Home » Eclipse Projects » BIRT » Speed issues & profiling(Tools for speeding up report rendering and profiling)
Speed issues & profiling [message #662246] Tue, 29 March 2011 16:32 Go to next message
Olly   is currently offline Olly
Member
I'd like to know if there are any tools available for profiling my report generation code. I'm currently using System.currentTimeMillis() to profile the section of code that I'm using for opening the .rptdesign file, setting all the options, running the task and closing the task and shutting down the platform. For a really large report, more than 500 lines of records, I time it at around 30 seconds. Is this normal? Are there any optimizations I can make? For small reports of course it doesn't take this long, but I see closing the task and shutting down the platform alone takes about 7 seconds. Thx for any help or advice. Also, if you may have any links for me to follow about this that would be cool.
Re: Speed issues & profiling [message #662408 is a reply to message #662246] Wed, 30 March 2011 10:50 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
How long a report takes to run depends heavily on the number of rows of
data, but more than that how many nested tables and aggregations are
used. Is this a straight listing report? BTW is you are using the
engine api to run your reports only startup and shutdown the engine
once. Wrap the call to get the engine in a singleton and use it to
create a task for each new report. To see how this is done in a webapp
take a look at this:
http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1
You should be able to modify the code to do it in a standalone app as
well. Make sure to look at the bottom of the wiki page for updated code.
Jason
Jason Weathersby
BIRT Exchange
Previous Topic:Database access in Servlet
Next Topic:Refresh Dataset using BIRT API
Current Time: Sat May 18 10:27:12 EDT 2013
Powered by FUDForum. Page generated in 0.01519 seconds
