Home » Eclipse Projects » EPF » EPF Composer on Mac OS X?
EPF Composer on Mac OS X? [message #489892] Tue, 06 October 2009 08:50 Go to next message
Gerhard Schneider is currently offline Gerhard Schneider
Hi there,
did anyone try to build the EPF Composer on Mac OS X, since the very first posts on that topic from V1.0?
Greetings,
Gerhard
Gerhard
innoreq® Gerhard Schneider - Prozesse einfach verbessern.
http://www.innoreq.com
Re: EPF Composer on Mac OS X? [message #555171 is a reply to message #489892] Wed, 25 August 2010 13:01 Go to previous messageGo to next message
No real name is currently offline No real name
Gerhard,
Did you ever find a downloadable version of EPF Composer for Mac OS X? I am also interested in using Composer on a Mac.
Wendy.
[Updated on: Wed, 25 August 2010 13:02]
Report message to a moderator
Re: EPF Composer on Mac OS X? [message #599464 is a reply to message #489892] Wed, 25 August 2010 13:01 Go to previous messageGo to next message
Gerhard,
Did you ever find a downloadable version of EPF Composer for Mac OS X? I am also interested in using Composer on a Max.
Wendy.
Re: EPF Composer on Mac OS X? [message #633476 is a reply to message #599464] Mon, 18 October 2010 03:37 Go to previous messageGo to next message
Wendy,
no, there seems to be no update to the non-availability of EPF on Mac. As far as I understood, the rich-text editor used by EPF is a tool using Windows libraries, which are not available on the Mac.
The only way to use EPF on Mac therefore is to run it in a virtual Windows machine, like with Parallels Desktop.
Gerhard
Gerhard
Re: EPF Composer on Mac OS X? [message #651437 is a reply to message #633476] Sun, 30 January 2011 16:10 Go to previous messageGo to next message
AJ Missing name is currently offline AJ Missing name
--------------090201020100060906040009
Content-Type: text/plain; charset=UTF-8; format=flowed
That information is incorrect. The rich-text editor as well as the
whole EPF RCP runs perfectly fine on Mac (see attached screen).
However, you have to build the product from your workspace.
On 10/18/10 12:37 AM, Gerhard Schneider wrote:
> Wendy,
> Gerhard
Content-Type: image/png;
name="Picture 2.png"
Content-Disposition: attachment;
filename="Picture 2.png"
iVBORw0KGgoAAAANSUhEUgAABX4AAANVCAIAAABAlXH1AAAPUGlDQ1BJQ0Mg UHJvZmlsZQAA
eAGtWHk8VF//P3dmGPu+70uW7PuafUska0T2sW9jBskSkRaiIpEUUl8SkiTR IkLIlixFY8lO
JPv+3KG+39/yel7PP895veae93mfz3bP58753HMBoOdyxWL9EQCAgMAQnKWR Lp/dKXs+9ACA
ABegAXSAxtUdj9UxNzeFRf5NW+2FpeHWLUm0pbZ0tR3KO51wjkdAnJKc6+a/ UfpD0+BghwBA
EjDB5HWAtYnY7QBbE/GZEGwILONNxO7erhgYR8FYAmdtqQfjQhjTeB3gKiJ2 O8AfiDjM3Yuo
2w8AKUMgxicQAPQcjDUxHnh3eJroF4PBuwfA+DoACM2AgCDYPl0nzIu6Y3Gw Lt06jA8R1wXu
4eYEc4pyAKAG/uGChQCoOAUAL/iHE9EAgAW2+eTYP9yS5f5aQSwdeE952Abc ICpdAEgIe3tL
wnBsqQDs3Njb27q/t7eTDwByEIBaf/dQXNi+LCwNtQHwn8YH9/xbAwknh5hg OqACQkAdJAU1
Ic4jMahgknw0iiybwpqKn4aCjoR+iZHAXM6KZafhSOPc5NbhwfM+4Ovk3xA8 dMhMKFq4QKRD
dEOMS9xYwk8ySeqJdIfMvBylvICChqKdElY5QSVb9YnaC/XSI9kaiZqhWs7a Zjqauof1OPTJ
9dcNJg37jJqP1hiXHLtnkmIacxxn5n7C2lzfQtFS1IrHmtmG4SStLYUdid3e qQ37JYe50+OO
w07fnPtdul273Drd2zFtHu2eXV6fvft9Bn1H/Ib8OwIqA7OCorGYYEOcGJ4K vxDSFVoWlnYG
F25+ViaCOmImsjEqNzrqnE2MTCx57Mj513EP4ssu1Cf0XJy+tHeFOVEiSe+q XXJISsq1guuN
N0ZSd25ypKvcss0Iy0y//Tyr987aXeZ7MjkquXJ54vdF8vkfcDxk/ou6gLQQ FG4/Witafvyz
eLZkqnTiyXjZ6NPv5WPPRiuGnw9VEl4MVnW9fFNdVpP9Kul15Buftydrdd5J 1rHVg/qJ9+0N
5Y2pTbgPFs1SLeQt31tff0xv82/X6qDtIHQWdeE/qXVD3c2fk3qO99L2dval 9Jt+ofjS9DV+
QHtgZ7Dq2xmCImFpqGIYPyI/sjL68nv4mOLY4njxhOekwOTQ1P1pnxmlWfLZ 2bnuH+3zfQuL
iyK/opZmVq6uWW44bZXtGu3twfmnB+ogEnRAqtBLxEkkPXKNhIL0BLqWHEMp QX2YVoJei9GI
WZ6Vmq2U4whnDtcsDyevIR+WP12gRnBUiE5YWcRBNOrwPbE68WGJXSleaVWZ E7LechHyVxVy
FZ8q1Sp3qAyoflNrVS8/kqkRremqZawtp8OqC+nO6PXovzF4ZHjL6MJRnLHz MRMTZVOR40xm
kNn8iQHzFotqy8dWOdbpNoknz9kG22FO2dqbOmielneUcBJwZndhdKV1o3BH Y0g9SD3JvCi9
aXwYfel99/zG/JsCigKvBWGx1sEKOFbcGr4vpCo0IyzkjE243Fnas7MRjZH3 oyKj7c7JxVDG
TMZ2nG+L64n/dmEy4dfFvcuUV9gTRZJUr5omO6ecuZZ8/a8br1P705bT6W9J Z5hlBt2+kVVy
pz37293he5M5P3NX87bzUQ/IH9L8xVLAWyj6SK7oyGODYosSx1L/J+Fll59m lRc8e17R8Ly3
cuLFYtV6NahBviJ/TfOG8S1zLfM7Vjj/zO8ZGugbqZvQHxAftptXWn60Tnwc autv7+5o6izp
SvyE6db8zPJ5vqe5915fSL/xF54vv77WD6QPen5TICAInUO3hzEjUiOro7Xf L40dH+eeoJ2k
mkJOrU//mpmZ/T7X+6NrvmWh6WfzYsuvjqWvy7Or0BrHutqG6+bVrZfbc7s8 eyr7+acC4uAU
SAcESB9qQLgiOZBbJEhSefQ1cnKKu1Sa1LO0F+iZGS4zDjPzsuixGrNpsEtx 8HOSc65yjXP3
8LzjfcyXxh8p4CZodEhUiEJoSrheJEs06LCBGIfYjPhLiUuSVlLcUu3S52Sk ZQZkL8spy43J
31DQUphVzFDSV1pQzlIxVFlUzVLTV/uhfuuI1pEJjWRNRc1hrRRtXe1tnUpd rN5hvVH9OwbW
hrSGLUYXjxoYI4xrj8Wa6JkiTRuPJ5lZnGA/MWJeZIG3VLfcsXptHW2jbrN1 str2rJ2y3eqp
Cnusg6zD/OlixwAnMadZ5yIXH1dx1zm3UvdgjDxmxaPSM8RLzuund6lPgK+4 77Rfgb97gEDA
SGBukAuWGzsQnImzxbPgP4ekhVqGMYR1nkmBdxL2sxMRVZEpUa7RSudozk3E vI3NPh8Zdzpe
58KhBAr4ORq81HT52ZW8xNSkmKv+yfYpx66pX5e4wZVKlbqb9uvmdProrcGM /swvtwezhu9M
ZS/fg3LocvnzlO6b5Ls9iHx4669nBV2Fc0U0j+WL7UqiS/OeNJTNlzM+U6lw fn658smL3peI
avEam1cxr4vfdNdC76TqTtVfev+sgdBE9UGr2b8lpbXs48e26Q6oU6DL4BOu u/DzVK9C380v
VF9vD5oS2IYFR93Gxia7Z4N/Mq3pEPN/UPuINYFUCYA75QDYjQJglQ1AcgZc 6lgBYHYBwJwa
AGtVAE14Auh7H4AU68Cf+iELbEAYSANloBWMgx2IBa4khpAzdAa6DhVCddAg tI5gQsgizBFY
RCriBYKARCMVkB7IO8heFCPKEnUT1U/CTYIheUyyQqpDeo2UgJZFx6H7yWTJ EsnGyfXI8ylI
KPwouihVKfOp6KliqH5Se1B/pwmg2aC9QsdNV0avT09gCGNkYHzCZM60yJzG osIyxHqFTYlt
lD2Vw4Bjk7OMy4ubB35SE3l1eXf4qvkjBI4I7Ak2HEoWshbmFp4ReSEaf9hS TFBsWbxBIlPS
V0pbmkX6h0y3bItck3yTQoNiq1KX8oDKhOqGOtkRPg01TWutUO0MnXe60/ps BoaGkUblR78Z
E471mnSbdhxvMWs60WBeb1Fv2WT13rrBpvnkB9uPdl2n+uwJDmOnZx2XnXZd yFwZ3XjcpTFa
Hnae17y6fGh8Tf1S/XsCOYM8sWXBG3j9kJTQwTOS4VFn2yK5ooKj62IYY/3O v4/nuRCe0HNJ
+3J1onRSWbJ4yqPr4jeepWncbLpln7F8O/GOeHbPvdhc+bzZ/EcPfQukC7eL eourSvPLMsvT
K25U5lQ9rW58NfWW8p1ivXvDjabm5rWPUu2nO9M+NX1e6lP+cn6gmyA8HDZa NTY+STK1MzM9
VzzvuLC8GPirZZlxxXTVay18PWrDa9Noi3WLsJ29o78ztzu4v39IwbtHDMgD teAbWIcYIQnI
AHKCQqFk6CH0BuqDfiIoEEIIXYQLIgaRi2hA/ECyIA2QZ5ClyFmUGMoXVYpa IlEjiSNpIWUh
xZBWoNFoe/QTMjIyN7LX5Fzk58iHKYwoyig5KC9SrlB5UX2ltqDupHGmWaCN p+OkK6c3oZ9m
SGAUYmxk8mOmZX7O4shKxlrJ5snOzN7MEcOpzLnI9Zjbm0eQZ4j3Lp8zvyD/ tMBTwYhDRkKM
QgThUpEYUbPDPId/ib0Xz4DfXzSlmKRmpd/J5MtmyWXK31bIVMxReqBcplKj 2qY2pL6iQacp
qnVM21cnTbdab9qAydDIKPposfGrY29NGk0/Hu8y6ztBMJ+wWLDcsNqzQZ+k s2Wx4zslaq/g
oHHa0NHcycHZ0yXYNcrtsvsdTIFHg+eat6iPlW+CX43/fOChIGfs7eAuPGWI QWhs2Nsz22fV
IsIjn0etn1OIwcW+OL8N7y4JCa2XWC8HXHmXxHM1Irn3mtL1zFREmu/N7lv6 GS9vi2XlZfPc
zc7hys25L5Rf/FDhr9eFho8GHieVWD7hgXeQ9xU3K3FVVtUKr7jf0LzdebdW v96w+YGiheWj
TLtBp/enq59tepF9tV/iB7QGdwlvh5NGTcboxtsnL0xrzSzP5c3rL3xfjFli Wc5bPbxWtiG/
+XRbcefxfv61QTDIBnVgHCKFhCA9yBWKgbKhGugLtIHgRGgi3BFJiErEBFxX rJDpyCGUJCoa
1U0iRhJPQiDVJM1Dk6GD0QQyc7L35BrkNRRaFI2U5pTDVKHUNNQlNF60QrSz dBX0cQzWjBJM
ZEwzzJ0sNawlbPns9zhyOR9yFXEX8NzlzeTL4M8SyBUsOFQuVC3cLNIvOnZ4 TRwtwS4pJqUl
bS0TKJsuVye/rCis5AjXm141LnXHI4UaC1qa2ok6Q3rS+hcMvhrJH00xXjVx Mm0zUz9RYiFo
mWvNZpNhy2x3x17IodRR3anV5bTrgnuSB49nvregT6Yfs//1QLKgeOwmLgA/ FHo8rDZc6mx2
JDoqLHok5lhsTZxkfE4C/cW4S6tXAhLHrjokt13TvF6Sypt25eYi/H+tuy2Q FXdn7K7evZyc
rTzb++UPqB56wBljeoQvai3mLcGXNpfxP40o76kQe55Q+b1K+2V29dqrk69f vGWoxb37VK/w
/lbDSpPTh7ctfK2XPs63W3S86hL+dL17uedUbyv8jtg0YDb4mYAZmhzxH50e sx9/PykydX66
bZZyTv2H6/y5hYs/Ly1e+OW9ZLDMsjy6krdqvUa29nBdZ31ww3GDsOm82bEl t5W+tb7tsJ2z
PbTDu+Oyk7szvMu/a7ebvFu3u7Ynseeyl77XQsz/wXmJWD8AhV6QfxCOz1RP f3/437sE+IfC
Z7L9xgBfqQLdzE7APRFPYUPMreGeBf5t4sOsDOCeDj4O0Xn6GBr/xnwYV30T GHPBvEyEt54Z
jKlgbOqJM7SEMWwHsvN1PWYOYxoY+3oE2lj95sOx/vtnXKJMIjZElyjPBuNs D7zBH5mKCG9r
29+6jbhQSxsYH4JlPvsFmRDlib7WMR76v2NDoAL9zUxhHo4ZweQTYkyMnwnG YsAQuAIc8AIe
QBKYAj2g//vKB/N88DgInvUAeFhubF/uj9TJ/bHP/9GSBJ779sL2dfzABKwT 4OwTh4NtHVhv
Bu4w5woC/zAyj2WmZbb/jPY9+u97/aNhAo/+N3Ng6SC6gxkfgIGl/vDufzSI ngPKPcMyg86q
nfRGCaPkUIooXZQGShOlCvhQLCgOIIlSQKmgdFBaKHV4TrV97sXc37EcrI3b 3/doAsfhAUL3
VyTwb/b/eQU+8DeM/bM7vMqAFH42suEzPQB1JT9jif3/bCEe4SHEsV4Q9izO x8s7hE8H/nLh
IcFnHOguJcEnJyMrC/4FCtaLACvSBUUAAAAJcEhZcwAACxMAAAsTAQCanBgA ACAASURBVHgB
rH0HgBc10/cdvQpIE6SLIEiTLkgXkN47AtKL9CZNivTeO1IFpIsgVVBBQDoI giJF6YL04+C4
8v5mJpPN/u/ged73+xZuk0yfSTabZLP7D/73UWjQK4+oqFeiX4kMDn4lmpHB /w3RfxIDGz1V
JmfkShIMPOBK5xEzDOJdiE8bIYSTwRwNOkXxPz+poVXgS2WqUiUMTF/BaCyN kYJtU1lio5Y4
FaYAKi4amIfycj4J/58KrvX/S00xtRYrzmai2xldjQ8S0MpVy8sEKp6bjS2I Vlcu80cT4gI8
ai+n1nvclsMQeebGQBPdDBXIKUTwtWATP9ZnhqoDiQ/usHgGOMDArLWfES4L XUbuYUt+Fo9E
TfITOtQ266fwJLwiZ1kCrPJYrHRzIRqMn9ErCTqg7MjwBPvlWXgAq4X7BL+E 6CVgqcuXIgNU
/D8VjacvcdiK9pqzAYlx/4HNXnfR2K3gl2Vc51+hhcj0z4hipTGzxIQyilwL rdki0UU55roW
GrBDGQPW8nq4lzDAeqUxaZSlpAx7RyfPzeiueThWrAJ9VlipFurRxnT7BJbV GtnOyIDEszTR
4yl3aFwlJsauNEIznzJravgc8VLnrNMV6uat+QGOW40B0pnXwJjGCouJ0CJN JsB9iw7g9cfb
qVQwODhrsrALHYAegyoIqHajLgAKYkKYkCtrYMpKreZArBFhwdaxAI5XKgFT ALmV5zRlgpn7
H6OVRdNoPNaWACEeoW0MAnIkOVmPHFYCzjFzgJw1ujyVbr1JiD1cNGICeOiY o+Fa5AlgKJ1s
MxE6oYhW4UCqLk1FtXCxK5z1TgzzNTFL65lBBtAfn0SKSLBtVMRAPevFWVqE dAOSN0ilNKlb
5dZ4UUFn1SjquGgYyVW20CaMUF2WysvYkLg6WTC5Jhlx0UbbYw7MObEwVoDi Jb0emUqH6uKC
LSrYpgatiW3FgTFgV0WyUaCKlJXTV0RE8D7q/1XBKGce49z/iv//QGyCAE4v 5xfjGuJVjaF5
WQ1p/ROZr/YdF50sS6NmFKzERoCpLCLVuAeyOZY7jUigxnbXBVZlTxZjpaoa IrFYoWcaNgVl
tlbgtrUwWGEqKM6dByEQZBUYfEBcCBqgzg+Ixr9p3dfTJo3dte9wnDhx2Sim IBlRXqzUCI/A
qncyVnY0C4iIgKDwpFKZBYpT1Abov/wDtRGnuolVZBCJe4gQFs8ovTRRj6h/ qU1jEif+7o8k
xSSRNagoscavlgkCTj6Kl7VqiYXhFKeMb57TjlylgO3SrD2jQGWwDj1nRbdp /oHI6GWKiwkR
IW29+PxRaQ6hk7WtRaS/zHlTv9ZTpnbF2LyqE3m+M6HYNFNxlPeZasqMFiSf vbbkE2cKfqwn
T3JqV0wBFxUUN8vF5OaExMBNYGPQruIFJSWhjonHUEvbJhZtJEaylWbtIYSa KUQWBWKbN/xE
rNRIVRynWgCNkyUZnhRD6FnlCPNUBOac2mSUT7yP2BMcYARTeXZwzm9YTKyq yOBUlcvoOMeR
URpllbJXkktVqbxIKQVbRgX9s6SUYSr3xHkfiVOIGelFAfdDh9qJmEdich7A x6ANxBOj7nkQ
ZfCJ0FAJUIkDwqycMaXKQjifZCU2BGqPgjllBl8lkhS3YTvkAdeSWu5QcDaa ougGeDb7ujAP
TIK4JCCjOQrmqnQgrLfaYImYBYpUJSFD1VifawokbSSaUj44p0WSHgDwqzba QGMtMgq5TOFF
SAXHwoiB/zFK0MRhKsKYQuMAYmJe4VYpBmOsdZWZALDBahcZLwrZRxElvGQI HyrK6EZRzBEL
qagU4OA8mUUZQXCABKCEMaZUfVyFYpxH48lnUYRQEqFngPFDvWE3WUawkUpM kXTCQRyC5Mga
c9logNl2dcBoV29f5gjp5YMTKRGPVcVZlQIEyzXChZPOHoByXslSBIIk4hZN GUeJD24M9MFM
wZPqxkAprUv+DNA+kVrQVNGecHbIuA47gTCBIhauFQaSXrXDZhhgo+/I9BtB vLYuqOAJMPaI
LpxNQ+CAQTpkG6lIxRjmJwRJcVUywvhJpNKkhNwUyQhDQUY4opCVFogz/Wf2 yEiSYUzScT6U
xopFqmPhjy2kyqUsG61SPflkJ2kSEhfOGo0uNss1mVhwWMEqRICMc05cgZBB KZvj4NQd6xdc
igRetTlBRNbEh/1GgYqAsoPGA6J3eLikZSJnt4STSs4fZwGQS9AgBMiRFuWW 1ThDDvE/ULIe
T5kEBXDC0D91SkkMStDGYVNVjHrFiUQ48q3oV7C8FCU1bYzy2eZnMRZSzCSM lPpIAsIpJqqZ
ton5WKRgawUSbIQpLjg4ckLGXhPIWikaYRkx4mQsYEJQWQEyJoviRPxgauYw PNo0RJVzJrxr
lUFBumcH5YzhIGf1dGYLiMz3j60SKSKByQgATJzIiAjWaMo2z74RUCGaEuxV B4T27fnpj3t2
vZU9e6xYsSIjI8TCAB6ySh3iPJUDaKRooS+1wFJYiczJ4vVClZCwN8Z/j4uo uaQgf2oDTyHn
f1SRZI2cCCYyiS/QKRKOwydfGa3HtkqMTOEJPPvEq41KhDKbI2W2jr2VE0Md LcpF9UtsxhOf
DML5DtavEApEwBEDwKUi9dYFa75cHwGKAwRL+CyLeykYSpGLs0ek5rtWkTlu 2XAboMXYGveJ
Y2LHBUKaNubYa4UAxlY5OJN1bRSQyxRArw2YhXnWWw5PmLY8R4ClBxVziL1E YWtD42RSJiM+
w2sUUQMR34XZUcLCxFk/1LC6KCOCjGaBYpUl9Gxhd0mc559FWtsYTwRCJGIs gyhQpL0wRSWx
mpzHYOxwzGEy/0nJOcWJqO2Vx6zK76WaY0leGEWwEaTySJwgzNlUhIUFll1y FqKUemlpmVID
Yw3RBLmEZIXfDsI6RqLgxxO9QGxLVHM0tQoMwMKNJI2jChJ6orKUBFJuSQ2x 3xjhfNnZkW9t
jZmWKAMks9ZolahyfIaaqvQsVCpHmV+6ljwWhxRZwnv1qtQujbWXMn4xfnIu GXmCEWrxz5wd
d5xr1+gD0hNpcl4VMpEWUWkkyogjD8QLY2K0cIJS/pEUQy4ckEN9IveL3kmU 8ZmQghZ9UiYU
ayesHJpSSWRrIhoduDDIOQpzIeagE7uFIskS8ZyDTuewQWLDQadY4SBWZjBG OJycVdusdQxV
GUKiFWFFmMAyXIBitRVu64spQUJ1oirEfszr1DSwMcxoFbxnhwacXbPuGl1U xh+DPRybYyhI
KrGqTypey0Tm4g1bDIlyaOqREMRAVTwhjUGeXZbKsDqSOGusRF7CSjLUF5sa XpuQePyJLNWl
qTXLyxAjoy2NFSUZaTBSJZAqRUKJCiHyMVNB/xjtOSLUdGYC9oJOwTSuZdEi n7Ag4QSKRICn
WvgcE7hNEY8c3L6MCoV5rUp8kVBCEvFGBdGyA/3hsGrZ2VhBkZG07hCJBYgo MZHsIe/lZBUY
AJUZY8z28CzZ2saaPaTkPLmsnLVAjhxeOAwxJTYqxCpx4/DAL3YNQPFKsSaY IsIADSXxkEh2
UARbamDUDk1VIqlwxVHB/VMcpQLnIFCoGUIJy2TFop4A9vkckdHhCzgRsADB ERoQttcIREJi
9c/SvSwjtWawZOL/9XDt8gm1Alm2qpACnaOpZKAHNbVBHtGh8QABg5hQpZI0 4dSUOSwvSxA+
GzTIge3mn2ZYk5ykgow2AoloppTqpLZGCCOEM1wOODGVUAqG7bKNWVX4KaAe ZCASO/RsiI1n
BMVBJ4HEicSiIoFUmFswMEWBQ7MOAzGrWEIf+eXQT3u/jxU7du8+/SMjaF2P DtEm7JL3uISC
iBRjIf85Y9e2mdcIcBM3EDRWVh0uvaNbwUxp5RgHqSugPyClKqU+paJJCNmr XlBB8wQ3BYoB
/3kaVLrBcEIkdEgaIIuLQLI+JqOssjCAmx3lLNTTwmzCy1jyyVCKQ1JmOYEn R6WItvKV0gGY
rBFqDOCYOGIM9iXSVCqnhsteCZ4UyilYoKLbMQYUUmksSrUSlAHuyTPR02Dw 4oTUqyB9dexK
iSHviHOtJMroVhDU+hSoxdofiCCuVxysVk50xh8r9muXxkMwq4ZEOrxU/O8P ZgS5JyCQ16cf
BeVAzssSExtlUhbiRwNkASpGAXoB+HxiGf6TqvBDbYnFqUwD9YsMKIGGIB6L 3yWFq3lWEdkh
x0tzItb2gUaJ7Y/cRqUyBMkmykmV+FMit36oiYZE7bdLD0ahqnBcFQ7i98nQ gvqsmlSC54FR
CXblCZTFFH5GH7FKcFMrP5DSKlGB4CJip6imWFISrNdpgJ/SXolAhIDML4tQ vsNTFGPt+AIF
UdYI8CFvuI0OuVEZ8YRyhLslcy8jQhIjMikyVrqBemXK4U8FmpQSzWpKdMyn rYbUgApKmdzQ
WTIWwEATU1KjB0uCPO+ALJ+dXAaMtLFG70QotgQZyrMwVe8ZIyGmEGoYhR5n QnmWK5gMJMlA
inxRaRUYMaKRtMo/ZQcTWcWWiRWEUbsIbqBWjsdpcMwgdjsQChuTaqqCLD8R EwmHl89CwgSw
kmcM1lq20j4qVSHqjpcqxjXF+MP2qGuaGnrSZyPoySC5JjqSJZSXY8EiiSNo Tp5sF6qCjDyS
5BFS6T8cLEttBC0xB/6JCCsWLDb8nnSDtlTAOC5JK9L6JC6XUKSYlsZsYJWi 45dQBfK5Mh2N
5BckWCy1NGE115Eax0DBskbDyHoJHB4efvzoL0cP/fzH+XPXr/0d8uQxJCdO kjR9hoxv58xV
uFiJgkWKxY4d28hmG0k0/yOg2iANEmsOvTq2ghwm9J2Ehzl8cBTezJhp+vxl DLVh0X7SYZOb
Fyllf6AR05bd27eeP3fm4YP7yZKnyJnr3QofVStVtoJen+ws6L2y+EGhIhyj TColBQtw3ddf
1W3YjFxDmc+cN0JYglaj1rghYBIJOJSLHUajiBZ1wUGrVyz55+bNtp26JUqc GGqMaFuvItYp
OtxkkTWMOQ23Ni4bO+OtmCGacVZ7kDoKIIMRgjXuKdBjcu3w51WsB7VueSCj XA22thCFBTpZ
EvoqwZbH6IpBJZGInyxIaoX0mQNQK0VhlFqJjGdDjCVuYvLKyMpIHlWRNcbs AAqsF0+Lth5T
sWqQVo+mdOkrU4w2R3NO7eIgMhYnEuKcjVAWre4wiTLL0gMrNCc3AVWMtjA3 YVyZBET5zz/O
p06TeuSoMYWLl3z2PJxJX3LyuL1czKSuFUobjdI4C/jKZV9euXSx0cct38qe IyL8xYH9P8WJ
Hadk6bKGVSVoypIkagFCbbVyRqqdK1RaAUdHK5ach52uHOIyB2ekRM74HXLo SLCwaOqTgIJK
Il2ufMAZZOiJnUWQOEOorEQiTUUtEScAFhbioYI9ESdzWwhl+DC0WvTBvMvE XCdC5dWUlD09
vjKBHRc9C1x3BGps0+B/tXTh5UsXGzf/5K23c4hIPtuqUrcFyn7ev3/vn1u3 UqZKnTJlqlix
Yxll6rOmAdULfjHSKNFYCLmULKuhMYmJgY2QgANZTC2pw44sVeWPkF+Hz01b fypEQ2skUWKF
cifnllkwc4Lti6EDatdrmDf/e9xcVJ7VLQDIihkTDUqMnmYrxmS0oUoR7RNj kYVzZ3Xv3S95
itcZaAW6QgCkNmdxjjUuWaA2oyUo6Ma1qxgkpUn7Bu3s1MORpiBO6aoRHMn2 5JucATKFIwLZ
DWtXh4W9aNysRUA1eiJIni2Bw8jyqfcKnvTw8Be4BBInSZI2bTrsPrMk9hpQ qUa4X64iSXvQ
1b+vbFi76u/Ll6rWrFOhclV11ate04hdM60+zbBlap6mgkTJMYJgAVcFIMqh qXAGno3Z2rID
0U5ZFBppbisRGr891jFHgLUIML08XXT0PJwiT1nY9WtXFy+Y/WkPtOEURGnd chR7WmPMeUBX
FUHlj2IocWRKBnJOyS3EB4UtZIyGhPPCsXnDmhcvwuo3au5ZKwjltwIBFhj5 K84hRI4o6l6M
bcosovhsWFwIR02aLq5pOYCnDCWG1Cil6tB/nidCbig9LjGDwSJfKIxCFEio +8e2iyYhtWc2
QwIndhmMyrXG+rDkhBVBqli2VQCcyYtJSio8hlYSJrASmFBVS0GFqwzB0tn8 QY7HwXbhpNaZ
nLFGZVDKwXYprc0ulTJqqkRWvkssdcooNcCmpFGZhMeKdMGyGMSCCOyi2GJ/ PH3KX13wQgI6
qi+r3uFTmKZMKviXMqhXjqmmTlWwlSYe4SzG+ExSYps6QqwAIFmd0RUogOjM gppcSiRMgFpv
BLH6Q0Ier1+14tsNa/79966ItJpCQkL+uX3r5LEja1cuez1lyup1GtRt1Cxx 4iTETOaTGdi4
wNJEBdmLzQ5Yenj04N7OvT97bZKJhCUI+x2oSPyGmT2qVa0SnqeKNEJTjm2x ZKxRwOxR1O3b
t4YP6vvbr6cIGBSE56a3bt7Af+zdzp0n3+ejJmIYICiSJvGgdTlzWE8thKxi Spdi8fxZjx8/
btayLdwRvThLWxBGPkuWI8BybWMBQsJFMq0vRgHDgoPSpk49e+rEk8ePjJo4 PXWadIASu7UP
RacpSGiIUxRZnDHPyKTE+MxZOYkBZKz+OeKMQiTsDZ8kIo4EJxuTNw7an/X5 Y1CiwfHTz2JK
ghdaYy0vrmot2ECpIEolj7CBT+EC9gDI3bxxA8PF1GnS2sbFUkmZn8vYYhLy nGhw6BVgSoaP
vb17559UqdPABvknFHo2CjEqTpkydYKECQEXu5k46vmzZ7dv38yQKbOBK9ax yxjAAm0j4FKM
pjEGJzEY9vMFKJ6Ys0ERO/5gjqvCFGjpwRjDjVKMBsRtoqpLUiLBwQlJ/G7z pknjR2HzU/4C
BT/8qGrrNm2bNWm48Mul3bp1hfA8efPVq9+oTPkPDRvzyskEna3ymQa0rQe2 o32rJocP/uyw
BjVo8vGgYaMAEbEBMvbu3n7owP5S5cpnzfoWrvbObT5OmDDRL6f/sFJJgytO 8k6rcZEu2FyV
GivvIo0Kat+yyS8H9wvja8mSZcueo3vvzwoVKeYqtWJteMkMrTU4Q//48CcB 5rLtoCBGTpCN
wR/UImTRn0Eykc0j07p5QwRKNMq5Vt0GoyZM9fxSVpfGlyfx5rDGK8BUTwCc DTBWeJRspxFm
7baWixnK5LYcSPAEUo6c3LNr+8Gf92HFOku2t1iFWulEWCIdEfFi8YI5K5Ys un/vXzEmTpw4
9Rs3HziUWpfjPYt2IBx54TBUokM1GVRMCdvrQ/gj5OCl7bFuU8OCdLRozVsu 27Z8KlAABfhY
GHIevdAJW3CXdi337t5hWdGXHTt7EcV8b2ccPWFajTr1kF+5bDHWHXK9m0+e UlhJlkszjHHQ
TlZJ/Gnndi337PJpP3nuMkgkDuR1VBTGMSuWLvqkbYekryXbteO7rh1a/3rh aty4cf2SuORe
ujGgYwZ9v3P7rGmT/rzwO57hxI0Xb/WGLbly54mZVKGInVSDWKhgkxJQD18E goP3/bgnNDS0
QZNmPrgSS2rrEypilO+Qk5ibN64N6t/r8MED8ePHDw19GitW7Dz58q/asEUa vBgDmdLmonf0
qo5VBQXhjbxGtSp36tqzTNm2sePE6d6xNRYyJs6cD0XGZkMIgArVJukYJsSv 8NKlNba5oD07
t/Xs3PbYuSvRKtrKNHZoGan46oqxeY9Kc0A5WeatUvZ9rLZ82rOvsLVr0ejm 9Wtbvjd3ou1b
N8+fNW3Dtj39u3d69ix0+rwlfglWl82whWzUnX9urVr2ZcvWaMOvEdpq1ugD 5rPegVtxgRnT
i1gtzGOqmWhtXffq0jb0acjsL1eKBDCsXLpw+sTRh85cgiF6O2Kb+ESCgoMO 7v/hWWhonQZN
AvVaKZSxSjwqag4kx1yNxhXnHuOROvzciFi9yGR6lGl7tUiSMwl2BVARAEZ6 MpjEuW9YFhM0
SNDW6wgzEXSQBImBEOI4RjiLEmsbEMZhGwBDQlYaYykxB8TQYZLAgg8sdAQS OznHHEzm0Pqy
BimJqQX7EonYKvQaZTFCrTYlx0SyPZhngo7XlszNGNUEshHzXBdK0Dj9B8s2 wXGlK8iVrnnv
1kZ6jDDDYMzmSrIVYyuI6VXMq1Ij1WX0k0sEfTAidjY9eQ1PqIhDjXX4WFAM 0jRKwhIDo5Vh
3bQQzWgQKTVytDbYOu/yUQ4Kn2s4xTE46PvtWxfMmvrv3bsgix07Vqky5YqX KJkpc5akSZPC
8sePHv3915VDB37e/9MP9+7eXbZgzpYNa9t27l6hcjUohQ75xyooPnxIQlb9 c+9xjfLFPANs
ztYojFfgjn3HwIJ7lgIk5fiRGnMYjezLndu3e3T85Oatm/nyF/i0W8/cefLg +3RYuD975sys
aZNPnzrVo0PLyXMWp0mTVpht47QZWztWPlNavLmYY8eKvXXTuqjIyMYft5Yo +iOpxnEKmdy4
rGw2XqIl0okgat7MyR279QYA+X9u3ahYuWq2bNm6d+kwqE/3STPnJ0qcxPCr GJBZNdY+gYlJ
IsrSUIaUBh4GRAj9c0hIh+hhzkePHvTt2uH61b8dkoBsgAZixqL80tWb4sWL 51SvcHkuXLv6
d4aMmYTADaaVjhnozRvX38yQ0UKQcZWFh0f8/ddlaMFmGWMz2e6p8HKuCOQ1 Xj9+vxPDgEsX
L2C4GC9uvMWrNuTMlZvwL+UkQRpTN7gmksoXdfjQgQ1rVh4/8kuK11Ou3rQd AlUnSSAZ7Mnt
Wze7tvv4/v1/Q5+GtmzbsV3nHkJ26eKfwwf2+vvKZSylYaWveu16rTt1E05S wWogAI8TShV8
R8QlS5787Zy5u/Tqjy0/27d8M3xAr1x58n25apNw0Tk4qGG18lf/uvLdj4ex 0gEDZOQrprA9
xiqxTa45qIIisso54uBKMFHiUAEprVNLROvj8BWCJk8YvWvHtvgJE+KDL+dx nDs3c8okiklw
rLjxEkD4+d9+Gz5kQI+HD6rVrOvo5aztC4y1TisWLcbYKH7nMKhI0eKZs2YT IYUKF4lw+xdx
1G8b3gYDDfoRzFIwYKX+iKuKT8YAv28+A9WoQEoTH4Cd6xjhEhOKl/gAq1/o Z7HKO6B31627
96PircaA6HONkHypM4k0ORHgCJG86iD5Yq7VRNYJi3cjdj2SvAS2aLH3s5jA RhUoWFgC6zYA
a2d0I3yWegXVbUywfJaCDXWsVZeJwK/a8prm4nHa9uORuBIhB3Uebd8Nm2Ar oku7Vgf3/5gg
QYIOnbu+mzff3Tt39v2491loiGldKo9UeYpFn/FFSYwH1kNrFDJaFy4sIK8W GXGUyJ+oZrBb
gZZdKYXhv9CknMQoWl2mWMFBefMVGDl2gpDhQo4Ipxt52w6ds+fIgZ4abRU+ ou2b2BqHzQXA
dqoGmwIKMoPzJ5aGM8BhBDBq3EQBk3a+zOkC0QjJMw2cgcqSJWuHTp8Chzye JH+17MtPe/RJ
lCixlapXlgX8hwwmV5/16VauQsVV6zbGjRP3u63fJk6c2DSGl7MigKyIKJxe 4SUMSkqBACNP
74mUyrK6wAgC0WFbFOGdg+IhOBUIJJ7V1K5SHk9pNm/f/U6u3GFhYUd+Ofjj 3j3U+6koqW5h
t8JJsCeRS0x36sSxJ48fN2zycdx48WFdpcpV4KpIIyIcJELFiATHHuAcs21W 6Yk/5gPbXzFY
adLiE0FnzpK1bccuUPQf6yJmcYFQssQx0xhmIVKJhYsWO3nscAS/Nojmdvb0 qSdPHmN71Guv
JQP74YP73y/5AUJRoWJlDDvYMOug0Sdl9ta4LJL5tis3KO6gLJ8/ME5Js5w6 YgMds+2PCFEd
XIkmT7RUQ7HQ7wcHaySJAlc9DviivY3t8ISHzqJUuCiPPzaGcJIVNV5eIyz9 lvADa7jIEnNw
xpYMkOlJiWA5IZiRxlkm9QR51hOVlognQKYFcDwEGWiEZw+rpiJpkn9Gnsdp qOW9c3VcqdRC
077IMBzuSQ2EeD485VKOGaq2eAYKn+W2Yq0UxwHNchvRkzQYQy6htrwqTcWj LFnyK5LDzR5a
ODiVh4SomQxzT15eJRKnsnpYyhmoxbJgOtHBSDWPAUoHjAsHjopqEZHyEZN0 xVHq+etCTV51
MWGANtXuxtdHwgVXgghlME5imM1I2Wvh0RmhUHkDTDU+WqheUASPQY6l44wT MdCj15s2buSu
bd8ClzJVqo5dulWs9FHipEnDXmDUgHe56eulQOV9r3Cd+g1DnjzZvWvHvFkz 7v17d/wXQ/Bq
Ro++gzEyZ53GKBgNDj5zQlWEbinaKM5vlC2hdwK/7aM4AIKkrHXORgAbK8aO GHzz5o0GjZv2
7jcgLCIq9EV420a1F3y19p08BeYtXj55/Ji1q1eO/2LwuKlzKE4Qo8xWmtXC GEuhdIqGP3MX
LunVrTMC06h5K64fg1NS6wfpcSJtdJqK4tKLFy8mjx2OZ2ztuvQA29FfDgzq 061h0xadu/WY
veDLpg3qLls0t12XnkCRDqOHg6tKPPsZW6PCIcX40iu3Gj/zAUzhwtnLCGh0 ywlNVUeBEuya
FUtu37zRu99nWHwxzDEknqTwiBdjR33RtFmLOHFi603Kw1rWBXOm5X+vEDYp Fy+Q0wKRaYUX
Tnr3R2b91yu3bt6QJGlSrFAMGjYaj4ExFtr27SZY17J1R34qGTV90ti3c+aE pQd//qlOfayq
c9QdcXAEuuXsgE1E8chh2IA+pctVWL56XZy4cXd8t8UMFyUCLoPXcBjKkZPw sW+eg1wbZMgf
v51JmyZt3vwFMLLlhg1GQXrEAHXv2KrY+yUHDRt568aNujUqZcicpWLl6oCH PQ9t0LhZ7XqN
cBkunDtz9rRJ+QoWfq+wbxUPguSrCO07dytSrPgvBw+sXL54aP+eKzdtlyHB uTOnb1y/mvaN
9KLywh/nsO4A4TAPI3AA0QRMcJjCNFHJE53NuR1f0KnjR7HrggGQAwAAIABJ REFUQRYIKVQQ
IQlltApsSnKcAzQnjh3ZtX1b3PgJ8DTMa4TGECJFn4HWU6hwoWrVq6siR4Rk mZMMNFYrAeSo
PQKqU79R9dpm/QLDwRe69MCus4fKKikiDrJ4ceP26j8Y6OcvXrAWe0UIlXXU z8wlI1TY/OTG
OgqUj7FR0+aVPqqGR+5tWzbFNODGjevp0r/pUTC1cKDZIcMqPAV+YcQXHQIg GAw8KmCs49WD
UcpzG8qzJgFKs0deLpB6DRvXrFNfUBGRES9e6JdHfb4pP6dWKnEpWaCpChfJ RKg5laVlTaUy
iEz/FBPgFwmQ61YJOFWQyJHZqY/AFlj+oQP7sO6AtaH5S74qUKgIbpUYkzdq 2iLsRZjp8tRQ
2zaN91aOkxHvWLBkBUccXJZgo8QyVLL1VHgMmBL3jy4OQclow8gED8EpgRIh AOplB6kQNUoh
JbnqBYbQYZd+5re83hzDC6C69er/Ao2DBgGkBx0WZlvI2LmysDNE7zkW5GaM lVpVLorzWKDN
mt3Trvcej06WHsLRoUREZH0re89+A8Ne0Mzvr78uL100v037LvHjJ/ConVw0 lTEEDJsdHj18
2Lxl6+DYccMjg6pUr61Dn0BiDiZdB4RAwZPOGAE62ilrAuOJQuRxBDQ2jrDU TGB9BcjjIum2
8Pmzp4e/eLFi9frXkqcIefoMiEJF3y9avCRCJBcFKOW6JNWWTYEGwBjBXvzj fPwECYJjxUaM
ga1SozbOL7jqLbfbfiwwpgzMcXXGRKKwn/buwoJ9Q7yKwkeWbNm79/nseZjM 8JXo/5RSsLzK
IhFee9VASqzeK1Rk29bNYc+fYyfUxT//eBr6FMRnTp0oXqIUMtiI12fA56i7 SlVroOjGRMWw
bPJZvdY6wJUEHHhxIGMqUKkIwkcAwBGrFDYlUq1Q1WIq2tam0jBeWx23XTz1 Bj8uagmOCY9f
n3DFfB9nQ1m8GMRlybIQFsg5MsYvlwwnUofHybIQ6wFKVFkkQIT4KRlHukxG /BB6EuQptjkV
oKljh6dB9BOJlyN5dDBUsnRWlZQlfVoXloKlmpNoMJSWwjMFIF/BkhiEXnhs FSNFnTCJEtVh
eKUtstHWF2LifwQxBiNnOJGIPAGYvGuKIaVbkb1PMT5QN/GqYMbpXe0lupTf S7liXd1AeTc+
a5vNWAUuD2M1doTwyFEwylQnM9qCUEolM0ZOjPfamSNRiaw6yuAwKq1mAFhq gCalUzGKptSl
V7gj2rB4GqxrKoxST5CIi+aaQ0yipNGoqHHDB+7b+z3ATZq16Nila6y48UOf vQi9/+Sf2zcv
XvgDO0nBgsfXWd96O3WaN2LHilW5ak2sTcyfM3P1V8t3b9vyPDR04LAx5pph RYiOapAyAHg4
+t8eGBOAlPoo4zYSGxpv0GpBGP5hFpM3X/7uvfo+eBLK1wEERIXjbvci/Glw UNde/fD0FM8R
D+z7sXjJ0rbeQGQjxQYTl6gyzcAYEDx/1pR38xYoUbocmRQn3pBhI1u3bFqk eInMWXlDLjHD
HLRhZ0eMqLFNRn2wjTk05OmY4QOPHaHFAtxBwF/8/ZJ9+g+cOG50/PjxWrXt 2OnT7vNmz6hS
sx5mH8YQSdRWMNrAWNjNm43SpfvaPYMqflRUfKIOPCJ+vWQjEIgTXRzl52HP dmzd/Enb9tVq
1sFkRSmNUVpEalFBt2/dQPndfPllhMk0gdf91m82YAdi+07dsI5z5gLvp4iK ehH+om71yh+U
Ko2YYJ1r3swp2/f+nCBRIhAvWTgHI/wFs6dNnb3g0p8XVq9Y3G/wcOz4/vfu nZ59P4OKrh1b
p079xvsflHItc/xgK6KdIOrRo4dNPm4ZGStOWHhkxSo1YA/d0/kq91yyjNYP xnknJSCNrBUC
mrVqi/kIfiny+tWXLj38evL4xQu/L1z29aMnT5MkS9GwcTO891T+wypgf+vt d3K8k+vx01CI
bNCkBbZmnD5+NP97hTnSpBl/UBUZRZdMmjfS5S1QtEDhYgjIxnVfP7h3D+Ne vNH8NOTJD7u2
N2jWEjQ49u7clvaNdNhngaECptfUZxlJ3uVgWwV7x2wySWC/uBx07MhBd9cD AWExEVDg5B/y
tmUaAklwPvDTD1jpwbAsVmxn6YHQdIAPfQ06joGDhmBIIx4Kyp7ttYQMDLVG WwI2BpIoDY8I
fxrKC3DiA3uGBVTsjsamlAf376V/M2PnHn1Klior9LToGhnx5MmTdi0bJ0iY YPFX6yF/1LBB
v54+2XfAkO1bv/1hz67kyVP06PMZsbDKtatWYAv0qZPHkyVL/mHlKphuiSU/ 7t29cM5M7Mx5
M0OmTt16YUcZ4MIiuqjIRmKI/zgk9J1382GfM7Q/DQnBTIYMSJBg8IjRE0aN wAdgJk6fi9a5
fPECXJO3bl5PnyETXnPAKyTySnZkZPjqFcu2bt547e+/Urz+etkKlbr3GQD5 P+3dvWjeLLYh
Y6euvUuWLkvxiorCm12bN6w7fGg/1pnTvZlhwbLVvEkp6MTRI99sWPPLwZ8j wsMBX7hsdXxs
XjLNwSRStRg0m8CSt+QHRenUyV79B+34jqK0efsPFy9eWLNy+bmzZx4+vF+0 WIl6jZsV5PUz
XOFtP26YOm1aLDROHPMFLoOSpcsNGTF284a1Xy1dFD9B/Pade5QuW4FiFRz0 055dWH4zYeza
64My5UKfPm3XshGiOm7KLJAc2P/jzCnjy5Sr2L5Ld5iB16Hx6ZDRE6cDhfed sEKJ+8SzZ8/e
zvFO5+696VsDQUEwQMM7ZsLo4Vh0nDhjPrVdugNRLwCThg7o06hZi5p1GkiV ASXHmpXLkKla
rUbuvAVCQ58bqG2FUfhm6gH0VpiOJk36Gu4W3Xp9loLezY7CnvwFc2ZgvSZh 4sQrly7CCnTr
9p0rV60xftSwn37Yg7VYzIdlyWn08MGIZO/PBu/ctuXH73clS5ECr+GUKFUW urgNzMe27Vs3
0AYy1qQ20AIPJBGp+//e/WrZIsxtrv791xvp0mPtDLtpAMf9cO6MKbt3bHv0 8EHeAgUHDx8t
byF+v3PbgjnT0VTSv5lh6cK5rdp1smtJxilprew/nTQQmhKV5OV70lh8sTSE w4pM7Src8svL
Vcrreuizou78cxut5fjRw/B3wJAvMFvzNzHi9h3mzmyofCiIo9YX9eIFzXLd A1qGDe5/+uRx
bM8R16LQ3CPCD/x8YOLoESs3bMFa7NABtDG+RZO6cWLHXr3xO2w+ciXY/KvN S5cuPRZS9+ze
lT1HLrDIsgvxBgfd/eefEZ8PQFdDng4dWbBQEYBRQUsWzj15/Njjx4+wVwKX Klog4FMmjMaU
FS1h7qxp9RthBb/1w/v3J40fefjQQWxAxQ7AL1esSZrsNfI3KgqL8dMnj0dX gFb6SbtOpMw7
pC175Vfk0Nw3rl1dv1GTREle82Iok1uq36j7/94bN2oYWjV6p/c/KI1miYaN esfWvkljRsz5
8quJY0YcPXSgWMlSPfoNev3117d8s2HuzKl4XbBBzUpWb7ESpXr0HYgiLq9Z UydiYx5uAbhN
onlXrlajRp0GQI0eNjB16rTtP+3OZFHN6lUDCxhhRLP61Tt82gOrfru2bVmx bguitHzxfOyt
QABx4Xft2Q89JD6XtWvbVlxWjWpWLlzs/V6fDQH9lLEjl63dDF2QiX5g5uRx WA7AjRCvR6Hz
BBDHjMljw56HVahcBa+8YuW3fpPmLVp3EBTOWvWaWoRibIqGCGS+AgXh+9kz p/LkK/DrqePY
HXbutzNnfz1dpFhJ3H3xLCU/7xGbOn7U87DnfQYMBcuMSWPDwp5XqFR11tQJ MACGtWzTQa4s
7OwdOfSzX0+ewN497H4EMS3lce3E6M7A3l3fK1y0Prt2+MD+aRNGDx09ATsh wfjlvFlx4sZx
XQOQe25KcaBRcUIXMeX4z57kMkP1CRW8xjgDVIAILx4offfNBgDrNWrWql1n EcBN1SxYzJoy
AW4WKlp88bxZCEX5ih917ztI3oVhmaSKomwbsg05of3jL1aJk1KzmVT07FV/ hMj0IExPNEzI
Ulkl+m8ZTnBie3MipMOaJEX3zMJcgOQdOyRyGlMWxViPCTBodyXRBSxlT7XP Kh77eBKMUlM3
gXBbFqtEsEfr5ZhQ9WhqAmmopJWIffbMOLXYaDP0ZgRpJsmKMyEVxzn2BhPg l2swKCgYSqGp
ATM/yJnEhUnleWFkQqPf5E1ATIlwtrloQ0EQLLHmADAKY9DB0YumVWQomFMt WO1OxlySpMeL
LqvnIrHaWvLYrKliFhEp0gmaAwXW8UloLcDwcuKdhEgC5ROqmpzUNR607Tp0 xnzms8FDy5T7
8GFI6Iunj7dt3rj1m/UY4zlM5HCmzFmr1Kj7UfVaGJ12ocFbgXGjRrTriC0A vNOKqcVOLzoC
jGnpwXokWmxM0J0iztKpGpF2uktEXLDUQUHHefaOHa+Pnj6n/o1I6BpBxyyS H4c879D50087
tj1x5CBW8AnoWyJwg22NchQEBdVv1LhbxzYYi0IwlmPGjhgya96izNmyY6Oc qKCzYfUlbIyV
SVRSOZgcjhrSHwNjBtEwct/e3RgH1qxbH/fQ+XNmfVCmQqUq1WZOxbTo4EfV 6xAZDhNWn0DB
MJKyWHcIOKP4MIZWScSRJ/+g5D8deHTx8MGDwkWKP3gUYhxgS347c3rX9i0y tYEMt92dPXsG
dZAyVZr79+7h1fUArCj87tuNvfsPCnvxAsWQUFNZK5YszJrtLdw0seMG90d8 ZGTXzh24N2Ez
foH3CqFO8XIBL2fQQPru3TsY289dtOzZ8zAIadysxdbNm4q8X0Lk42wjJdXp q1QhCkbE0seO
HeeHPd9n4adlNFxktj07d2B1Y/4yxJPK0yeOweSuK00ngzEwwK0TVs2ZPgm3 TtxhP27dnuRJ
86OMUR3KjVBaDjVprUFs5cDYaeqcxaDFExp80DBOvPg0HMb2ogKFFs6bde/+ v68lTRYeFB6F
8HCjxlWB7f8JEyXEyoh1hDPYwUq3fsh/jjH/iyDMIFBEoNBgMZTN/17BH7/f Ua+x+cDT9zu/
q/hRNcSZrhDM6qXarERwUlVygoxJTc7ryoKC/rp0iZYexCO57CTcehGaSxES BE4ZR8C5335D
3PHQGGF1mw6T4aWvIMx106VNHT/Ra/LEzFoiGbJMOnXu9cRiazfRaKxF/51/ /rly+RLAGOJg
PoYMdkd/0rQ+6i9Tpsyt23XCZ9XCwxAyCiUO2hGC2UlEOKaO+NYDChB+4/q1 P//4ffzoEcDG
ixcfLP16dt297xfkd27bOn708Jzv5BoweCheEAqizd7oHYL3/bCnb4/OaNOd u/b8avniPt06
bdiy8w3dy6ARI4WslNRu/XYT1OFd6zczZsQFgNkvOty+3Tq/ePEcc0hU2riR n2NynjFT5g5d
uq1asXTyuJHwoksPmjtNGDV847rVMBhTCFAiSjjv/3FP/55d2IYeK5ct6du9 09rNO7CggA3A
eAUavVjPfgOwnQmLJtQkaM3vcfdOrQHHLjLMwU6eOE79MUfGaxBkrthMgWJH uBjFUbrw+6Sx
I7HZBm0xIiri/G9nHj2437R5C7yaPn3KBIR01cbvIACbo5DHukCvLu1Tp0mD aRWWGEMePz5x
/Ejq1GnwoWMs+tIqSVAQwtivRye40IXDCBfWbdkF4TAPn/O5d+/f5MmS4ysD 6J0xG2nTEbvo
g7Zt2VSmbHkYjhWK1s3q4yX/suU/xNbrlcuXtG/ZeN6SVZgSoH5NeLt3ehEW hvDCF2mvqAks
2uG1tyRJk1SvWQdyINM98C1SFEuULosFI2TcyCAQ2FCN2MaLH7/lJ21PnTzx 7cZ1p08cW7Hu
W+yjwdtr8Prbb9bfvnkz/ZtvohVhzobdVnfv3Ib2H77fib3ueO0KMm9cuwrz Jo35Aq0CoqDx
s15dd/xE7W3sF2gDa2wbmDJu1O1bt7r06AOuMSOGYKWpZp16ePyO5R60W/SY OA8f1H/71m8q
V6mWKUvWL+fPQQwXfbUOZmMlAq06IjwcM2HEJ2H8BMhDjntw/Uoj9S5nS2Aq HmW6+Gleb1GS
Qb08efyIYgg78KtXWCGLCEcH1Llti1y5cn+1ZuPGtV/3+rT9t7v2JeJP3fii aWPrhdjLQT4K
Yh5UP3/+/NbNm6IU757hwgGwU9sWiRImmjN/MRa2x44aASwaMzpbtPM/L/yB do5b78etWmM0
07f/ILw/Ty5Eq26RaRRb/SYuggxKlCRprTr15syYgh6gZ9+B2AAiCFwhHT5p 9k7ud1eu3bR+
7dc9O7fb+v3+hAkTYhyQKlXqMRMmYcbbvnULTFarVK8FFnyy9Myvp86cPtWR XuTJH/4irG2r
JlgmGzV2YoaMGc+f+w1TaFgIO/FK3qhhg5t+3BKLp9MmjvuwUtU3M2SwAWPt oDLmxZyoL9ev
X8UbFvgylm9YY3joZtH+k6ZovaPHT0aQZ0yd1L1jG6xUAv/0yWPUL1o7XjEY 8Pnw0SM+37Ix
Z/NWbfEs5e9Lf65csXTIcP70SVTQjKkT8U4pXWJBQbOmTdy0dnWX7r2wioFL 8ujhg3hoQKjg
YEQPRqHHARmaCjeex1IjyOPumztP3i/GTsTCx4Ub51KlSjVy7ERY3rltK6wn YgmvXIUPMSjE
1L3/4GFJkyYD49MnT7DQgFaNGw2aeufWzWvWqQur9v+0d/a0iXhCxfsjou7c vnX+t7NHfzmI
NQe8GYEZcoWKVWQRkMKApsuHBkxKLz2/mTEzXrM8dexI7nfznjl1Erdh3Hrw NTIMl48ePpDr
3TzxEySEbeiXsPFSvEMeXSXWkpo0a4nXL7GQimEgbhaowm4dWuHeP3MerVRO GDMSWnHXB9fL
3EmXPj2WFOs2bArKvbu2w318S+jtnO+guGXTugGffyG1INZzA6GTNhWvzQjE llHEP3wEBA1P
L7ugu/yeNozBrXjh3Ol4f3X0hCkPHz4YOrAfnlh+UKY8aWFOUXr3n1vnzv76 5+/nWnzS5rcz
v65ZtQLfNqpVrxGT0YkOirL7JBDmafztLk1rAdPajkDHJGy165YRIfMkUsKO U4ZEA8wDETrx
PyoKgkhwGHJjFnEIxBgGAtbGtB5MOHU4IgFlEkci+EgXJwAbZi/sSm+lCoCK 2iyVRFKuJz/I
lthoJTB2KdKaZz1nlaJXvFNO4634zCjrvkpRUtYI71xl6orKl2CbiFNC/+wR IJowBiscVHbI
LVYEKEopxB6D43oFxgJtxjHBwxPWUHiEIkrPqsZ4oEVFUxodxVQBpI4eVuuW nTwLDmAlmJBE
R9iQaQxtypKU0RNhwJzEZLnYLk1G8srBZmtBUwCJKk26Nzdu2REUO86/Dx6f OX0CHTsemAkN
bty40yF/7epV3G6whW3ejElbv1nXqXufPPneK1ai9KYt28Mig8PCeKQBYV7L MnERH3lV1ED8
idriOCudMI1eyDohpxwOSkzWpkFYRwZZ5mxvEaMxgBJ0zFimYJbITFmz4yo+ ++spjAFYorFC
xGsB0p2sKkSaImUavGfRsU0rvLc4bEDvMROmvJUj19NnNN3F5QceMcpeHQRX WV5ImKx2pdKC
9c4YiUVEnD5+ZM/uneOmzsIjzKVfLjz0809YjsfY+I9zZytWqekRG4UuIDDv bnmQfDLtCQJI
I47z2kcA1F+Ea7gjw8fXU6Whm4texBgqTBg17OnTp3j6+F6homDCtAIjXizK v5Pr3bv/3Mak
Mk7c+J91aV8Ri1X1GnpSIQENAjsdfj2VMnVaqW7B4s67dNE8DESfh9F6BB6u jBo/qW+PT3Hz
SpQoER77Yps8xmYzpkzAfa1u/UajcW8bOCQoFg3DQJ8qzRu/njrhCpTgc+1w QwCRc+FIZWN8
WKN2nQWzp2ODe5defenjqby6FfLk4ZXLf9obNGzDFBlmQwY+83T+3Nljhw81 boYPNNzD6AXL
EDSdlFuFW+WglipDg9QBOfB4CyP3u3l4coodItfxohPGP8KXhIe+t29cT5Sd HoARkA3FMOn5
82d4ZAKTpFkDKw0PrZooI82A+dtvNmByjYE3wgyLYNuwgX3x5A8f4L/w+zk8 P8MjWCw9wBdm
NFUqorzrChL50ArXsqb4kL954YLM07YvKSAmFGy68cAkRsCDRw+DadkhNj4C b1uV4OLFjo35
HkbAyV9PiX5HNaq7/jLsg+mQoDXsoZGDPdL40WjwH5Cs2bIv/XojiNet/orW HTJn3rh1NyIB
S6ARz/DVcmqkGHGLOBBwgMif3LnfHT1+EoaAdWt8dOXy5RPHj+JDEjdvXgMK MzeM/tFvQjP2
94Iaz7cB7ztgMK96RmFTE3bhtmzDK1UgYgtBIEZuWv/1lwvm/HH+N0CwuAug tD8MrLGU0KpN
e8whL/z5J+axIFi0bFXy11N9ULpc/Zofff3V0sbNW+FqhASgvly+Gj9HRGKD orAst3Au2dCn
/2BUPGROHj96x3ebP27dAZ/2wUWL7waXLlsx7RtvNGzSPPTZc2jEZhCBlylf MW1awD8WOIRQ
rLlORTjOE8Z+MXPaRGTwSs+8xSsIyc7gCf/q9ZvixU+APRENGzdt1rwlTYBj BWEfBNYy/vz9
fLbsb6PBghwX86BhX1T6qComUWtWr8QoeevOHzAxe79Q3j9+P4+ViISJEy2c Q5sXsN8EYYRT
k8aNxiwaD+7wnhJmC0cO/Vy+YpVD+3/Ceg3mz6hWXCp4lF28ZCk08fVrvsLV i++YTp4xFzt9
IHnurOnzZ02dMnuRDW8DCm8HTEfhqTQAMGI+f+fObQz3sQ4K7e4BGrxDBUjK lGlEiMFqfObN
mAIa7MRr1KwllnXqVq+IwfqWTevRv8v+ZPwI08atO/Dt2dLFCiICGTNlnL94 2e6d23p364Ln
824vliv3u5hoYSmxQa2qf125fOLYUcwrvt24FhoXog2kSPlB6bL1a1ZZgzbQ rBU2KOIBOFBF
ipWoWKUauku86YB5/vW//0bEsAw8cvwUXHXYLYb9FFcu/pkxSxa+PWP+cGf1 hm9z5HwH7Tba
Yp+tVeMltQEZKNvmwK0CNX/08C/lS9COEhxjJs7AY2fpUxANuiVzgXueiB/3 7MZiClaO4QI2
qqxYtuTAvh/KVeAn5Hyx8YkFeTkuBowyGQb9UIHgVClv1p6nz12E5oFfqMF8 ddW6TW+/kxtd
xdARo5o1rIu+GP9p4RRTuPAILOXg5Qvk33k3D/pNmfSKpoCzGMLeB2DMZfH5 iDGYrM6ePgUR
Hj9tdg6+DNHmscA0f/EKeNoRni5d/PNPe8t9WBlPbwoWLARbEBV8gAaTQzxw YLn0beFZ8xcl
fS05gvb9zh2YYQ4bObZQkeKRQZFp07+J5kGtLioKS/sr127MkDEz+q45M6dB AhoYS7Ah44oR
Y52sZ70SYgsigKlSpoZkPyGVUFmwYfnq9bnz5Ie1cePG69yuFW6B2IiIsIMA ay54ORDXFz7f
g50R+M4CJt7Yk4U+nli4nSRPnhwZGI+V+7Url6NPw7I9XOk3cOgP3++i25F0 syyQb0609AAW
eGqteued3CPGTIS/iFue/NgaUhCdNmq2YOHC6Ac+rFwVowrcULFhLde7+aXV SQuHBPTyy7+c
B+yQEWOwYtgiew5cUEsXzqnfuCn5EBV0//79ZavWYxsRjJw/e8bhQz/LFgOy gZuuRssCOIOT
P2QAQMJ7BQthFbVhs5a/nj7RvVd/fHxk3dcrYQZWN4oUex8eMDNxgpglRz2A AathQCZjwMH9
1WvXx6uk6BVXfL0xe076BtXgYSNbNKmH+OAQdwazOx+rO/UaN4X81SuWYrkK n3rFdrCyFSqi
spp83BpyMGQpUBAviFFg2WoON/vPJzaKLibOOHdtA4rCmPtUm2bm7UUQwRDQ ovLQR61duRQL
oLnzvYebOrb24AfnSpQqAyzfh6UHILVYHJ+5YHGsWHEqVql+7drVo78gzuat PVFP0bCx5oyW
zJ1eimywGCp87BEbSifSyiSkUzd4kmQ7qnHGg5QlBI8o8A16VaSKRYGK4xJz e+pNThLPQDKD
yOnE5jAvn9hEUxS91mtQu7Z7PE5gojdJJXNUKkhSg0BBbPLKHp3xmL0jqI2A JfbCShG2jrFI
125yXbCC8ghsDah4iTefKfL6R/pZAomSgrWC7GI5krFmEhlVJqcvPxljXk7w KgnWCMMOYZ4+
tscgyA4PE6DMQzjxCKDhonUeJcpzSIwDkniiYuI3MCdar6JinHhk26ArAXmq H/eQMjvrw1hD
jbHKA6KnzyLDYsWKjAr7fsd3GC9hzIaxWas27cqV/zBrtqzWycuXL/+w9/vF C+djYWLEwD7t
u/bCgixuK7jXuCawfLKWgWQOGiZ1TQGK1YDoKcYEYEGnyiKIzas5yam+5V/O x0My3KMxa2hS
r2a5CpXbdu4mBmDLxsLZ07GPT97cjB2Mp2Ox8RUwHlQYU7j6IEuuHOOo3x4T w2cREQmTJMfj
zF7du2D8/1bO3E+wB140gYEyRiblHFeFxOLUcL8Svu/06j8AuwKx4oAH4O+8 k+vvK5cw/c72
1lsYsVAo3MORb8FWBSDRNz68bNdDxOEzLzMJckQmCPC8Ck0CXTFPxIgDj1Fn TB4ns0LUQrJk
KXZt34rR1OdfjM6ZKw/u6biBJkmSBMMjNKdN61fL7VtbJCRE4ZuOsYJjybo/ BApq+qQxGL+k
TPOGjDoAx2YHPInEkwBsHr967RqeTtVt0PTqX5fxaOq7LZvxAwjnz53fv++n mnUbYskAw3hs
Y8S8Cb+rSo2HHLCBMVeK25YEiWYwcOhIzNXnzZqOIRO+0C+7ZaUe4QI5TAdE YenBDJ7xkGnp
ynXpMmSKDA9fMGfmkUMHqtaqAxKjz2aYk+/yfNtVNDYbFitRMhSrV1FRmADC YMwOmDZIWiye
h2Wi13kMA74BMWnUMOxhx5hEbFCriElayOlTxy9fvojXDP3EAAAgAElEQVSq wVc5sCsfAxvM
nYEt8v4HeLNh395dNeo1wvaHsh9WxBCIuGAWXWUkSf+Q5UOla+qHcgkP+PkX LoyrZCi3TDoR
jP/Ztipo4w3zY2+4+Yeq0aaBSRoWHV5L+hpMw4X9NOQpKkCU89lnjylolRop DBUUKyW78Ifr
9v0SH8AoDMU4gkF/XqCFt5KlyjwJeSqdDLhUGHxBeHCIySiwGVyqXKX64yeh MBkTByw9oO4L
FS6Kr4UtWThv5/bvMK/GHum6DZtgGoyKQUOHllUrlq39etW/d+4gjyG+bFNB HvIkUmIkZtFo
6GXKVajboFGx90s9w/d2eNKLyw+7qe8/fAwWPAZH08T0JkGiJJjVp033Ji4G 7Be49Ocf2MUA
FLYPZMyaLeRpqJgOGy7TE6qgVSuXrV2zCg2LbLhxHXWPdeUCBQthv3e96h9+ +FG1j1u1wz4L
BCFDhkw8aD5Wu+qHmL5iG3fAV145olLdQVhCw0+BQCamtdIQRW/LNu2ev4h8 FhYCFH4CcN+P
3/380w9YALv4JxnzLPQpDJA4wBe8VfH4SYjs/4fvwbHj4NrA9YxtJhjOxg6L 6w/jP+QCwhgZ
ib1YeEX/yKGDGTNl+eef26jlJYvmHzt8EIvECRIkzJO3AJRgmQP0+Qq89/gJ KjoIz3Vx/uP3
c7Z+EV78lObDx09scwUBtiHgdQbsVXktRSrxC0D3QNjRzWEcb7HaiunSwr4G EL+TO5+8M48Z
EpYesM8NxDIRqlqtZvyESaAU6whYemjeqs2DR0+wlgQunlVJs6dYVvyo6qPH IfIrMJgp4ZtA
ud7Na9tASGhoqjfS4wkw9std/PP3/AWL1KhVd9L5UUM+671m9VdNW7QuXrIU hMBfnHF9YSkX
dmITEIq0LSVDRmnkmPOny5iZNrbhoMtAqpFKNiw2Q9CYDlj1bp68w0aNFe7k KVPxhYM2xdeT
ruDwKmkkWiye3g/oQx86woH9T3hPzwTTXodAyMXMNCiYEolklDGTTMOlVLT4 +wsWLxfaZ89x
+UQg5tCSIXNWNELAZYMcVT0qgvtH0GALHSaywGI9EWSOQpMVVSLWKJRCtHNI aPgnbTsVL16i
X69u7Vs0njJ7IRrepQu/w4Z+vc0nguHpLfIUc+fgq7f+3rN7xz+3bl7880I+ 3DL5Zk9hzJs3
XoJEz3jhVRp/0eIlnoeFudEAWcHCRVKnTY/1MhiCWyC+1ACpxijHDc9Ma300 bDL+/CE2EMEG
prKkxI3lG6yoYrmQbAgKwtZ99Lfoi/K9V1DCWK1W3RB+ow1NEZ0MXd2YjnK3 KU8SUDtcSXQj
vHb1Lzzqxy6PUDgYFcRbH6kjBJc4CFLpHFBRUEdrwBBFFkVhl0RISChyOMKD Iq/+/Tde1sBq
Iy6vvPlpzAHFaNI4sAmQvcTAhYQAFRwR6/LFC9g/+YQlYI8gNkps3rgeG6+w UAIW9HsYf/ji
SYsC/mD5S2wIt0aT8xJc9VhKfvT4IXrgnHjUEBkJRbdu3Tx6+BA+7ETOgo/j YvPvFSqcMk06
z4BwasMXL1AbfjNTFgl+KG/yRETAJe6EhDxFbFAx1p08+d9DBeFjbHgPE0qa NG/Zs0t77Aj7
+Yc9WKlEeDBqEEOlrjm0Yg6DGUpXFJVswoWoqMJFi89dtFxwiM2KpYumThqH 8OLTnlizRjx3
79wOUmzaSpPWPFyi+tDNRMi8kT493m6NiqR2i0dV+NUb7Gd1f4mWNEncNdp2 kEBgAVq7xFri
YaOggAJLaM4ynGDUfxArn61AlkclTGV4yUEARAVieX5JvBwHRxWBiIBS74Ae sY5AhCa8oTEG
W2LPOnGJDNAeDizGBeW2bE7GUwWgFFiXUehQqhRPJyGJLgZakiXS1Bz1hOkt l2uhAo04LpLz
otAWSWv0g9SRKoo5H1i6AhWyODMvpX4hVCISPtGZM5K+/KzCXk5BGJZqSTQY BAisQ0sULcM+
EdRl91EZo32wgAJ4fRqp4ITBhzNVZiVIS/Qp4YLfOUsuGaIwBJ4uj0bC7dEo hmuKTuKsVQpb
uZ74pMTEzsa+4BtEtmxZwVjig1KDh45IkvQ1jP1u3blvm02y11M1btaiRs1a I4cPPX7s6FvZ
sqI/x9eaIMQKNRk22HWA7hr/9cF3K5Itko0LVhyXBdi+Y+frf185sH8fKHPk yNm1Z88nobIT
IWj5um8njhrepFblURNn4C754OFDdOB4sAfhpq7UaKTqowNSayXOUHfq7K+T xwzHzRdfrIyf
KAlejCVq5aCckaucAiLhLp0Y7tFIDlZh2IkFlATx4+EujJiiCmEwbruwje5K wsfqPJ2eGA8W
fcsDqF626yHyEDaMOIejxYHiA8Z0YHDGwGC8wY1fYO3Zp1+p0mV7du38xx+/ Y3c2fgll5twF
ad7I8JRHQbSJHstSWJfCO/uxY6sLnvsg4Bd+RSYEB+P1DcwgBg8bZd8zxULA 3t07l3+98fnz
0P69ug3o/en8pV9jayJmW7+f/w3vMpcpXwE/SIlPy2NrZO8Bn8u7G9DstTcE hnWKYsnSmXNc
NShEYSGpRZsOGNoN7NuzS9sW46fNxX4TaRWoGrlGqH7p1hkJXmTeK4gRAoYo z9AvJEqcGI/L
UV/SHkxleHVimoISEIIedD0j1SgkTpIUGxgJywe22COlhRuCAB+MAXm/bh3w iAgrLM/CwsV+
tYqkkVVBQfiaSaYsWUuVKY+HT8lTpsGTSxpg4OMkceNh0o03eqrVboDd3H0H fC7xQaVwxvYl
oKXIcGw4bwAM9QCUg9wPypSNg9GP1+z1EhAIVOs/phcoc4pXxYsXP3b8RIKE ifFeDdZCcMSP
Fz9hokREzfMUtJt///33t19Pv5M7D+mUw1pHkfHB7LXq+gAqqWb8Wg+2LnMx CnUFTkwycMbj
O1xnIglnNHRhwOwIdY//ogNZiBUn8FRYIgibgcV4Dhdq2nTpN3y7bfyYUXu/ 3zV7+mQ8xJvz
5XJMA6QZ4fUBzMyzZMlapFixTFmyCbtIFvPkPPDzERUqVoJWPHl++uwZ9FkD 7IcqoA6MWEDh
Z30gCEqYICGWHrAzQlBYu5JZFsmHBCxBsfTUqVK/liw52VC0GN6dgw34P3vB kuWLFy5bsgiL
uNigO3/JyixZskEpnkUv/XLB0sULt2zagK8DLFy6MnOWbMZgSUQ6Ph1XrWZV 3iWOSpMxsQQQ
NmCHs9QS3l3ftH7Nu3nyYWaIsTcmyTz1QwOU8GJrxnMEX6YZNAtE3FQ+U6oL qVO/lhwuZME2
E7R1XI6oU3TK6CmwOJIhQ8ZadRpg6QEvP2Pyg2+uUnVH0jtaEIbP3UnY8eMp KGKSiQAAS3po
yxZfjtJmOVy8dSVo9VfLKnxUHdMSIXPPmTNnxdIDuq2i738AODUhaUb8shNd 4XztUd+H+krA
SumNHuoUAQmPRHgoPlI7+FoErdyYeSN3+tp00a+R5WiApr09Q02TTLQB3isF Dcgjqti3Dxm1
6jdGcKaMH42vyAw4ebxD1554aVxuqGjembNkAS9qGS0d61ygl7DDsLDnNDmn RhPjIddzjCjr
OS3tJcBkWGJBFzJfOGCC1xIK9hjaqAEiyPi0qvQ5TZu3zJg5i9SRCaTG09EJ q32H2sopLMSv
eWOBSaGwC1/3oJ1sQeab/OIsvLaOI4PAmtkpwx0VyJIslueAPROsJgIJ6dPw Z9gVuXLdN3Wq
V8IGJSx1QSo8bdykOXUvQUHYAYQvCaOF/LB75xdDBzZo1BTvJlz4/TyMByXJ oQ4wSu+4tLRM
/WMs+8Vm0oWDyehRs2155mKhMltrzGfqGM1nDMuiXUvIYMksxh8zRpPDb4XS SixNxamfhEFy
EUlI8SACK9yQANtxFkdkVUvyhME8jtcX8NCblLq/dkF1h8ZCwuEXDpVA0qAC rUViTb2DXra4
n40eNqheQwSwBObnqABqbyyBuDiPSIgZJASNPCwMTRQZqdS4cbBDDX04XTgw Aa0UyzeA4ODW
RHpteAUuoTV5m/gagoHiC2F4VXXHls34yEj8+Anxu1mIG960RO+EH5cVB+Ep HLZ5mIioCj/Z
E0moZ6HPMMiAGUJGxvNKCopwh3o2aTZYv4tDVYAbAT7tiYUP7HTApjasNeBX r3DBnTt7Gl8j
wus5IgGUYjV3SJSFRgExBAClQOqB6Fr+9/5DRtNJBl4IFPZXoVi6bDk8QEMG QzH8QhtqgTxk
NzmYXIAF0tcRLghfu0A3FOyoMO2XGy01ZtOgIdWAHFsBJCF8aMLesE4DEbSc UQt8IdLZisYS
gwBp/k9tE6sQqpZ1SmR8kWBKT4EGj7WwMEcrBxCCYJQnjs2GHpIt2gjHeDJe lQmZCguUrHBf
ytyiiOSxkXSyf5oRlOE1DFKy7rNFLAHEnEqCLGUMho30bBAM4bTpSGr4PULk SK3UhZ5l14kv
vp4oIxAAEwqpORHjE2wKRicn0fA+nxXrxJjxbIkg2Q5LJ5VFxZjgxjHxkHli toFRIBaszyJY
wpI9Rlu0GWY3zJKHWbRkYWw3MGuGiatxUmtQqBjoWEDBdigs2jB7MgEw/xxu kgkzHQEEEbPo
zDWXI2fuxStW4dX3x6HP7957gA3e2P+Iz+MBj3Ed1pqx7z1uPLzrNwk/J5Es RWoeZ0Kqp8ea
iAw7R1pguHSMVPgPB4USxNFZjJumhRkp+CIbdiI0qV8bk5Qhw0c+DnmGKIlB GIkN/mIsPieM
D6jhBbfzZ0+BB2/bqSXWUg2LB2CLjQajD4/NJo0ZNnb8lM/69pw6c06fnl3R heJrDERFjJzo
iUoEphOftcCRkgEtBhXUCWvkYNXsqfQSQdnyFfE4He84lyxZCgRXrlxOnz4D 2ayUVjRl9PAM
iGnLA6heuuvh5+O2mlQYUnNhCwSa8WtQ8sE7TJLPnj6JJarV6zbhSQYecuBl 8A5tWuJp5YzZ
8xIlTc7Pj4kPu1bxgTzcxLHtulmLVjxUcH3Ag9XMUP3gwX28jCmKFs+fhTFP rDj8O4YMOn74
EHak0gOA4NifDR6GR7B4j+P1VKnw5ubUCaPHTZo2ZcLYpi1bYwf9zCkTECUs suPd54QJE2ML
LSKGsFiVmvE3IKkZdhcPifFldGx1bFir6rbNG/AyKY2geCQjbY+adBTteqBo 88hQbri4vg3A
TsNNkzDacaPBLJZFmXmoqS8lS5U6NZ52Uy3zgQ+7IsWrBjI8wIvYA3t1wTP1 lm07PZWP2Zk6
E59IivC2aIPvgNZFqJ8/f4FbOVnFK4OYyZUuXxEjtCOH9qMec+crgN/5Albm 1qTTREVviQSi
wwZNis6ZGnbK1G/QCxcBzhinKOHWb9sSQwiqYooUKXrx0hXs98BUGS/nBNQM jcDixcXOiK1b
aJc4NqUo30tTqScKTmCASCdihBkbMtYivByBIn4NEctOEgPhFBspOnyIPqkM sZ4xVFu/chwz
ZsoEQgxaEyVNNm7SVEwh2rZq/tvZX7E8luPtnFjywM4l7CZo9nErEYUBmjQd FG00JFqYgWMN
UrsNwmM0LlxQITSZs2QGBDvV0TKSJEl67x4+YHcbEDR9vLuODHb+4CEbJp8i HYE1NmTI2Lh5
K6lVjPNe0EPg4NDQMOwNa9ikWd8eXY8e+WXnd1vadOiCSGKFD5sdGjVp3rt7 F8C3f7elbYdP
xRKxGpZLJLHE9eQp7SYQ8yhlxTBYZgiYGuGDc3ivac7CJej+8K21v65cAYr+ 8/dRQS6TBJmT
QywxkgKSijwahxPGTwhKFUphxPwHe0+OHD70zfqv8f3OFClT4esJ+O4dep/u vfvBTQiRH1U9
ffJk4+a0fvTbWVpwxWQAFuJgYTzGNw7BfFJcttyHMHDL5o34/aTRE2cEtE8Q VKj0Eb6Osf7r
rz6qVkv2a0hsEVW8i4R1ELz6gc/LySuLZ8+QUjQ5GoizUlnbgir2kiZXtAbA u2wAhHdkGFtC
7Y16h+Azp08Cht8izpw5CzJoA7hnILDY6IXtJITKlAnt/GloBD4Ys2r9t1hU mj1jyrcb1uKV
b1k5uv/gPr5bke7NDNLUEUDeZEi6KOy68wpF3yEmijU+hFeQaw5CYDItHnPn wUAwU8FeNSaP
H5jI9hbWWRMnfi1/wUJMTs2APVWxAtWSPwXOmGXhpFt6Q4sJDsIi8aJ5s3FR YHMNeHDVgJ4j
SvHmPJpYLMlj/mw7YhbravFZI/VmQRohYxO9WhQ7Xq7cefDWDwRmyUqe4vON 2GQk1ooBi+bP
rl23fvfe/dFHb9qwFiiZj3EYzXQUQAQK9Pv3/Yj9LxxM1cZ0ssjFYqlNOUVt j6LylSXYjSXg
90uUXL9mNRaqaKIrSsTDqKgM1L08ufDH79neehv9A762C7/Q9XGjpTAiiNhT gIwYj4qk2oBF
FG3qxASOmwwY8e4fNlDglZ9CRUsAhfUOtGQQoAGgiGsND8+lIk6fPEa8NAMH imwiJ+XqCApa
smBOrTr1u/XqiwBu3rQeWGo/bDNWlkUv5EEyoah5xUJPcuqE91rmqZPHcAN6 HdtzIJMtps5H
DzCyGbaeCQH3ox9sWSA4y1vZsaNq7arl8npF/ASJsLi2bvWKPPny43OkxjyK iwkRx4huVVYQ
hYRe3Ci8eMGc69f/fuONN4F6/JCm/eglgYM79v0s2IA83EE3iAUarPNu37oF d8+mLVoBVeC9
gru3f4dNQIWLlrDBJDmsTEJERY4VwRghWC1SiQhglvacDCE8IOnfzIjvWdy7 d6/ZB6UJRMT4
8Q7zfAnMXHEiQJt3VBC++4DPLflESm8CfumnbJFlUoWqcZTxTDQaUT8CZVcM 2rolPTnOqEf8
o9o0GbPWIPVLKxGQQ3VNfyRSDk5VK9MoVlQAxQweJwlQBkeGiCRxIlqMkby1 HxkSy1BXMskR
u0RiwFklxgBmeVag0e1JE6HiAgfGQ1Ft8sGpmCQQkSlIPZMLhoYSKSKnUKVD yvGHSujmIHCZ
68fUhWgBr9HsyWZSYjThcGNiNFlFKsWE088FpMsrii1Mi0aWBIJbiJVuM6LG CPNorHTPDGHx
0VspknH1avSBIRZbCcwfKJQtt0Crm6RynCnjOOyEiuPOaBBIoPXMPC9xzDjK iaeB5YiBYoxa
Qik7Ryc8+02cNAW++IDNa/ju1aU/L2gV4UvMV/A6AD553vuzz/F4L/FrKbDN E66DCwJZCukg
4RoQApqDes+DR2nUJIdBWQqxidgp9/cNbAUlFsg1wpVR+glbokzs2JOmzcSA ISpWXPuQwBLk
zpsvV558eAManT8abWn+6BhjraWklAsAa7u2/Krv/NnTmOm+kSETiOMlTIyP PXVs2wo/b4H7
CNGK3Wy8x0riHCQjUCN79x+C348fPx48sD++Vy30uLmUKVuuWfPmr6VIuXLZ lzC4xAdl8Hoy
PmNRsVIVuhO5LVD1WV1GD/Yg3+Qv9ViEl4kZHrmPbutySG2wKAC8rgSa8RUD wLG/AD+4gA2J
tF30Dn49gWjxxgHezalZu05wnPhoEkYW4OnTw+wH9/+dOmMOfgmaHkRBgUoH GYYR2K1w89r1
xDnwRAqWX8d8YcK0WW4lFihUePK4UW06dcPW9ZMnTmA4hF/ZxNhs+uRx2Fgd P1FixP/6tWt4
HxYzU6jDLnI8BDUSbOvyLjBp6dZGyrBFxllIwLuH+BYYXinCLRL+4Uvt2M6A p00hIfQhrew5
coIGLGDAgbxVwkMjDBikzkUFI8VlUPNvilPKhzQZKkQF4QVevAP+NDQEYwYA sF6GGQp+mYIu
AXzte+gAzGIQBHrHhw+WSydRACEyhsEzy4ePaO4JiNDABxzAFileEl/emDFx TLkPK2HUIcMG
+EguiCRmYPHmpuOpgjRgTSMnsGSx6TUOjdLYI3uSjLhJdELLZe/EsjNmyQrL 8T35BAniY+sB
uiwcQk7204+dhAOLlZjpUyYO+nyEbIhgVvfEKrSrEy8ghykYqib8vP+nm/r9 OSxM4gcLatSu
//WqFVgXGNSvZ43a9e7dvYMpGQZ54hFNEBEhHYZKyMS8+bNnwpcD9P7tBYws 8UV0kH2zYe3D
hw/xiX7wIQiYEifHCwiRkZ+0af/5oP5LFy24888dbL2+cvkSwtmwcXOyUMyU uLDFXFlU6xxG
Aoleyuh4NEvW7BhTou/AxybrNGiyYc1KYMtXrIzRPN5QENTnn/XC/AGDznt3 7+Id2haftB0+
ZMCyxQv/uXMHO3L/unwJIcK3ZDAM3bFtC1x+M0MGeaKOR2Tw5cIf5/ETHvAF S85wBPJTpkxJ
UwvkYBsbzDk+UZzUZrFbGoHCsf8JYrHD/5uN6xHt40ePgg0/apA9ew7LKMJF Mk8tSKAcdCuI
jMAFP9QLI95zuQgXGjb+GDTY/YulByyHY9sSJr14+eXbbzYCXrBIMZGPyQl+ X+PEscP4wEnG
zJnxjQ9gm33cigTrABoZVK4xgBVjb0vXXn2PHD6Ir77hxywQLlNfjEUN4Qs2 W77ZiBcZOnzS
pGGTFphK4esP2HCBiA0dOR6feBzzxVBoRJ+FWym+pobqqFK9BoJltJhZjals ampkDzuuKAnn
wrmzWkdFHfp5P17ZQHsr+2GlxImT4oP5h385OH7k0Nr1G+FzfTCq/IeV0AYg ZdrE0fjSB17K
kBUuvNkOID56V7pM+Z9+3IMXHPApvpSp05w/d6Zw0ffxaFSCAKtgADlnG594 6oBiwGgrppSu
Wjq4W6HGYi5EloO2beRTEyJvS35QBj3d/NnT2nXqBmvxDgIQWCAwauXydVQ6 WdMlSY2gPUIZ
+i2oxporPrcpCgHEyib2TGHLybyZ01q27XDl4p+LF84FFpbggBWU5znzW2/n wBOMA/t/kg89
GhsCE7kCYowQWYeZOdabsB8sbtz4587/hn31eI8GivC6u3iKH40mT2/egL3w NEnixDeuX79x
69bBfT+ePfMrOnpZOOAoYteDuQowGsBy06oVS3BzwjWOFSg8TsHGVCGDfDET FtB9SLiMpRKh
QDe0rERUJvu7dOvVslnDbp3a9Bs0NFu2t1FJaN57du3AL8JgXQ8NCe2546c9 EeRVy5dgCUwu
MZgBXlRoZHAssgFFXQCSpiUWEhVwwWgeRPtBqTL4Feh//72L2x4+QYTXo3Dh AAFRefLmx7tO
eCkDN92li6i+qDe2biKv3TICiLv+7Vu38TkDXGLor7gnCcZbYNu2fIM3bF/n /UpgZwuppus2
aNyra0fsRqlUpcbJ40f3/7gXPw8MLhCQ4fYqQJm7XxteBuCkjdoNnuIk5XhQ Fl0n9k+iA2nZ
uj3kgAOvI23bshmfgLUDHdLJgwPQS954R0GVNZeIHLnfRRueP2s6Hi9cvngR 33cAiqIY4bhT
tTrc+ZndYQnBBQoVxTdHcN/EQiQoCxYpiq9XFCxcNG68+GBl8aSC/eazAVFi XWC8PbGJbKao
IAQRw3C6VSE0jZu33LRuDfqfEqXKYdH5xrW/zVeHiIZqUdzCh77w4hh+5+iX A/thdrtOXdEk
RBif9USdgPxTCJlgzfCAJkeGcG9A5WiOKDnsxD86mwOkpkhsolDPygSEaPYA JkdKPV3Ic9Pg
diI5piMKOmy7obDZA1AqCdIKY7mgYwDQwmCEWkFWiJsBqaFzxBo7SZLVoQU/ vRVuM6JbqR3j
RahFIOMdhGNGQ48SK/YokEOkVLhWCkOljtwoiTgRCTiH2AbUWGoGsKpGJROZ zYt6dY2U2sPQ
EMQB+0iMHGFiQiLGHxtG9yGRZplshmgUKzSvOksLjE7B4k0QWCKdzF90aoWI ubaWtUhoIxA+
IKftXgi07Yk6lYXU80kIbVkyDKSTZyczC7FktfqIA89LkNy8fhUPVPByWd36 DQoWKgyyE8eP
rV+75sqlS0Dh3vcU65gmyoHiuEzhNaqR8G3oyjX6qc5Fc2bgw71C43CS59jT 2qZjV4zfkEfl
yL1AaVgaSXQMZxx61DcyZMYbAZiY4Ycq8fFLTFM1CBQ1rErMmYpPqv+Bj51n yJQVb5GYMGso
kXJbILDkWLA5QRRUNmn+8fPn+Nk72siJjxHii/J4JyVL1qzyaXMAiVcSl5kd IYyaDVGXr9Ln
tzF7/2L0uGmTJ3y35VsUcSPA+BnbCFeuWIpf6OvSrUe8hIn2bd4E3vcK43tA uC26jrM+VhTQ
il+2u8FvlFeK/OEXr2BzxhOrJThN2nQYNuNnULJmexu7AywhMnh7Gj8A9fhx SJj8cKHi5Ckg
1rCSJ38dIzwF+1IMlTdtWN2z32BAUXd4gpv/vSJ6AyLKQkWK5ctfoGWj2pCG B3IjRo/HVbFn
13b8akOBwkUxy6hYuSp+bm/P7u2436El4Ivvdeo3Ygk8GGVtFDj/JQyI9Q1I PHHBWkOJ0hgu
xv399/PHjvzSrMUniDkeWeHBCTb+pEmTDj8XhUc+aB7QAl5kECTZW8FKaGhE LdarD1NfGGDg
8QN2UOKm+/RpCFoTZtlguXLpAt7axmYE5DF+w5QBP6jZ+ONPMNHGD39gqigj E2jHd/Hxs3TH
jh4RRfggOi5AuKQNglyBVTizDfb2TXgoJTiWVGLHwQfXsI8Jv2JDLuiQW5qW lQViX0PjEhSw
LC9o1EA4gvStB3vNWKhBatnGRCiJkXPYS1OubNlfz/yGJ+Ey7iSnhJozPAqP evr0SdFCBfFx
b7aVq5LMVKlsh9GoUaHq5sN0BEyDNyDwX+DYZ169Vl18z3PazLn44j1GP/gP Mzp364VH6CKN
RkkUKYosDtMfsajsb2cfOqgfGkSKFK+PHDseHyxBFEJCnmxYs2rxgrmYw+Mb JI2bNsfsDo2i
TIWKA589nT1z+uqvluI/WnnlqtXFF5GsZw4MDbFRZ6yGEy5SGZYINCwyYsiw UVMmjv1hz+5D
P+9DN12tZm1YLtt08cLStEnjgMK+IOyJxjfnq9asU6pshf6Dhs6bPR1TaPyH DfiaHTyCtl8O
7MMoHGNCrN5hxztm6fAaGFppBjwyEouI2KBbu83bFmwAACAASURBVG4D92kq bEYdSqDgu7Q/
cYRM5coBnJoHt5X2HbvMnDZl0rhRWB1o17HT7BnTMAiuVKU6Pj0gXIg1yaRF G7BT5CnDOBiD
MjZEDRg8bM6saW4YpVLwdjQI8QMQWHcEKebSWHrAw0BcKkKQOGnyKTPnjR05 DD/PC0r89Gn/
gZ+X+KAsvZKk8xkwwlRyif9ABuMjg2INGjqye+d2+J3OPPkLyBiajaJTRFjE 7IV47DoTv2S7
aN5MQDB3hd7yH1aG/R9+VB3fm1g0fw5+mxMo/GgF7Me7HkAhLsQv8aFYsdcU drMUgrJYLpF8
K/vbXwwZgAaGT0gOHzkWlwte+R48nNoAPv6HGkQbqFqjVseuPakNBAdf++sK vmmPndj4Ni++
G4KfQSFfIiP7DxmWLEVyLCrhxwVwaeAlILR22MNrZeS4hF3MIQujHVIjAWB7 sRk4+YVZltPp
MgXkM5yoaIYMg/ArkjPmjhg6sFun1pggIXpduvWWO4fpkqSFaUsI0Bu9CBWn T57AD3la1MRp
c+Bj9179Jk8Yg289vp0j56co9OoG/Ygw2j8o4TWuFDyRbtysxYzJ47+cN3v1 pu+shICMd2OJ
hoCZjx89nDph1LgvhmDJA135R1Wr43cxceFAzeQZc74YOqh7R+NpZ3ia5o1W bTuMHTm8bpXy
mBB+2qM31gdnTBnfqRt9Xxa+2CsOM9jJ02cPGdC3eYNaiBKGSlNmLcDuPtAQ GT1VNpWAoOJ+
A9O4bIBsqY7TbRXaXtJxJH2mLEtXrhnx+aB2LZrgnQjcdLHk8X7JDyREk6fP +Xxgv2b1awKO
SE6YOoM9M8ujQgNhZJOdS/MVbdsVENiBIBcdfj8cvmBHFXYtDh05pnXzRriE pdljMRc/SIwb
P7ZujZ04tWn9WtR0tCtGczUC6Qs+HcaOGl63WgUKYPdewz8fiB/sxP2yeMnS OXJuwC9xYpUN
P3IsVxwkBEfGwsdQ+nw2aNa0KXNnTsGdGRdOy9YdxCS2nO6XJiRwg3W5cWRU tOg6MaQsX9Co
BNR7Xl56yJn7XRGL7xpg6SE/rwVIDXC0EJP/Ye86AKMo2vZezSWX3ggpkIQA 0qULqMCHCj9i
Q7FgASsKgqKCoKiAqIgCAoKggBRBbFhBURAUREGw0JSaUBJCQvqlXJK7+5+Z 2dndu9vDUFTU
WcjuzDtvfWZ2bnd2dpYPfWpPQ3o/jzcTUJ3DR4565eXJWMcbD0AeGD5y7GMP 4QxCRK3atsd3
wjDEMO/VV/CcBOHga1usXjDRCZ9/xnAVmjdY8VFu4IaXL1gL4X7CWeYuO9KM Go43kTUe4rFc
6YwRVYoE3IGftw++ByMO0yY/O+OlF3B+db340lFPTqC2CLoAAbJIpKQ0fG/5 EqwTjiU/8L3b
3ldeTRd4VgwzS6Qd839KEcSRpk6oNL8UVcC1KKUqAR0g3ejrxPQ+ik1zAJGa hGm5E/ISprYV
ChKKLzRBSgAZax9kz+qYJCiNlNONO0KPhJ8TSCkLkCWgDVmunBz9/CIiGkss K+8Vq6p+BTmi
livmQgo/1ahxmzMyPWpOo4IluSYKBMlQXnUnG1XZtK5T8xQqUg0azGSEZOve taD1WbbHtfMQ
eZ4dZQGuXmvHm0HOEX4fI6yE1apuETzldLkN8Owpmi5YmByNk+Hg5ZFslhwY FEwZSXtjomGU
mRXztMgrZlWUu8qhobKswSjNhsljr/WP5FQLJKXJUv3sl1ND5fKsoiECDXhJ dtrM2fUTEvDJ
ADZJGfPF+l8/4Hju8fSMC3CTD1WaZqa1Sd3iO+YKONEpQeSdtxZNeO6Fhg0b evtFQAR0hw8f
njrlhVHjJjA/SUdNA+DKAh4d9N14TFnHl5tx/Xzltf1xBxsREYFnkL/+vG3V Rx9griXeb31k
1Bi2tBCtMo4m1aqAqiSYMQYtvMgvKEaaVotn0jNjHxg2on3nriWlDrBRbewg JxVHffO0gGGC
6E4Wl2JGMC6PlyxaiF8ELCGHN3OxSDmekvbpd/W2H7d/8O7bNw+83WQJItNX lWZMlPgqZnlo
DrSmg+KST8L1NaZdIDJVoZxS65dg4PS4b77lVixAjnkNys2CjyqfbGQkeY1i 72+70+hLf0op
C59l8YnHvVhGcveuphc0v/raG2CiuKRMdQWvELqkcROfB1ZYxhvLFeHNC7w/ np6R0bNXryq8
heHBWwmxTz37AgCpqqrZ9O2GVq3xpeyL2JpWBCX5PCLgaZKyL4ohLKKJJTNf fn4CXhKBIXx7
7hZyuehOatCQLLr/zBO4KsZic1u+/w7Ng13zUHjorHCmjDRxVkS1sl8eWrRg 7izMBGdc1/ft
iVmrs+e/hRaOAQ58v/biHr3gJuaFvjxjzsgHh6xbswrL3uNh6hV9r6FReDBz HrKvzZzGNGA/
YOAdtw66R9MeiEVysiBg6h4QZqGRBLvwozcC9w0bceVV12Q0bYbLEvlSgVz9 k2sGedPUDUtC
j6JNVkpZldPEsPabH1jE7KRlhpWulWSVP5qgbKDJ7cskuWfOeCWuXkJoaDhu n6CXekbeIkaz
xBUMLuXxgcPRj40uLC3z62aYTeKRbFeDCjt1qbdSeChZTkLbNaM3Kiomc1Yt ZrM9JKQSq1lW
VOBODE/zsDQd+C0WMwYacWuKQc2oiDA0peKSUvA/MephLOA/dcbsbhdfgknu cfXqYQkG+nDS
gyFPm9Vais92SPjGXijaKqlC6iO+EhocHFR4sgCB4QUktGJ54QbmH92HwUmT GW8uqMs00LgQ
SFREOPQUFpfKYWIWEd6hJd8gxAqleXHxCbgAxVqGrFZQZA8OgRT7ogmQLHWU wwusIhMSbMMa
cpjDQ32owSCi2WwKs4cgzJKiwri4ehhJxYvxsGIxm0JBr6nGWgZx8aDXYFET Vncal6Ww0BD4
DOz4KScXEsDNALCc9lyECASsFhNWwcSjWtwpsbnQHoMZRYgOrbCYTtcJtgXB SawWQ05vvHQU
HoZwSOAMxiCUBhUVKDDWMBhpFHgR2oM+FJxBVksIBqpc7uIy0kHTtsYq2oZF 7/EWdExcHMJE
BaFF0foNBxesEF5iyRNmJw0AuKEu0ELCw6BcwnqQylNoqhU78mMJh4MsZgxI Izq8xIHX3YEG
WyUuxBYE2FERWJASSbyfxrqPoCCrPdgGHvgPexFhdpPZVFxchpWTEEtEWCgq Atahf/zYR7b/
uPXFabO6drsYq9HGxsfjlTaGKlyHEvDgyxRYWBSjKBUVlZgyjp4uIjwU6z/j HQw88kVtwgq5
FYGvBoM9xGYxmTChDrOq0GLRBmAL/oSGBOOX3kEmp/HhPxIf2Vir03QOjOy3 h3YJTcKOI1YM
JcbAIve7hujIcPx4sLYdHREOu1hCFeX4vE1IiA1rEeNNMLx4BrITq81pdLNW x3xge1ao5VHY
0ZhRcUoWCXiC9mYLCjKbjFgLA1HDQqg9GD/e6P3wqUiki0rQwMBLqhLDxBiy 8dBleBU9Wrua
PkYppwnC5EFrCQ0NwYj7yZMnk5OTg0NC6exQ0t2hRuz2YDwJYZFibRG0E6vF jBaCISp7WDjs
1lRX4V39mlo3vAJy5FkH3/CwIjQkpKysBO+mYR3H0jLivxebB6dSGLSylQi5 nKYHV0g8ofwo
cgI5YqIZagSrwGL6BuY1BIfY0T+QhkqLCHRFRWjkmIGIzord4gLGMHtwIT37 oAFnH4KlDdiA
Ex/nLDu5UIQKgh72WibaR7DNhq4Gv7VYPOyRYfdibWRMUgUbCdYeUlpcjJ9k MEeEheGiE/ig
iDQkvHdYTYZXAHggAHFeo3fCy6tYPgjrxuA9YVbRbJQNmOM/1nvEPA5UvYOc hqT+YBStH49T
qHLYikDgbKVPRpH3tGl7UXwyrNUSogFgoodA/4YeCXnYtYcEl5SRZknONWKU 17XHQxwwSGSO
KDaPB8FSB0jgEARWWNMnIiqKtuEQXC2hDbAiEs6JE+jZEAj5LeBnbXREGPoc vJkMNtKVhdoV
hZyHdHooJfbYkWaUnUrjxVCCVlVahg5KPgtZv43VH+A8/ofQasVrgPjtAOD0 kR061RCU4XyE
wldenIRT/rmXpuHNEfLUgfyIsJsKxSzxh+qne95SZWfgOneGCZBybY/gU8yY iDATI30T2Ekf
RTaaIDtGIdwkQ/YkjU2xpq+YUimPwijrhywzRNXo7JSIaLwyg6qKVBLRzv6R YuYZTyj+KGRZ
hXJQYgCF6SVFij4loQiQBIueJDRk6qoXvxyt4oQcDNXOBBV2muDliiNa56gA tUd2igeE7F25
IHCLWvcII99UQxpfeCE9avDSJDmLrNfLET9fOTPxFUiQcsWuUoYE1cIITK8C ipaLpPVMUJqf
CiZJzFEoOB7MA+aL7A0x5rvpRKxl8S+GfmZLywZ3WTxeRGQC0SmfTyELD3pA Jxu5hCCrmOHH
EKto4YcGn9wKsljN5OqRrKRLPKEhMUhIy6CtQxskLSI7vKn+3FQ8E/KMHfng tNmvk0s+4h71
g+2oKnSe+Lj789NmgfbkoyOem0oS2LwZGQ12uA5eXFvtxAOob9avYxxauUu6 9xg99skycidB
79Boa2Q1QvYsRcS80FUMIMHS2D/8wF3Dhj+M6et4I5sbYmI0R/g0GHDNhKzd eB5Ax0aRr9G3
bNcZ5cFBVqm2OiwiauvWrTOnTo6Ojn5x2szScrL8mdwo5VNdq8sr3f2KS7zy f5T59ius0Alv
dHwmojLMJBkWEoRHMvigOMnUbcNdDy4mJ06ejtkEGgkWPFVtIL+nu3buwDc9 NAzeSUyfoRv7
kUXLw5MSMtoPBTK8xHkAc3Dfb5hLjh9WORpihxRpTwQOPCFjo8VYZ5D8Ip84 cRyT0zFhE98N
wM0UU46fS1yD2UPtVVXViAIG2WUJ6HCK3R1Aj3KFwBTKeqkJXGYE2/BpeZrB A7ZaVyG9hyV3
JTZ2SUacwrUWfMg6dAAroeKLpOzdCgjh5gJXbopaNBjcl+FnmjcIBgKBKDYq ohT3NnQJQtkY
Lu3IzZoNF36wAdxw6cJuEnEREhkRCjq7EqOnvyzkfyDWuf9yKScZ1qz/jpTS +CiRRUpqRhFh
pZTCWIgSxoEL0+PZWZ+t+hwPotHLAB32QAZY4w6Z3fredMP1YdFxyhiJtgqp CcUOU6v0F1pG
UsRs0gPNaXa4v8VNKBv1oFgQWQUUhQLVT41+ZNuPW194+RUsLE+mB9OhHYUT rrBuEGM7coQa
72ADPjARWqo98zR8GseUdkOcV/84hwFPbMhirRo2UgQzMEWLSD/NJYkKMqbD faD+UH56Bw7H
WCA0eJkOHvbAkChVNk3lMqeUEiR8nFGKoBzaaPjslMZTMqVQTVAftMaISl5M 6NoQOJ3zeDmm
Fqry8ECJSNMxwDXKQ8AiCQoaS6hafFOKVhSQr8RiLICM6lE2OQDaGtCS6Rig MiApF6o1o1SR
6j8hQXrCk6PwZsrEyVOxRoDBQFbrVazSBOGCZXSOTBs1SAKDDQDFiL6OGwxm rACMMhKtoo9w
EQokvWgkJ3vsq0iTJ4YpFzWNAuYDpcokXkKlNDhTe4SdnOOyFo1mjgnc8PaL 8DDHAnjoxQ5E
jADQp83JganxMSfZ0KzihJci2aZSyBOESf4D8qgU2JJPdtC5CjLWJZ8FRBCG UUKZCQcSrFpI
md5mIgysebJipf5ICGoYBH/KQO2qO0JTuWQeyuizg5No0rQ9E2nFDKT9fFBE oZkyywRqiEpS
BxQ2OfHdt+vx4gleP8FXbFZ/vBKxvzJ3IS7RFP9kWEieqaKCSrH8bJkQdQEE IzsF5HOSOQdu
2RuML5E+nzjo6yTj4JbU4KkD2J0COMaiiCjnBaNDpRYLYoFbQVKRosxqo+Ei MEvmL2jaMC8h
AjRYJVbolTVTZ9Ud1c0MKPbIea94plBVTp5i5kgQ/O6Gl3BEeDTIo6WTE4C7 qD3OmPI8hh5G
jZtIGrzcdSnAUEZ1Ry3wYAiZKWIu80JinpsGA2OhB5ZkLlNu4pBcK+RUJL99 tLMiSTCQPU+R
LJPBngeiMczKaAGU+py5RI+siR+IdipD1HEntQTuN1SSJNnL/+QS5jqKmItc NuCRRqQpZXoJ
gemlCbYDq2KEMBD3/TZFCiXcWZbQlGiSDDXGSfCRFcoJsrQGNmqJFOGP25SP rEpkKX5AGVfE
SFyI5LQlNK1a5fJKbFROjpOkmR7ldxoERiUsrExzIFHSjbsvc4DG7LJSxqKW aaickyoNwKGY
VjyAlMLLPODA6kWqmFOwV5ugUqYmiGY0LY0BOUimW61ZDY8q7ZWiqog6QoV1 nmcExQKLi9hk
YMsHCXPsp06eCFEs8YCloIgSqgaa+D+iibEzndwKcrLWRfNm/bydrCnQtn37 QfcOozp84WMB
Lnlj9k+Usx3jVPyTZbwbFogaBjwuqhcTjcnz69et+2n7j/n5+XFxcfiucM9e l2GG2on8Avyo
ESu0xWiBlLHlDUk+cs1yDNQBYJNz+FCL1hfSj9wxOfAhwbkJG9enpFQC00L3 ml1MZEQhfQQL
/Vaz9csvPsMLlVhHbPLL0yucbLImgZhIKO1HI64mCYvWE1IiN0fZB/UHg+mj skiqxUyGCLIy
uscO98ZJCfE+j5RAV+xpFHIZMpXVfTg71+uU8ONDxWmfJioKoUVt6VSloofD oByJt7idxtiS
altJsSqkWa1yuZyTMJsDP0Lkt5L+esuI4Acdy2PT5q7o0yYUNkaUsz5UlGkK /AsVhXjgBAeY
OcpGdhp+JIm73GVZjrZomY9wqMWUWdkRQVrGGWiJYvyUCdkG5dE4ZFi99lvQ +OlEUkqWJBi/
XE28+lRdhBITFZl5YN/7K1dintL/9endrVs3CK1b9/Vnq1bhudCgO27Havlk BQvuNFUZYEf0
8aAUfuoE95kfVQVaft77oZSLUzRphoL37rKl+EAiXshJTW/Euz0vyGnMDAVo 4SH7UlXzfinF
XflmmDHIEHpxc07ZVe6xhgfOM0E5bBV5lUkJkMlrlZG0qlVN8YqVlau65BQH mR8VBm8Cclqd
Mpem+SpyakJzLmtPDDBodNMky8OApsDHhGpdYWM1hz2Tko/+Kny1alRpA+Du smKyVxlV9GSj
PAhijVWbQVr5zjKsE3HjwDvwVRTmveKL4hulKGTShplZpWaJWa1XTJFmrzRT TvMj8ALlKOtj
ZuWg6IFbwhF59kcTzC2ZFXpIiMQO/pgWf10qyoRPsU3rVFWkoXsntRKsREVB NkZ/+ngteUtT
g7IKX016EoRH5eMp9YiUl89eGW6as/M8P6rMSHkzeeeYDZWdK5Ax5lkVCE6h R385r2KS8WPx
I3j7R93z8ZEp/QmrHn/z9ZHDWVZrEFZAuP3Oe/B+k44FYkBrhCijFcASTNkf 7NnvApg0nqhN
iqQ0BZxLNupTRi15+aQR5Ul+pI5qnff206dEkZK5eKUpdD9+UgIiY6ClGhZa yTKRHTSFzIR8
7lFD3Jq3izQXCAJinej00+ujg5/iXNkXn36IV8P6XXejyqfEyKORj5SOHbGj uqGmiHXmA3eC
SHApuSNVMZJL5M4I4w6Qxh/VQbosGo1mzx2UDSp6ZchhCbBRiwQ+LYRQwtUS H5kiqtlHJ8ty
iNQj6FQf0U8tyFpkJ7mWUx1ZIBoOWSGncGM8Ty0SoKm7ss8oJCSZR9XAKURI 9o+x0RzYKVEp
IVxchB+JTh9IOFKyOX6QffE+0ELVS86LIzNA92SnGGYsGpMMTJCJGh3toPF/ lEFrjRnRUph6
WGdFcpYdOB+OKOU5hYUSiClayjTQLOFlhV4yJEOYWWi8BqhdbpwfFRteCa02 hRPIsH8yq6JP
rTtViayBeEGIihKVwzultkZuWzkqdlmsoOOh656dP0NBizZtMY1Lqwkhs3+E qFQgycguEBpV
nZQQZzGZQcVE0ezcfJmBWeXusmMyOOl8ScJ5Apxk82ZU1PMCxsT3eMiMJ9J4 lk6G7PGJOmc1
ZnuRZ8jUANlRp2l98VrjDnMd6pGZJuFRGg6R4aHyh8+9pDijF5HIsLjYXYSq l6UUIW2BR9ry
3QZMMx946+1FpRVsmTBtecC0rI1izqyCVWkwsh9EmjBy0/SInVpMU6zhE2Z1 4yIaXkWNolNh
UuXUlGzslDwqN0mpDYzReTj8SH2RPaZBaHTLSXJQo2NqNFy8akmBTNYLnsox NUyFZq/YZzR5
kRMNg34SYjDo0ydyX2URHqdvAL4afbSQQGiTpQnK7JMlNDlcWnzqnTZCrSu4 nvtszXpCURzV
nlgkGFlUy8NpqlhsdGSDlER8aTAnNx9f1oFj9eJjkhLqgSPz8LHisjKte7pu M6+0bL7pQBxc
ndLhKglokM971rwpJ+awYKgMk3Axv52XEj6uRjbL8GBRM5KS5nVFHQrY1rj7 gbgonTPRo8YD
ud9lFK6BHOU0k5MFFDklBoXCm4gXp5cOmlHc0OT0k4yTl/GjIu+Ft0rVpuTQ tCSfsJQipp75
rjVFKGqICruc4F0OqokKkR2vMpJU+ZFU1WhScpIf6FEtVuXlFDVANCtWuAuE Ab9neBcDP704
OwgTobFNy6WIwiP+T269rGkS+/xPVcBTPFI5ZJC1yhUuHw0sJo1HrJybQXPC P7InGztFSIJt
zGPEzDZKZKpkDs4oh8xQ0hpT3dJPybw4KKqIR3yTi0Ggw/GUTS1VkCZsMiuX 1DlCsYodL1cr
hWmgalRdWme4yJkctYYD6JSNsoMmSE0ygGXCQbkUv2lOEQRZSStnLwdMkWHt yc8E1hbGrDdM
xkMIGGXGfEX2iDxAFFze2wPVPFzRZrhrxAvqieIOTYBVRY6klGJih2W06mSi d4HCwOvaSwlR
hE1t9Czvs2c69AThhkxWShWDTAnzGkTGQEsVFhlGmcgOvJDwa3XjLFQpPg5y RnaULRFF9E/W
KOdlnayQe8/0eVnA64eABetUa22pLkAbzSgUqpfuFAFNjtY7CZc5o5FSmGSN PBbQCTedgUR7
J1pLrKawZwrlmGBRbh1UG02r6miWdGLgYgFT3RCCAaaKN0tVn18QMv4KYkgo NmWriozcoGSt
tFQt80nJyKhU2UdOUHVzPeSIP3LHQvxlG1HjxUAzKoX5qhB5GD4hkHKFRBVT C6oZ2RoOGnsK
EeIyqyymCqopxq15lsqcYh5pxblaVtc8Ry3w+uJEBUQfXl7uf6RGVci8GGTn GY07zpuuF6fM
orqj5WJUDimNj2YCmZaB1xgg2qhGBg5lIFqVcBkvVehdbWpFgF02KCv2N+Nl UdbOaUSWuyE7
w4tICSaTwwBeh9QQaesnVtSWzKqF5qkz5KyjFcl2VFhtklpd8J65T+pBmezi 7wmRIYyMGQlZ
P6GzTSnhBH5kBRw/mOOee+nj3OqReMQ3Zo3VOKf5HnVqgrBwNQH94yyUATdi eLElL7+IvRfs
ayNQXjbCbRE2HjBPUEe8WhblZiKwjYRfFWn1MdMsCo0kyBwWf24mo+7rfPoS EbV50Vqnzqk0
7ivlZDH6NTkCgp9Tiu8koSlV60dNEeU8OpKmjngdvXhlyCkn0a3RLtMUBTyP ozYSTqZqaUvl
FKZMGcbS2GVJboseFSQ4lTqjZBSdf5jgZshR9pOHBWg/Wr1WrSX57PdtdkoQ VJWSI1By5cQL
4pviuuI+J2qOSPpvsiad2lZ4tcZAlG3xYm5ee37wiqdllF92k8lyEarCt2Er 7ZS1WmaGEVWK
jAj3QT4yR2V7DCYf3xmj3BQURjjHPfbXKJuWC1QZNSVDQjm0VC7CaKg0JLz8 UTMkpeaYoCbv
XeGyXv8Db19+JTpe+fEwgsaoL8cplFApJqqFi5+egd1XdcopTT2wBqX8sMEd wqM6SFJKYwFd
tqLxxTcCkvfyhapQq4+1Au891aHxSvZAcYOZUyOl/DxLMjwwWqC/IyzcBLGO f2RPNraXdYCN
nQIIm23e+rgOSuUegpHk6Y7pQRIJtvdWwBmZCHWLkFTzsh4mpZKJo2STbbFi RiFUlmceKEo1
TCqnzKqUkbxKYylqCjuVztmZEzxHjuDxJ4LqLytL+erVMvpp0jDLZX4sqn1a pFOu5yALTtuK
tEEFSntVv75aIsp8IN9EojmSVdySaaSAJGmW0fycUeqalRMRGVZVo1oktyjF EGUHv8rBKFoV
PswyAzv4lHmr0VGrFSbM3gKklLdhBgbVT85EUkJ2vptyWlFNqkodZq07RKVG t3eVyTY41KpS
7q62xMshmRWaaYpLqvyEQjZ0p14eKg4gwbk1dUCYFTIRxx80gBl/ZGO4EaXs nwyj7AixyIQg
yV2gFGSAICHRAyvlSoheqht7okB/YzJUCUly9Yq7KkmWZyqpo4SiMPqo9zIp O+Cli1pSzFFV
/uqIFi9N1EFZVBUmKea9TGMEQqQlZKfyeKnUYONjyEcV0UQ2Di/L6e4VRRwc WRVlVgoVNzQu
EP3eWdmAQqWlRIeiU6NQJnOzsqzfQVHGSuQ258fGCUqNc4LsOfo+Biqhy82Q pOQ/QuWb7CwO
3FveNgmHXDeMWeOctyZZB+WiWojf8qaW0ZRXQ+M8gaBFOWwqqhR2H1jAwLBH AkaIHdUqybAc
0cMkqXsqm1rMLcheylq0Hvi7Q/XInERey03y+hFTn1hkpH4YE6spKuMXhrda 8uPGQfZBg9jU
bBQTjXtKEaExwBRSwATh1dNBBVgBi8VPgw+Z8vJwOTOvFJb3kQAxoHWFVfZN PiiNgShUeJh2
r71c5gWtrCOgoNyYaI1RXkpQKpmR5Pqkxng16VlWadxN1RdZk8rCUoRR/lNc pSVafrlESwIP
zTJwmC5lL/MzDkblJJKjzslxIiurxUH11k9IkafOUg1EkQYNOQqmnamV2Zgy GFKUcAo9qlQ1
pTIYOl78P97nMZ81e0Uep5pMViWR0tK4M/Ipr5z5GgQV+5xXi6CXYp8M42fi iizl0QAkAy9T
lANjI1LKH094AUwEZN3soD3vqGlGYG1X2hcXOgAAIABJREFU7XsoBj7+ynFR PTxopc3LvJQu
G2SusYxKklPMNtlrVXC1sjZfKW2xEpccH9SAXebQMjKiX4EXi264vuGzPPGJ NXlFyPcM0BeU
qRxjHhtRR4o0eZlTeyDeUo8RJuwy57kqFHlF46tMVa02W0bTes5VcG6qkxBZ gqZkLzgr8ZCz
+0DP2QmLGiA5f7z/sUK/ymQBMTtyuFSjbFk+UOVsp7ihoSlJZlJmhA/EDfZo EStSsCyRZ9gS
gNmr9v6ocj+pL0SCOcK9PaUTsjdUgvuvxZ8JkxKagk6ujlulLiqlxF/Nxnwg IlyMprx4mISG
RJL0T0OTxVUtihGZpOFFUg1BU0+KyB8keEsGm6qHyxDlPK05gpF64C8AHXoC VFZbIAegnj4a
7X5JVTCwclWIcFMJJsZqTldQdoK0IbkV0bCIHC0i0MgJRT2TYaoVIkucooia 8GFH9hRgUWZm
hun1llZrTSlVfJIpSoEiqZjjrMpJyQkyK9dAjkpaq4/wMxnmiFImK2KWFHuE V2GhNmhOCYLk
tH/IcHZVEl9epaIyK+XnZ73KL7NQMeIM+SMbfFFVQQXV5dMqFC3ABUVEBBur Jt6MaJbqo2qx
o5pkUaRlK7RFwQptWqSUslF3uE5ZO9cDQe1G+Jkc3fMGSvXwDNOpSFENNCau y4dB4eQJwif/
UVbuJi+X5Yk95RThZSq0hAItsjB3DkRQWE4pUh3SqGaMhF8mUvepXzTFfFTs KYZogssQJ1gs
PrVKC2QVlEXuvPwD8ubUAkl9kYuVA4jwVz2H9O0q7EqCBOnlNS+hDYNllKQM AKhQD5eJEaKA
tUeaYGVyhAo/g5LuNZXAqEwF5LQbLwINRvAPG61AUoA/qln2SyYRcU2SZGU2 1T+tLcILAflA
MnRDnmJHdzI/4SEWFSAYK9/LZBkMxWHCTiSJ35wVOZKheRYVLSGcCo+SYPDR rLqT3SNizE9V
tZpSVBAulUxS+i1Na53izJEJJOCtFDktPkp7UCJl7JqAvOW1/pIS37xXFP51 5q2M53StaVwj
doguLbY8DpTJnD7wcX5u5FRHOQrWkgKo05H3dpEz+PrB6aw+iSlWh8r5paKo Vi4VUp6CKCp4
gsMsX2p6OwITpLOSg4IIK+Z+8SNnoB4RxRoR+XSg5pgenSasGECCKFXyVIzt VJ0kpXJQJ2RP
KJUX8SPElbPVp0ZoT6xEgYRGRmPaJ6nBVp/fnHc8u88Vl/W/9uqUlBR8xMBH XmQFAgIBgYBA
QCAgEBAICAQEAgIBgYBAQCAgEBAI1B0BfN2svLwcHyjEAEd8fLzNZjP369tn 0O234n3d4uJi
LJBZd12CUyAgEBAICAQEAgIBgYBAQCAgEBAICAQEAgIBgYAPAvh6V1BQUFhY WEFBAb4gExMT
Y77i8l5YIayqymsFWh8xkRUICAQEAgIBgYBAQCAgEBAICAQEAgIBgYBAQCBQ FwQwrQHjDGaz
OTg4GLMcIiMjzbExMZgLURdhwSMQEAgIBAQCAgGBgEBAICAQEAgIBAQCAgGB gECgLghgqMFi
sTidToxEmDEUEeg9C6zLgW93F+bm/vzpqtzdu52l5Bs5QeHhCS1atL3qyuiE BGiRl6bQM6uI
7/70k7zdO530EztBERHxLVq2uOrqOoqfyM9d/e2nv2fuLi0vgcIwe3jz9JZ9 L726XtwfWNfz
SNAEAgIBgYBAQCAgEBAICAQEAgIBgYBAQCAgEPiLEGADDvj4q2Ht2rW6NnGf j8GJneu+3rpo
SWhQUFx8XGxSEogF2dl5efnl1dWdBt/Rqtf/8P6G7ugDE9+7ft1vby8OCbLG 10+ITGqANTSL
s4/mHT9eUeVsdsugpj17nVp8/Q9rl61eZAu1xCbFxsfVg7sn8o4X5BTWVLhu vfLOnhddFkhc
NyJBFAgIBAQCf4yAq2z/nmMRGU3ig01/zCw4ziMEXDn795TbUxsnhp1HTglX 6oIAPenCM5rU
EyddXeA6PZ6zOy9I1WTZU5snhp1Wf3h2Rk8vQMEtEBAICAQEAv8ABPLy8ho1 amQONOUB8x12
fb1+2xsLGtrtrRuktOnbt8mtAz1u176ly3Z88cWOo0dRhEEHjD5g7oN/uBDf v2HdwWXzmsSH
tm+b2rDH5QmX3ygZTSfWvpf19ZqffjqAIqNBatLzskDiG7asW/zJvKgG9lad 0y/vdGWfdteX
O8s+3bp80y8bft9+bNEn82Adow+64v7+CIpAQCDw30ag8vtlr397UrJRFKqq ipK73n3rJSk6
mDizXx45/PJXV/ZvEpqz7d15O+qPueuSYB2+syLlfP/u0q3HmTNBsRkX9+ze MjH0rDSeM+E6
A3XOLJ4rRc5tD4yc+cDsL69rfGqNlTm7Vi5dvHjdr5QtrWvXtv2G3tUh/l/+ gaejXy9cJfW8
/39pkivvo5fnlF96961d5PZfnbNx+uvHb3/ixsQ/C4PiL2fMM/cf8b+UAGeS M4eedB/2b2I/
dd2db6UKqtV52xa++Z2TndKSVFUkXXrfA10SXZpuJ6h+szY9enSJt/7BKeat c11JRNt77r8i
hkfuKt71xrz3nWn9HrixQ92qq67nBbfgfSRVM/KK2R9e19iratCDvf6tdN9I rzaj6TDPzqi3
C5JU+f3Cmb81vuWuSxr4ltQp79P8XJnff7r4mTmbqWzX/g/dfduVKee0981B rf/W4HHlh6M6
Z9nzSxvcN+KSxODzuOevE5SCSSAgEPiPIIA5BFgI8tdff923bx/mIujOM1Cg ADNmAzRp0qRN
mzb4hkUgZow5YDNjKoEiqU0U5Ob+unRZk5DgTnZ7issdnZPj3rcPQw/Rx3Na ud1RIfatHg8Y
Els0j0tM1AqydFHu8WMfLW6dau/cKjY8ISjYVOopzZWMxhBjSVoDa7QlbstO z/6PFsc1axGT
mOQvnpt3fMXqRbHp9pY968fH2WuCSvIqjlRUO9wh5YkZYUHRiXs25IKhWXqL xAQdcX+FgiIQ
EAj8xxGo2L1qneHKoR0bAgenMyoqxqbf+xmDcUNmD5ZQ6ir++fsVYbWDAvSS ZwGoq2L/ulXf
9Lzt7qSiHW8tXrVy8aeTV8xsE3FazxXPwvwpResK1CmV/B2FHnsnqZM9QLVy hxy/fzxg5FxJ
ajJm1pJ2MTX7dny/ZPL8zFtvbRtzXoDP3Tznx5Ktk1cYXu5P2nxV+e51m8tb D1baf62rfN3m
X66vvd7152DgKtj78qqj8+4PViz6hme04bQMpSedb9F5nVdRrS0vXrluVeMr b7u8YThcdkZJ
0aEegE3PphuGdoz47asF81etnL95+HtPXXbKU0yrM2/lunWStK795V17psqj Nlmbv1i5brPU
odNdgaurJOvX7/ZUdut9Ee1R6nReBISZVo3dRvpDLQ96sM3rym8b7uWEpsM8 O6NaSzRdvm3d
tpibzqwn9m5+rl+XPzlm6a9Sv0eW3HFxTebXdz8+Y/PKrS+teLplhJ/VMyW4 indv3h7jUtyt
de7evC5s0DBgeD73/GcarpATCAgE/oUIYNwBL0YUFhb27du3devWdrsdX8PE mALbEDCGG7Bn
own4fOaOHTtWrVp14sSJyy67DKMPuoigCyRLTvr8nCisv6/5KsrjuTg0NFny hJeVBu/a5Zbw
zxOyZ4/BUWY1SFa7vaTMAbboO25TpJRE9obPY+yenl0SgyJsljCj2ZVbe3ST ZDCaanOCIoxR
xrCeoebCr4+ALfKmOxUpJbHu+y9MQZ4O/RqGRdksQZ6T7sO/5G+ocTsdpvzg KEs9e0RIv6CN
Cw+CbeDVgxUpkRAICAQEAgEQcEkGqWPvQXdekwYGg8HoqirOL67UYa51OdCl utzoG9P7L9hx
mzPnSH6tDt9ZkgyS1POBEQ80sphv6f3qlSPmH88rbxnq9VzxLA2cqXidgTqV ARcWL7Za5RtZ
IIlfrFOxn5syl9sjYXw80I8aNVK45lUy7jD147cujq2qrDU0aNTmqpuGlBUV FlfUnBsvzk8t
JYfmSU3mtYx21VZJRgMaH/4UoNwSHp8bLAS6P8X73N2bpI43NbRW1wbCuNZV hisYA7kgwfaX
tJZzEakGVbcFoEo3Dxp6dRqZB2owSpWF+SXOGtrt3HjnNenmIXd+9sTFT636 NcfR81R9kZdO
+ept3daDl6Y0ox4Xbv3sS5IIs5mAFCX570p2vzvrVemC/3Wkz/LJeVHkNhD2 0wKXMXss+Oi6
m/aH3oYQb5hPm9F0mOxkJEaxSWdbo9b+H+y41Vl4NA9982lv2ubnyttKxh16 PrXp2avcJeWG
lEEbFll6DJ4+96OfZtzW5rRVBxIIMkgGq5FETjdcqmOhNAOGokBA8vzs+QMF I+gCAYHAfxGB
nTt3Hj9+fOjQofXq1cP3KdhAAzozfCyTwYE0xh2QRpHVasV8h/r168+ePRuC 7dq104UM4w7o
BgO+cGHOzGwTEpJiNMYYDCGSx1JUaPxxGxRZqqqCJMlqMhrcHjBkZ2Yywz42 wk7+ltYiOjg+
LCgy2BIWZA52GWsOoc81heEDG3ZziMkYZG7bIjqr4Hdd8SPF+9I7xtVLjjJb TWbYMlXl1+73
uD3QE2rFk5Og4BBbWoe4I7n7dMV9nBFZgYBA4D+PABmdlcpL0ZN6QVF57Itl i+d8soUSe898
f1iqkXCiJ0Xfsu+jSS/83PDFYd2DpcrNsyf93OialvkfT31vpySlDh4/tn+7 +uCsLtzzzmtz
39uShXSPh2Y+0isVCcmRtWLGiOVEa+rQyeP7NI8mRM1GvfHkZeVgaNgUHYcS U5Axe9PiV/ck
3tQ8f9zk5amDX5rZv2nJwc0LRk7eQAWvfmjyHb2asynWJVmb33pj8ho4gq3H o+88Qjzc8enC
cW+sAaHz4PGP9G9HH5KWbF25YNKiDYSt80PvPNkLRH2HCQfbGFCFx+XXQRix cvP8ST8nX3PB
sbdmfCK99M7MuCPrXps9gwYt9Rg47r6bO+Em5/jmpa/uaXBXp8qR4+ZArPej Mwc1L5xx93jA
kNp76FP394mj4w+Fe9dNHTWD+N5qwPSxAxOLNz0+dPs9Sx9qjUe0lQfnPz5S un7mPd1TJcm1
Y8XktZG3PtInVao89unC196gAaf2vnf0XVclk0iy5j+2rN7NFx2ZPGONdO/y T/pQX0nFSZVZ
K6ZN29ngtmdu78QQo0VS9bFf5x+Uej4+obM970QB+cksLSnCbaIRA/eIW9cK rfo9F1zfuuTz
SYsQSqtx80bHZ34yYvJ7EB/w6PTbuzeCZKDmEUCndHzHF6+Om8Mq8KGZ7/Si z7R9kGkUCrx8
kW+KwE9/y//tB6nJtUmeCnKd4KJVjFEaetEAZfKzC0qoq2O+4F9VphcR9bRy 55o1PW+4042V
rZF35X8645U3NtDQOw946YGBTaNNeKqBUbeC3799feJLn2QB46snP3pH82ha dTqnEkF7zwU3
tatYO/6NDWhc90566qrW5CRCm9j7zcrZU5dn0czQme/0AbBnXq2BmgTVLkla VD0kNqm6NPf4
cbNcTA7as8mS2qantCrYRnsYqdznFJOFvHUS8SZNpO1vbsm+uml9E2nAbx6Q evaU1pdhdNRN
LgD98Kk+tm7Iqz+hZNh1/VJ7P/risK5IR1Znb1u9ZPycDT5w7Vn3zpgZpCWj Hxkz/e6ujdij
/8qfVr42nvYbvQdcD5l2pG3QCCkrdjQwXJR5kTUdJi2vPrx+8XSfDpP2Eppe 7pponfbg2+xf
LBg96ueWQ4Z1b0js+4UMmm67JcySV/PL2fMDSC883LvsaC4dByuzpl73wpXT x67YcOiGVqkS
6VKSb+t5cNJk0pOeaTskzwI9vIKgh55x9CeFdDMo8+n5vUAkDGITCAgEBAJ/ MwJ79uzp0KED
XqMoLS3F0AMGkLFh3EEZeoB/5IfBTR/4YETB5cIARMeOHfGOxoUXXqjrPXhO NevBXlKaYDFH
2YLCTCYrTFrMkskskZFbK76KYcJ3MWpdCQZnSUkpFPkbiLaUxyfH2uLCgqJC LPYgo81sNJnw
REqqDTE7raZgq8Fijk+uLHGc1BV3uEtbpNcLDQ2xmI0YejAbyX/01zVuEz7I Uety11rd9dOj
f8vJ1RX390dQBAICgf82AuQp3I+ZO3cmJEq1Tskc17RJgsmV/9ZNQz+QGo+e vbxHmu1oZm4E
eVBFrg7Zw3NPxaGsg4n0caHBULVzzZyda657bOGSkb+veGHK+CFRs5Zfmhy8 f+3r721pv2T1
wsjirBM1YbRHyn9r4IgP/u/JlV93z183b8iYCQmLprXyns1L73QlsxXslds3 bELVBFtMntq8
nZ+8t/OTPs/Pm9cwul7l4fW3j5ze4a7nV97coWrP6oEPj8l0TJ3YL7362Le3 j5gudbhr3rvX
1peKj550B7lc+z+bPm5B7Uvvrm5Ru/vpgaPejH99SJe46mM/YdxhwpJPusRW ZR6uZJPc9BzW
Ng0Sf3FBTnauEc9IJVNwXByGBAyGkp1rPkH4o+YtvDA2yHXSUdP53nlPdkw7 +f28u56Z1LHL
O12Trcz/kZ+0mzBvSchvK0ZNHYHL9zufnzfE8stdo+ZsvqJLv/RQOD941IyB zy+Z0cH2yRM3
jpwc++6zHVKlqVt+u7lFx3qFv28ld57rfx9wcUpo9ZHPl29pOecxlyv33ZuG vi31n/3ui2nm
zAWjhw29yfH6+zfG1Zprsra8MXnL4AmvLGycZKc15zGjCvPffXzE21l3ffDS 5eaCQu3vU62J
3Kx1aRmaX6Z9/s5+w/L1rWCCYdXOT2bs/KT3iIVL7lj37LBJQ26XpD6vLFmY //Fdz01d1a3T
sIbWQM3Doa9TOvbOuDlBD8/+8uq0k/uP1kSjAl3+yCyfcEWwH/J6v7fa6tNN V+/b8EnHAQOk
Kiott3B1kgNuYuUm76mzYz7gVx+e7xeR7Ioj87OfpGFPRDhdVYRSVW1vev2S R16MdeyeMnDU
sgsveqZPuuRyY0Rl8ZSXBo+fvaR+ycIhT4wZHLrgwwHRku6pxGuk3eDZS+bt XzjklXEbLvqw
P4b3Dn320qgFW/o+/NK0K1pU5WZWhaDJB2g8darWQE2CReaFKsVQ+n3n9ujE kFqnyxaXlp6A
4TiCtcdCJii4SvZ/+Px6SRoSadU9xQLp7PvAA01Gjnzll/3XxDcO3b/lI6nv hBs7blm/nFSf
UQ+fNg0uebLvjOdWo1sb2yY6HG3LbJd+fPWpH/XgGrNgywOvLL+uuW3bihlP jLx9JO3TDq2Z
Pn7RD6Nnv9sjpWrdnIk4i9m1JXOR7VkPxpxQ6JoOkxmd8KNfh+nTy7mqjuu0 B99mb8g9uetg
DZvnodckQnXareyVV/Orztn/pdT44Za2k1UVdBAAIxNFRSnt+0qr8iQn5tuQ LmXOJHQps5ck
nHk7pO
Re: EPF Composer on Mac OS X? [message #651859 is a reply to message #489892] Tue, 01 February 2011 15:01 Go to previous messageGo to next message
No real name is currently offline No real name
Thanks AJ. I will give that a try.
Wendy.
Re: EPF Composer on Mac OS X? [message #654322 is a reply to message #651437] Tue, 15 February 2011 02:46 Go to previous messageGo to next message
Gerhard Schneider is currently offline Gerhard Schneider
AJ,
thanks for the information. Are you able to provide me with a short cookbook with the prerequisites and the procedure to perform the build?
Gerhard
Re: EPF Composer on Mac OS X? [message #656002 is a reply to message #489892] Wed, 23 February 2011 12:24 Go to previous messageGo to next message
Dallas Vaughan is currently offline Dallas Vaughan
Can someone upload the built product to a public site, and if it's known to work (confirmed by multiple Mac users), can someone on the EPF team post a link on the project page with the text that it is not officially supported/certified?
Re: EPF Composer on Mac OS X? [message #656008 is a reply to message #489892] Wed, 23 February 2011 12:45 Go to previous messageGo to next message
One more thing: Given that this post has received 2,778 views, it is very apparent that many people would like an official Mac version.
Re: EPF Composer on Mac OS X? [message #662289 is a reply to message #656002] Wed, 30 March 2011 02:26 Go to previous message
AJ Missing name is currently offline AJ Missing name
This bugzilla describes how you can built the product for Mac OSX
https://bugs.eclipse.org/bugs/show_bug.cgi?id=341305
HTH
Previous Topic:Is It Possible To Render EPF Output with a more modern CSS Compliant UI/UX Style?
Next Topic:helios build path problem
Current Time: Sun May 19 12:18:57 EDT 2013
Powered by FUDForum. Page generated in 0.02056 seconds
