Home » Eclipse Projects » Rich Client Platform (RCP) » Completely lost.... any ideas? (Unable to launch application - errors attached)(Sorry, this could be really easy!)
Completely lost.... any ideas? (Unable to launch application - errors attached) [message #665497] Thu, 14 April 2011 15:52 Go to next message
LHXS  is currently offline LHXS
Guys,
I am getting the following errors when I try to run the RCP application that I have. Any ideas? It's completely lost on me!
Many thanks
Matt
!SESSION 2011-04-14 20:49:59.140 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: -product org.myApp.gui.product
Command-line arguments: -product org.myApp.gui.product -data W:\workspaces/../runtime-org.myApp.gui.product -dev file:W:/workspaces/.metadata/.plugins/org.eclipse.pde.core/o rg.myApp.gui.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.osgi 4 0 2011-04-14 20:50:00.812
!MESSAGE Application error
!STACK 1
java.lang.ExceptionInInitializerError
at org.eclipse.osgi.framework.debug.FrameworkDebugOptions.setFi le(FrameworkDebugOptions.java:438)
at org.eclipse.core.internal.runtime.DataArea.createLocation(Da taArea.java:185)
at org.eclipse.core.internal.runtime.DataArea.initializeLocatio n(DataArea.java:147)
at org.eclipse.core.internal.runtime.DataArea.assertLocationIni tialized(DataArea.java:59)
at org.eclipse.core.internal.runtime.DataArea.getStateLocation( DataArea.java:125)
at org.eclipse.core.internal.preferences.InstancePreferences.ge tBaseLocation(InstancePreferences.java:44)
at org.eclipse.core.internal.preferences.InstancePreferences.in itializeChildren(InstancePreferences.java:199)
at org.eclipse.core.internal.preferences.InstancePreferences.<init >(InstancePreferences.java:59)
at org.eclipse.core.internal.preferences.InstancePreferences.in ternalCreate(InstancePreferences.java:209)
at org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:289)
at org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:277)
at org.eclipse.core.internal.preferences.PreferencesService.cre ateNode(PreferencesService.java:390)
at org.eclipse.core.internal.preferences.RootPreferences.getChi ld(RootPreferences.java:63)
at org.eclipse.core.internal.preferences.RootPreferences.getNod e(RootPreferences.java:96)
at org.eclipse.core.internal.preferences.RootPreferences.node(R ootPreferences.java:85)
at org.eclipse.core.internal.preferences.AbstractScope.getNode( AbstractScope.java:38)
at org.eclipse.core.runtime.preferences.InstanceScope.getNode(I nstanceScope.java:71)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getStorePre ferences(ScopedPreferenceStore.java:241)
at org.eclipse.ui.preferences.ScopedPreferenceStore.<init>(ScopedPreferenceStore.java:133)
at org.eclipse.ui.plugin.AbstractUIPlugin.getPreferenceStore(Ab stractUIPlugin.java:284)
at org.eclipse.ui.internal.UISynchronizer.<init>(UISynchronizer.java:88)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2456)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.myApp.Application.start(Application.java:20)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Caused by: java.lang.ArrayStoreException: declaredAnnotations/7371509
at sun.text.resources.FormatData.getContents(Unknown Source)
at java.util.ListResourceBundle.loadLookup(Unknown Source)
at java.util.ListResourceBundle.handleGetObject(Unknown Source)
at java.util.ResourceBundle.getObject(Unknown Source)
at java.text.DateFormatSymbols.initializeData(Unknown Source)
at java.text.DateFormatSymbols.<init>(Unknown Source)
at java.text.DateFormatSymbols.getInstance(Unknown Source)
at java.text.SimpleDateFormat.<init>(Unknown Source)
at org.eclipse.osgi.framework.debug.EclipseDebugTrace.<clinit>(EclipseDebugTrace.java:51)
... 41 more
An error has occurred. See the log file
W:\runtime-org.myApp.gui.product\.metadata\.log.
[Updated on: Thu, 14 April 2011 16:12]
Report message to a moderator
Re: Completely lost.... any ideas? [message #665531 is a reply to message #665497] Thu, 14 April 2011 19:04 Go to previous messageGo to next message
Eclipse User
Originally posted by: rth_morpheus.web.de
I suppose it would be quite helpful if you could track the source of
this exception. Try using a breakpoint catching this specific type of
exception and copy the code or method that causes it in here.
Robert
Re: Completely lost.... any ideas? [message #665651 is a reply to message #665497] Fri, 15 April 2011 07:28 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
Your JCL is throwing this exception during class loading, and that's
killing plugin activation.
You'll have to google why your JCL would throw that kind of error.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Completely lost.... any ideas? (Unable to launch application - errors attached) [message #666732 is a reply to message #665497] Thu, 21 April 2011 21:55 Go to previous message
jim liu is currently offline jim liu
Member
javadoc below
Thrown to indicate that an attempt has been made to store the wrong type of object into an array of objects. For example, the following code generates an ArrayStoreException:
Object x[] = new String[3];
x[0] = new Integer(0);
java eclipse Search
http://javafind.appspot.com/
Previous Topic:Cloning Custom Perspectives
Next Topic:Dynamic cacading menu items
Current Time: Thu May 23 14:52:56 EDT 2013
Powered by FUDForum. Page generated in 0.10013 seconds
