Home » Modeling » MDT (Model Development Tools) » [Xtend / Check] using multiple check files
[Xtend / Check] using multiple check files [message #664198] Thu, 07 April 2011 15:23 Go to next message
Volker Wegert is currently offline Volker Wegert
I'm unsure if this is the correct newsgroup for questions related to the
Check language - please feel free to crosspost if it isn't...
I'm thinking about replacing some rather clumsy hand-written Java
validators with Check expressions using the extension point
org.eclipse.xtend.typesystem.emf.checks. I need to execute my checks
instead of the default EMF checks because the error messages generated
by the default checks are unsuitable for the users. From the
documentation I understand that I have to set override to true, and it
seems to work.
At the same time, I want to keep things organized by splitting my checks
into several .chk files. I can add multiple checkFile elements inside a
metaModel element, but I'm getting strange results. If I read the
implementation of CheckRegistry correctly, the validators that
correspond to each of the files replace each other as soon as override
is set to true. This looks like a bug to me - is it one?
Volker
* Volker Wegert * http://www.volker-wegert.de/contact *
Re: [Xtend / Check] using multiple check files [message #665304 is a reply to message #664198] Thu, 14 April 2011 04:31 Go to previous message
Sebastian Zarnekow is currently offline Sebastian Zarnekow
Hi Volker,
the m2t newsgroup is a better match for questions related to the Check
language.
I hope that somebody will jump in and answer your actual questions.
Sebastian
Am 07.04.11 21:23, schrieb Volker Wegert:
> Hello,
> seems to work.
> Thanks
> Volker
Previous Topic:Topcased interface custumitation
Next Topic:[BPMN2] adding potentialOwner to UserTask
Current Time: Sat May 18 11:17:16 EDT 2013
Powered by FUDForum. Page generated in 0.01658 seconds
