Home » Eclipse Projects » Virgo » LogReaderService for Virgo
LogReaderService for Virgo [message #658302] Mon, 07 March 2011 13:56 Go to next message
Marco Ocana is currently offline Marco Ocana
I would like to see some logging output from some bundles that utilize OSGI compendium logging . By default, it appears that a LogReaderService is not started in Virgo.
I have found some blogs describing how to roll your own logging solution in osgi containers. Would seem that the ideal for Virgo would be to have an LogReaderService adapter that would use the included logback-based logging.
Is there an "official" way for the LogReaderService to be hooked up to Virgo's Logback logging?
Marco
Re: LogReaderService for Virgo [message #658395 is a reply to message #658302] Tue, 08 March 2011 05:57 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn Normington
I'm not sure, but presumably you could write such an adapter and have it use the normal slf4j API which will then feed into logback as usual.
Re: LogReaderService for Virgo [message #662333 is a reply to message #658302] Wed, 30 March 2011 05:32 Go to previous message
Ahmed EL AMINE is currently offline Ahmed EL AMINE
No Message Body
[Updated on: Wed, 30 March 2011 05:42]
Report message to a moderator
Previous Topic:war deployment fails with CNF exception
Next Topic:[Resolved] Redirect Virgo's Tomcat logs into console
Current Time: Tue May 21 07:41:47 EDT 2013
Powered by FUDForum. Page generated in 0.01801 seconds
