| Possible to generate a maven repository using Buckminster? [message #666907] |
Sun, 24 April 2011 03:12  |
Martin Taal Messages: 5049 Registered: July 2009 |
I use Buckminster for building Texo and Teneo and generate the p2site. I would also like to generate a maven repository
with some of the jar files (plugins), is this possible with Buckminster? I mean can I somehow (easily :-) generate a
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Possible to generate a maven repository using Buckminster? [message #667013 is a reply to message #666927] |
Mon, 25 April 2011 09:47  |
Thanks Henrik for your answer, seems easy enough :-), I am trying b3 and asked a question on the b3 forum about this.
gr. Martin
On 04/24/2011 07:55 PM, Henrik Lindberg wrote:
> It is possible to generate a maven repository using the b3 aggregator.
> Buckminster can be used to produce a p2 repository, and the b3 aggregator can aggregate p2 and maven repositories and
> produce a result that is in p2 "native" format or in a combined p2 and maven repository format.
> Don't know if that is easy enough...
> Regards
> - henrik
> On 4/24/11 9:12 AM, Martin Taal wrote:
>> would also like to generate a maven repository with some of the jar
>> (easily :-) generate a maven repository using Buckminster?
The Netherlands
FUDForum. Page generated in 0.02894 seconds
