Home » Eclipse Projects » JFace » TreeViewer refresh performance
TreeViewer refresh performance [message #513534] Wed, 10 February 2010 09:10 Go to next message
philipp huebner is currently offline philipp huebner
Hi folks,
I've messured that my tree takes over 2 seconds for a refresh on a element in atree with about 10000 elements. Thats too slow for our use cases; is there a possibility to speed this up or sth like a SWT.Virtual flag for trees ....
Re: TreeViewer refresh performance [message #513549 is a reply to message #513534] Wed, 10 February 2010 09:31 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
did you turn off redrawing (tree.setRedraw(false))?
Tom
Am 10.02.10 15:10, schrieb philipp huebner:
> Hi folks,
> flag for trees ....
Re: TreeViewer refresh performance [message #657102 is a reply to message #513549] Tue, 01 March 2011 10:39 Go to previous messageGo to next message
ahh....nope. But why....Then you disable the entire tree. I want still draw it....
Is JFace's Tree Performance really that bad? That can't be possible. It must be able to handle this....
Re: TreeViewer refresh performance [message #657120 is a reply to message #657102] Tue, 01 March 2011 10:57 Go to previous messageGo to next message
A refresh might mean in your case many many micro updates and to make
them into one big flush you do:
try {
tree.getControl().setRedraw(false);
// Make you UI-Updates
} finally {
tree.getControl().setRedraw(true); // Flush all changes at once
Am 01.03.11 16:39, schrieb philipp huebner:
> draw it.... Is JFace's Tree Performance really that bad? That can't be
Re: TreeViewer refresh performance [message #657261 is a reply to message #657120] Wed, 02 March 2011 03:48 Go to previous messageGo to next message
Ok I understand; but does this really work. I have really one call of tree->refresh. Whre do I have to add this code?
Re: TreeViewer refresh performance [message #657262 is a reply to message #657261] Wed, 02 March 2011 03:53 Go to previous messageGo to next message
Exactly there where i had my // Make you UI-Updates comment.
Tom
Am 02.03.11 09:48, schrieb philipp huebner:
Re: TreeViewer refresh performance [message #657272 is a reply to message #657120] Wed, 02 March 2011 04:54 Go to previous messageGo to next message
But I have already cached my update events.
I have a customized tree viewer for an emf model. There are many unnecessary update events which are cached to one update, but this one update is still very slow.
Disable redrawing could only be a solution if you do it in an inherited method of the tree itself. I
Re: TreeViewer refresh performance [message #665898 is a reply to message #513534] Mon, 18 April 2011 01:07 Go to previous message
jim liu is currently offline jim liu
Member
do not refresh all tree,just refresh a tree node item?
java eclipse Search
http://javafind.appspot.com/
Previous Topic:Zest Graph Viewer reference points to null all of a sudden
Next Topic:Exceptions and DataBindingContext.bindXXX methods
Current Time: Tue May 21 17:21:26 EDT 2013
Powered by FUDForum. Page generated in 0.01799 seconds
