Home » Modeling » GMF (Graphical Modeling Framework) » Audit Rules and Link Contraints in code ?
Audit Rules and Link Contraints in code ? [message #217325] Thu, 05 February 2009 03:11 Go to next message
Pierre is currently offline Pierre
Hello everybody,
I would like to know where Audit Rules and Link Constraints are generated
in the generated code (in .diagram, but in which class?)?
Thanks in advance.
Pierre
Re: Audit Rules and Link Contraints in code ? [message #217382 is a reply to message #217325] Thu, 05 February 2009 09:10 Go to previous messageGo to next message
Stephane Bouchet is currently offline Stephane Bouchet
--------------030906010300010504030300
Hi pierre,
it depends the langage you used.
if it is java, look at the ????VisualIDRegistry Class.
Pierre a
Re: Audit Rules and Link Contraints in code ? [message #664846 is a reply to message #217382] Tue, 12 April 2011 05:23 Go to previous messageGo to next message
g mouch is currently offline g mouch
Stephane Bouchet wrote on Thu, 05 February 2009 16:10
I used OCL. Can anyone tell me where the code is?
Re: Audit Rules and Link Contraints in code ? [message #665319 is a reply to message #664846] Thu, 14 April 2011 06:26 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph Gerbig
take a look at the generated expression package *diagram.expressions. Is there anything you need helph with?
Ralph
Re: Audit Rules and Link Contraints in code ? [message #665384 is a reply to message #665319] Thu, 14 April 2011 10:01 Go to previous message
Thank you Ralph. I do not need help with something, I just wanted to see how OCL rules are represented and how they interact with my application.
Previous Topic:Create NODE and EDGE togther
Next Topic:"create new" from palette or diagram does not work in generatet diagram
Current Time: Sat May 25 01:38:57 EDT 2013
Powered by FUDForum. Page generated in 0.01766 seconds
