Home » Eclipse Projects » GEF » Modify model when a connection is created
Modify model when a connection is created [message #662850] Fri, 01 April 2011 04:40
Hoang Tran is currently offline Hoang Tran
Hi guys,
I have 2 nodes : A, B and a connection A_B.
I want to initialize connection's properties when user connect node A -> node B.
I have try to install an EditPolicy in A_BConnectionEditPart but it is not successful.
Do I miss something ?
	 * @generated NOT
	protected void createDefaultEditPolicies() {
		installEditPolicy(ConnectionEditPolicy.CONNECTION_ROLE,new CreationEditPolicy(){
			protected Command getCreateCommand(CreateViewRequest request) {
			      return new ICommandProxy(new BindingCommand(getEditingDomain())
					  		protected CommandResult doExecuteWithResult(IProgressMonitor monitor, IAdaptable info) throws ExecutionException
					  			// Property source code to initialize connection's properties is in HERE
								return CommandResult.newOKCommandResult();
	 * @generated NOT
	private static class BindingCommand extends AbstractTransactionalCommand {
		public BindingCommand(TransactionalEditingDomain editingDomain) {
			super(editingDomain, "Initialize BindingCommand", null);
				IAdaptable info) throws ExecutionException {
Previous Topic:[Zest] Layer for a grid
Next Topic:Lock Lines in TextEditor
Current Time: Sat May 25 16:17:32 EDT 2013
Powered by FUDForum. Page generated in 0.01441 seconds
