Home » Eclipse Projects » Eclipse 4 » DeltaPack
DeltaPack [message #664014] Thu, 07 April 2011 04:17 Go to next message
AppleJus Mising name is currently offline AppleJus Mising name
Member
Is there any delta pack for eclipse 4.1?
All I see so far are ones for 3.x.
Re: DeltaPack [message #664023 is a reply to message #664014] Thu, 07 April 2011 04:23 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Simply use the one from 3.x. All the native fragments you need are the
ones we share with 3.x anyways (swt, launcher)
Tom
Am 07.04.11 10:17, schrieb AppleJus:
> Thanks
Re: DeltaPack [message #664076 is a reply to message #664014] Thu, 07 April 2011 08:28 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
On 04/07/2011 04:17 AM, AppleJus wrote:
And in general we don't use the delta pack in our 4.1 work, at least not
for builds. We use a (well, several) p2 repositories and build our
products using the p2 director.
The delta packs are still useful for exporting from the workspace for a
different platform though, AFAIK.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: DeltaPack [message #664252 is a reply to message #664014] Fri, 08 April 2011 00:06 Go to previous messageGo to next message
Member
Thank you all,
I need the delta pack specifically to export on multiple platforms.
I got the delta pack 3.6.2 and installed it correctly ( adding using target platform and putting it inside the eclipse installation folder ) but I get this error when checking the export to multiple platform box in the export wizard and exporting:
Processing inclusion from feature org.eclipse.equinox.executable: Unable to find plug-in: org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400. Please check the error log for more details.
I made sure the required plugins are listed in my .product ..
Is this a version incompatibility problem? Do i need to try other delta pack versions? Or am I missing something?
Thanks for any help
Re: DeltaPack [message #664298 is a reply to message #664252] Fri, 08 April 2011 06:05 Go to previous messageGo to next message
3.6.2 is wrong you need the one from 3.7!
Tom
Am 08.04.11 06:06, schrieb AppleJus:
> Thank you all,
> Thanks for any help
Re: DeltaPack [message #815143 is a reply to message #664298] Wed, 07 March 2012 04:34 Go to previous messageGo to next message
Kris Reid is currently offline Kris Reid
I have the exact same error when trying to export to multip platforms 'Unable to find plug-in: org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400'
Did anyone find a work around?
Re: DeltaPack [message #893464 is a reply to message #815143] Wed, 04 July 2012 04:47 Go to previous message
Oliver Koch is currently offline Oliver Koch
Member
i used the following article to create my delta pack from the Repo found
at http://download.eclipse.org/eclipse/updates/3.8-I-builds
http://wiki.eclipse.org/Platform-releng-faq#How_to_assemble_the_deltapack_using_the_p2_slicer
Then my IDE export works well but the launcher "is not able to find it's
companion ..." .
I posted a new thread on this topic.
I think I'll try to assemble my delta pack from the juno repository,
because my target platform might not contain the platform dependent
fragments of the eclipse plug-ins because I mirrored the plug-ins
without the optional dependencies and greedy inclusions
Am 07.03.2012 10:34, schrieb Kris Reid:
Previous Topic:Juno build trouble
Next Topic:SimpleIDE compilation problem
Current Time: Wed May 22 22:46:17 EDT 2013
Powered by FUDForum. Page generated in 0.06135 seconds
