Home » Eclipse Projects » EGit » How to move java files in Egit between different projects?
How to move java files in Egit between different projects? [message #661087] Wed, 23 March 2011 01:21 Go to next message
murali t is currently offline murali t
Hi there,
I have 2 projects in STS/Eclipse with EGit plugin
MyDomain
SRPApp
com.ebay.foo.package
Bar.java
I want to move Bar.java and foo.package from SRPApp project to MyDomain project with EGit - something I used to do on routine basis with Eclipse/ClearCase,svn before. But EGit only delete Bar.java from SRPApp proj without creating it in MyDomain proj.
Does anyone knows how to do this properly?
thanks
[Updated on: Thu, 31 March 2011 15:31]
Report message to a moderator
Re: How to move java files in Egit between different projects? [message #662710 is a reply to message #661087] Thu, 31 March 2011 11:34 Go to previous messageGo to next message
Stefan Lay is currently offline Stefan Lay
> proj without creating it in SearchDomain proj.
How exactly do you move Bar.java? What do you mean by "move with EGit"?
What do you mean with "without creating it in SearchDomain proj"? Does it
not appear in the Package Explorer or is it not added to the Git repository?
Re: How to move java files in Egit between different projects? [message #662752 is a reply to message #662710] Thu, 31 March 2011 15:26 Go to previous messageGo to next message
I'm using Eclipse Refactor to move Bar.java and foo.package to a different project (with in same Git repo). When I move from SRPDomain project , it removes correctly but doesn't add to MyDomain project. The work around I'm following is to use Git mv to move around files.
thanks
Re: How to move java files in Egit between different projects? [message #662786 is a reply to message #661087] Thu, 31 March 2011 17:40 Go to previous message
Robin Rosenberg is currently offline Robin Rosenberg
On 2011-03-23 06.21, murali t wrote:
> Hi there,
> MyDomain
> SRPApp
> Bar.java
That's a bug. There is is a bug relating to project rename. Thix one
is similar to that one.
https://bugs.eclipse.org/334112
-- robin
Previous Topic:Merge with --no-ff
Next Topic:EGit mylyn nightly md5 wrong.
Current Time: Wed May 22 12:31:41 EDT 2013
Powered by FUDForum. Page generated in 0.01570 seconds
