Home » Eclipse Projects » EPF » helios build path problem
helios build path problem [message #648119] Tue, 11 January 2011 05:12 Go to next message
Glen is currently offline Glen
HI everyone, need your help please ...
I am getting errors opening the EPF source code that I've got from an external resource but Im having errors on build path
The container 'Persisted container [org.eclipse.pde.core.requiredPlugins for project [org.eclipse.epf.authoring.ui]]' references non existing library 'D:\Program Files (x86)\Eclipse\EPFC_Dev_33\eclipse\plugins\com.ibm.icu_3.6.1. v20070906.jar'
I know that the build path that the external resource used was located on his local machine . How can I modify this using my machine?
I am using helios in opening this.
Thank you
[Updated on: Tue, 11 January 2011 05:42]
Report message to a moderator
Re: helios build path problem [message #662988 is a reply to message #648119] Fri, 01 April 2011 14:27 Go to previous message
Paul  is currently offline Paul
Having the same issue. Did you ever get a response on this?
Thanks.
Previous Topic:EPF Composer on Mac OS X?
Next Topic:Do you use or extend EPF content or tools?
Current Time: Fri May 24 21:04:14 EDT 2013
Powered by FUDForum. Page generated in 0.01641 seconds
