| Zipped Update Site has external dependencies? [message #662363] |
Wed, 30 March 2011 07:50  |
Chris J Messages: 2 Registered: July 2009 |
Junior Member |
Hi!
I have a problem installing WindowBuilder.
I'm testing with Eclipse Helios (3.6.2) and have downloaded a Zipped Update Site since I want to install on an offline computer.
However when I add either the .zip as an Archive in the Available Software Sites, or I unzip the Zipped Update Site and add it as a Local path, for Eclipse 3.6.2 I get an error when I try to install all the WindowBuilder components.
Cannot complete the install because one or more required items could not be found.
Software being installed: SWT Designer SWT_AWT Support 0.9.0.r36x201103201151 (org.eclipse.wb.rcp.SWT_AWT_support.feature.group 0.9.0.r36x201103201151)
Missing requirement: WindowBuilder Core 0.9.0.r36x201103201113 (org.eclipse.wb.core 0.9.0.r36x201103201113) requires 'bundle org.eclipse.pde.core 0.0.0' but it could not be found
Cannot satisfy dependency:
From: WindowBuilder Core 0.9.0.r36x201103201113 (org.eclipse.wb.core.feature.feature.group 0.9.0.r36x201103201113)
To: org.eclipse.wb.core [0.9.0.r36x201103201113]
From: SWT Designer SWT_AWT Support 0.9.0.r36x201103201151 (org.eclipse.wb.rcp.SWT_AWT_support.feature.group 0.9.0.r36x201103201151)
To: org.eclipse.wb.core.feature.feature.group 0.9.0.r36x201103201113
If I install on an online computer, I only get the error if I uncheck the "Contact all update sites during install to find required software" checkbox in the Install wizard of Eclipse.
It looks to me as if the Zipped Update Site of WindowBuilder for Eclipse 3.6 has external dependencies not satisfied by a standard install of Eclipse IDE 3.6.2.
Shouldn't the snapshot of the Update Site be standalone and not require any further update sites to install?
If other Update Sites are required, could someone please help me find which ones and (if necessary) where their Zipped Update Sites might be available so I can install everything offline?
Chris
| Re: Zipped Update Site has external dependencies? [message #662862 is a reply to message #662790] |
Fri, 01 April 2011 05:39   |
Junior Member |
| Eric Clayberg wrote on Fri, 01 April 2011 01:40 | WindowBuilder absolutely requires the Eclipse PDE which is part of the standard Eclipse install (as defined by the contents of Eclipse Classic).
You can get the PDE from the standard Eclipse update site.
Actually I downloaded Eclipse IDE for Java Developers and not Eclipse Classic.
The download page for Window Builder simply says:
| Quote: | These instructions assume that you have already installed some flavor of Eclipse. If you have not, Eclipse can be downloaded from http://www.eclipse.org/downloads/.
That doesn't look altogether useful as information. Perhaps you could state that PDE is required and link to the Eclipse Packages comparison page?
Installing PDE in an offline version of Eclipse for Java Developers wasn't straightforward. I did find a "PDE Runtime Binary" distribution here but there was no instruction on how to install it and it didn't resolve the need for the dependency if I simply unzipped it in the Eclipse directory. Could anyone point me in the right direction?
I'd rather not install the Eclipse Classic if I can avoid it as it's not the set of features/plugins I need apart from the Window Builder dependency on PDE.
FUDForum. Page generated in 0.01924 seconds
