Home » Eclipse Projects » Eclipse 4 » Help system in e4
Help system in e4 [message #663702] Wed, 06 April 2011 05:11 Go to next message
Kevin Smit is currently offline Kevin Smit
I found a lot of tutors on the net how to set up an help system in a eclipse 3.x rcp app. My question how is this done in an eclipse e4 app.
I use the Applicatione.4XMI file to create a menu, command and handler. After that i open my handler code and ...
In the tutors the code: Platformui.getworkbench().gethelpsystem() comes up to open the help system.
I don't think e4 uses this approach anymore so how to invoke the helpsystem in a native e4 application without compatability layer.
Thanks for the help.
Re: Help system in e4 [message #787374 is a reply to message #663702] Tue, 31 January 2012 09:09 Go to previous messageGo to next message
Lars Vogel is currently offline Lars Vogel
I think the help system is currently not supported in Eclipse 4.2.
Re: Help system in e4 [message #787376 is a reply to message #787374] Tue, 31 January 2012 09:11 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
The help system is in Eclipse 4.2 (the workbench) but it is not available in the E4EAP, Eclipse4 based applications.
PW
Re: Help system in e4 [message #918347 is a reply to message #787376] Thu, 20 September 2012 20:21 Go to previous messageGo to next message
James Navin is currently offline James Navin
Has there been any progress made in making the help system available in eclipse 4 applications?
If not, is there a recommended way of embedding the eclipse 3 system in an v4 application?
Thanks all.
James Navin
Re: Help system in e4 [message #923790 is a reply to message #918347] Wed, 26 September 2012 03:38 Go to previous message
Roland Tepp is currently offline Roland Tepp
Member
I think you are mixing up e4 framework with Eclipse 4.x workbench products.
Eclipse 4.x (the workbench) already has the help system - the same one
that is available to Eclipse 3.x through the compatibility layer.
e4 - (the framework) has no such thing. And is not very likely to get
one in a short while. But it has all the building blocks afailable for
you to build one, if that is what you need.
21.09.2012 3:21, James Navin kirjutas:
> an v4 application?
> Thanks all.
Previous Topic:Calling getObject On A Populated Part Returns null
Next Topic:How to forestall the window closing
Current Time: Wed May 22 21:43:32 EDT 2013
Powered by FUDForum. Page generated in 0.03058 seconds
