| [EMF Compare] Custom ContentProvider and LabelProvider + TransactionalEditingDomain [message #657688] |
Thu, 03 March 2011 11:14  |
Sylvain Dudoit Messages: 5 Registered: February 2011 |
Junior Member |
I'm using EMF Compare 1.0.1 with Eclipse 3.5.2.
I want to integrate EMF Compare in my RCP application.
I already tried to implement a Handler like this :
MatchModel match = MatchService.doMatch(eObject1, eObject2, Collections.<String, Object> emptyMap());
DiffModel diff = DiffService.doDiff(match, false);
ComparisonResourceSnapshot snapshot = DiffFactory.eINSTANCE.createComparisonResourceSnapshot();
snapshot.setDiff(diff);
snapshot.setMatch(match);
ModelCompareEditorInput input = new ModelCompareEditorInput(snapshot);
CompareUI.openCompareEditor(input, true);
My problems are :
- The two EObjects come from a TransactionalEditingDomain. Then, the commit of changes is a problem since it doesn't use transactions.
- How can I customize the viewers in order to put my customized LabelProvider and my Filter or Decorator.
Thank you for your answer,
Sylvain
| Re: [EMF Compare] Custom ContentProvider and LabelProvider + TransactionalEditingDomain [message #665089 is a reply to message #657688] |
Wed, 13 April 2011 04:51  |
Laurent Goubet Messages: 1545 Registered: July 2009 |
Hi Sylvain,
The merging process of EMF Compare does not use transactions for now. We do have a bug opened for it, but that is not a planned enhancement, so I don't know when it will be implemented.
As for providing you own label providers, the EMF Compare viewers are currently not really customizable as we haven't finalized their API yet. We hope for the UI aspects to be customizable for EMF Compare 1.3 (June 2012).
Laurent Goubet
Obeo
FUDForum. Page generated in 0.01820 seconds
