Home » Eclipse Projects » Eclipse 4 » Where is the API for accessing persisted state?
Where is the API for accessing persisted state? [message #664207] Thu, 07 April 2011 16:05 Go to next message
No real name is currently offline No real name
I have tried googling for the answer, but could not found it.
How you do access the persisted state stored in the model and defined in the workbench editor?
I have an AddOn with persisted state, but cannot find how to read it.
Re: Where is the API for accessing persisted state? [message #664328 is a reply to message #664207] Fri, 08 April 2011 07:49 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
Depending on "where" you are being instantiated, or invoked, you can ask
for the model, or the EModelService. Ex: for an AddOn, you can ask for
the MApplication.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Where is the API for accessing persisted state? [message #664336 is a reply to message #664207] Fri, 08 April 2011 08:09 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
How did the addon persisted the state?
Tom
Am 07.04.11 22:05, schrieb aappddeevv@verizon.net:
Re: Where is the API for accessing persisted state? [message #664352 is a reply to message #664336] Fri, 08 April 2011 10:01 Go to previous messageGo to next message
Through the workbench editor. There is key-value set of fields for persisted state in a number (not sure all) model classes. In this case it was for Addon.
At first I thought it was a per EMF thing but now I am not so sure.
Re: Where is the API for accessing persisted state? [message #666490 is a reply to message #664352] Wed, 20 April 2011 11:02 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph Keimel
I am currently working on a related problem. My goal is to create a Handler to enable the user to reset the UI layout und I am also searching for the API to do this.
I expected the API in EModelService but didn't recognize it there.
Is it necessary to use Perpectives to get access to features like this?
Christoph
Re: Where is the API for accessing persisted state? [message #666499 is a reply to message #666490] Wed, 20 April 2011 11:26 Go to previous messageGo to next message
Please file a bug so that we can add support for resetting also in case
of none perspective use.
Tom
Am 20.04.11 17:02, schrieb Christoph Keimel:
> Christoph
Re: Where is the API for accessing persisted state? [message #666618 is a reply to message #666499] Thu, 21 April 2011 06:45 Go to previous message
Hi Tom,
Bug is filed: Bug 343512
If using Perspectives: How could this be done? Is this what EModelService.resetPerspectiveModel(...) will do?
The comment to this function sounds more like as if the Perspective will be deleted completely ...
Christoph
Previous Topic:Maximizing a Part
Next Topic:4.1M7 and e4 0.11M7 are now available
Current Time: Mon May 20 04:21:10 EDT 2013
Powered by FUDForum. Page generated in 0.01686 seconds
