Home » Modeling » GMF (Graphical Modeling Framework) » Duplicated elements after Drag&Drop to compartment
Duplicated elements after Drag&Drop to compartment [message #655571] Mon, 21 February 2011 14:20 Go to next message
Patrick  is currently offline Patrick
Hello there,
I stumbled about a rather strange behavior. I was wondering if anyone has already seen this before:
I have a node with a compartment that accepts the same elements as the diagram itself. When i drag and drop a node to the compartment i get two graphical elements. The semeantic model stays correct nevertheless.
Before:
http://img641.imageshack.us/i/beforeo.png/
before
After:
http://img148.imageshack.us/i/afterq.png/
after
I can also cascade that. If i take the new graphical node and drag it out of the compartment again it duplicates again. If i take the old node this wont happen and everything is fine again.
thanks and best wishes
patrick
Re: Duplicated elements after Drag&Drop to compartment [message #655586 is a reply to message #655571] Mon, 21 February 2011 15:02 Go to previous messageGo to next message
Aurelien Pupier is currently offline Aurelien Pupier
I think that you encounter this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=318585
Aurélien Pupier - BonitaSoft S.A.
My blog
My company Eclipse-related blog
Re: Duplicated elements after Drag&Drop to compartment [message #656360 is a reply to message #655586] Fri, 25 February 2011 04:48 Go to previous messageGo to next message
Thanks! I should have found that in the forum. Rolling Eyes
Is there a way to implement a Custom Edit Policy for this case?
Re: Duplicated elements after Drag&Drop to compartment [message #663389 is a reply to message #655571] Mon, 04 April 2011 16:10 Go to previous message
sorry for the delay.
You can subclass and use your own edit Policy that extends CompartmentCanonicalEditPolicy. And add it to your editparts.
as it must be applied to all elements I suggest you to modify the GMF templates used for the generation (ChildContainerCanonicalEditPolicy.xpt)
My blog
Previous Topic:Problems generating my gmf-editors with eclipse helios
Next Topic:Containers of Contains Behaving Weird
Current Time: Tue May 21 22:26:57 EDT 2013
Powered by FUDForum. Page generated in 0.01921 seconds
