Home » Eclipse Projects » Web Tools Project (WTP) » Exception in web project export
Exception in web project export [message #665435] Thu, 14 April 2011 11:28 Go to next message
Ashish  is currently offline Ashish
Hi ,
I was trying to export a web project war , but I got the following error.
org.eclipse.core.runtime.CoreException: Extended Operation failure: org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentExportOperation
at org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.performFinish(Unknown Source)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(Unknown Source)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(Unknown Source)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Unknown Source)
at org.eclipse.swt.widgets.TypedListener.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.jface.window.Window.runEventLoop(Unknown Source)
at org.eclipse.jface.window.Window.open(Unknown Source)
at org.eclipse.ui.actions.ExportResourcesAction.run(Unknown Source)
at org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(Unknown Source)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Unknown Source)
at org.eclipse.jface.action.ActionContributionItem.access$2(Unk nown Source)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(Unknown Source)
at org.eclipse.ui.internal.Workbench.runEventLoop(Unknown Source)
at org.eclipse.ui.internal.Workbench.runUI(Unknown Source)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Unkn own Source)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(Unknown Source)
at org.eclipse.ui.internal.ide.IDEApplication.run(Unknown Source)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Un known Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Unknown Source)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Unknown Source)
at org.eclipse.core.launcher.Main.basicRun(Unknown Source)
at org.eclipse.core.launcher.Main.run(Unknown Source)
at org.eclipse.core.launcher.Main.main(Unknown Source)
org.eclipse.core.runtime.CoreException[0]: org.eclipse.core.commands.ExecutionException: Error exportingWar File
at org.eclipse.jst.j2ee.internal.archive.operations.J2EEArtifac tExportOperation.execute(Unknown Source)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl$1.run(Unknown Source)
at org.eclipse.core.internal.resources.Workspace.run(Unknown Source)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.runOperation(Unknown Source)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.doExecute(Unknown Source)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.executeImpl(Unknown Source)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.cacheThreadAndContinue(Unknown Source)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.execute(Unknown Source)
at org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard$1$CatchThrowableRunnableWithProgress.run(Unknown Source)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(Unknown Source)
Caused by: org.eclipse.jst.j2ee.commonarchivecore.internal.exception.Sa veFailureException: includes/js/dojo/dojox/rpc/demos/templates/documentation.htm l
at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Zip StreamSaveStrategyImpl.save(Unknown Source)
at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Sav eStrategyImpl.save(Unknown Source)
at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Sav eStrategyImpl.saveFiles(Unknown Source)
at org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.save(Unknown Source)
at org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ModuleF ileImpl.save(Unknown Source)
at org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.saveAsNoReopen(Unknown Source)
at org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentExportOperation.export(Unknown Source)
... 11 more
Caused by: java.io.IOException: Data error (cyclic redundancy check).
at java.io.FileInputStream.readBytes(Native Method)
at java.io.FileInputStream.read(Unknown Source)
at org.eclipse.jst.j2ee.commonarchivecore.internal.util.Archive Util.copy(Unknown Source)
... 19 more
Anyone can please help ?
Re: Exception in web project export [message #665480 is a reply to message #665435] Thu, 14 April 2011 14:24 Go to previous message
Larry Isaacs is currently offline Larry Isaacs
On 4/14/2011 11:28 AM, Ashish wrote:
> Hi , I was trying to export a web project war , but I got the following
> error.
> ent(Unknown Source)
> Source)
> t(Unknown Source)
> Source)
> run(Unknown Source)
> veFailureException:
> ... 11 more
> ... 19 more
It would appear that the "Data error (cyclic redundancy check)" error is
being reported by your OS while trying to read the
" includes/js/dojo/dojox/rpc/demos/templates/documentation.htm l " file.
Are you able to open this file successfully in Eclipse or other editor?
Larry
Previous Topic:JavaScript Editor contributions
Next Topic:Customize Web Page Editor Palette
Current Time: Fri May 24 00:20:45 EDT 2013
Powered by FUDForum. Page generated in 0.01636 seconds
