Home » Archived » BPMN Modeler » How to enable the Save button once a tabbed propertySections is modified(Enable Save button when tabbed propertySections is modified)
How to enable the Save button once a tabbed propertySections is modified [message #664042] Thu, 07 April 2011 05:33
BK  is currently offline BK
We have extended the Task in the BPMN diagram to include an tabbed propert by using the extension point of
org.eclipse.ui.views.properties.tabbed.propertySection.
We have the tabbed property in the Task property but when we add/change any value in the property , the "File->Save" option is not enabled in eclipse. However we have noticed that it gets enabled when we move the task in the diagram , so BPMN plugin is able to do it and I need to do the same thing when the property value is changed.
Any pointers would be appreciated,
BK
Previous Topic:Load BPMN modeler from a plugin
Next Topic:Adding a Pool using the BPMNVisual2ProcessGenerator
Current Time: Fri May 24 23:55:05 EDT 2013
Powered by FUDForum. Page generated in 0.05539 seconds
