade>
</orm:one-to-many>
So I explicitly set the table of the map key column, if I don't set the tablename in the map-key-column/join-table then
EclipseLink throws an exception (the same as in the previous post). But I prefer EclipseLink to generate the table name,
is there a mapping I can use without specifying an explicit table name?
gr. Martin
On 04/22/2011 10:07 PM, Martin Taal wrote:
> return writers;
> I tried this:
> <orm:join-table/>
> <orm:cascade>
> <orm:cascade-all/>
> </orm:cascade>
> </orm:one-to-many>
The Netherlands
Re: Howto map a map? [message #667231 is a reply to message #666853] Wed, 27 April 2011 10:44 Go to previous message
James Sutherland is currently offline James Sutherland
The table should be defaulted if not specified, please log a bug.
As a workaround just set the table to what would be generated.
James : Wiki : Book : Blog
Previous Topic:OutOfMemory ScrollableCursor
Next Topic:Apparent interface violation in CriteriaBuilderImpl
Current Time: Tue May 21 20:15:45 EDT 2013
Powered by FUDForum. Page generated in 0.01850 seconds
