Home » Eclipse Projects » Web Tools Project (WTP) » Javascript Editor Type Validation(Unable to resolve type in included libraries/project sister files)
Javascript Editor Type Validation [message #665843] Sat, 16 April 2011 19:46 Go to next message
Matt Taylor is currently offline Matt Taylor
The latest version of the javascript editor appears to be able to do some rudimentary 'includes' of libraries and other javascript files for the purposes of validation.
Unfortunately it doesn't seem to handle the 'new' keyword very well.
If I have the following in the included file:
function foo(){};
the following validates (and I can even ctrl-click to the definition in the other file):
var v = foo();
However if I do this:
var v = new foo();
The editor gives a 'foo cannot be resolved to type' error (I have 'check for unresolved types/fields' enabled for javascript validation).
(the above is legit javascript and it validates fine if I have the definition of 'foo()' in the same file)
My question is: Is this just too much to expect from the editor or is this a bug? Or maybe there is some setting I am missing?
Thanks in advance for any answers.
Re: Javascript Editor Type Validation [message #665865 is a reply to message #665843] Sun, 17 April 2011 09:59 Go to previous messageGo to next message
Ian Tewksbury is currently offline Ian Tewksbury
Member
Matt,
This is not a bug, this is the way the JavaScript type inferencing is currently designed. The two most common ways we determine if something is a type is if we detect the following syntax:
function foo() {
this.bar = "test" <----the reference to 'this' tips us off this is a type and not just a function
function foo() {}
foo.prototype.myFunc = function() {} <-- the use of prototype tips us off this is a type.
Just having 'function foo() {}' just looks like a function to us and there is no information there hinting this could be a type.
My suggestion to you, if you do not want to see the validation message any more, would be to use one of the two syntaxes above or turn off the validation.
If you have any other further questions please do not hesitate to ask.
Blue Skies,
~Ian
Ian Tewksbury
WTP JavaScript Tools
IBM Rational
“When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return.” ~Leonardo da Vinci
Re: Javascript Editor Type Validation [message #666071 is a reply to message #665865] Mon, 18 April 2011 17:40 Go to previous message
Thanks for the great reply Ian.
I'm using the slightly condensed
foo.prototype.foo = {}
form and it works like a champ (it isn't exactly meaningful/correct javascript, but it is enough to tell the validator that foo is a type, which is good enough for a stub that will never see the light of a browser Smile ).
Matt
Previous Topic:WSDL editor (WSDL 2.0 ?)
Next Topic:Unexpected context restarts
Current Time: Tue May 21 07:42:43 EDT 2013
Powered by FUDForum. Page generated in 0.02077 seconds
