Home » Eclipse Projects » XML Schema Definition (XSD) » Can we use list of user data structure as an element
Can we use list of user data structure as an element [message #664461] Fri, 08 April 2011 22:25 Go to next message
No real name is currently offline No real name
Embarrassed
I am working with xml, xsd and jaxb for xml to java and java to xml conversion
I have xml of this format
<Configuration>
<SelectedDataList>
<Data id="name" seq="1"/>
<Data id="taxid" seq="2"/>
</SelectedDataList>
</Configuration>
From This i basically need a java object mapping
class Configuration{
protected List<Data> SelectedDataList;
class Data{
string id;
int seq;
I am new to xsd so having little trouble in designing xsd which will result in above java-xml translation.
Your help is appreciated.
Anup
Re: Can we use list of user data structure as an element [message #664487 is a reply to message #664461] Sat, 09 April 2011 13:05 Go to previous message
Ed Merks is currently offline Ed Merks
Anup,
Most schema to Java mappers will produce an intermediate object to
represent SelectedDataList so I think you're out of luck.
anup.mayank@gmail.com wrote:
> :blush: Hi,
> conversion
> <Configuration>
> <SelectedDataList>
> </SelectedDataList>
> </Configuration>
> class Data{
> string id;
> int seq;
> Thanks
> Anup
Previous Topic:Is it possible to manually specify schema to use for XML for wst xml editor?
Next Topic:view xml file with internal web browser
Current Time: Fri May 24 14:30:41 EDT 2013
Powered by FUDForum. Page generated in 0.08683 seconds
