Home » Eclipse Projects » Eclipse 4 » e4 Workbenchmodel Editor in 3.6
e4 Workbenchmodel Editor in 3.6 [message #662172] Tue, 29 March 2011 11:38 Go to next message
Christoph Keimel is currently offline Christoph Keimel
is it possible to install and use the "e4 Workbenchmodel Editor" in Eclipse SDK 3.6?
I would like to write an RCP Application with Helios, that uses e4. This seems to work fine except that there is no Editor for the Workbenchmodel. Using an XML Editor to edit by hand is no good, since the Workbenchmodel is quite cryptic.
Christoph
Re: e4 Workbenchmodel Editor in 3.6 [message #662232 is a reply to message #662172] Tue, 29 March 2011 15:06 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
At least it works in 3.7 so I guess it might work on 3.6 as well but why
not use Eclipse 4.1?
Tom
Am 29.03.11 08:38, schrieb Christoph Keimel:
> Hello,
> Eclipse SDK 3.6?
> Christoph
Re: e4 Workbenchmodel Editor in 3.6 [message #662319 is a reply to message #662232] Wed, 30 March 2011 05:03 Go to previous messageGo to next message
At the moment you could call it an experiment. If you could point me to the right plug-ins to install, I would be very grateful.
Christoph
Re: e4 Workbenchmodel Editor in 3.6 [message #662360 is a reply to message #662319] Wed, 30 March 2011 07:32 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
you'd probably have to add at least 2 repos:
http://download.eclipse.org/modeling/emf/emf/updates/2.7mile stones
http://download.eclipse.org/e4/updates/0.11-I-builds
Then install eclipse e4 tools ...
Later,
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: e4 Workbenchmodel Editor in 3.6 [message #662392 is a reply to message #662172] Wed, 30 March 2011 09:59 Go to previous messageGo to next message
it doesn't work, because there are dependencies, that go deeper:
Missing requirement:
org.eclipse.e4.tools.compat 1.0.0.v20110217-1700)
requires 'bundle org.eclipse.core.databinding 1.4.0
I am now using Indigo 3.7 which works great.
Christoph
Re: e4 Workbenchmodel Editor in 3.6 [message #662436 is a reply to message #662392] Wed, 30 March 2011 12:20 Go to previous messageGo to next message
Kevin Smit is currently offline Kevin Smit
Cannot install it on 4.1 M6 also:
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse e4 Modeled Workbench (Incubation) 0.9.1.v20110121-1000-7B9n7DFPJtAHosNOibp2U-26CA4 (org.eclipse.e4.ui.feature.feature.group 0.9.1.v20110121-1000-7B9n7DFPJtAHosNOibp2U-26CA4)
Software currently installed: Eclipse SDK 4.1.0.I20110329-2200 (org.eclipse.sdk.ide 4.1.0.I20110329-2200)
Only one of the following can be installed at once:
Eclipse Bindings Support 0.9.0.v20110312-1200 (org.eclipse.e4.ui.bindings 0.9.0.v20110312-1200)
Eclipse Bindings Support 0.9.0.v20110217-1730 (org.eclipse.e4.ui.bindings 0.9.0.v20110217-1730)
Eclipse Bindings Support 0.9.0.v20110320-2300 (org.eclipse.e4.ui.bindings 0.9.0.v20110320-2300)
Eclipse Bindings Support 0.9.0.v20101201-1400 (org.eclipse.e4.ui.bindings 0.9.0.v20101201-1400)
Cannot satisfy dependency:
From: Eclipse e4 Rich Client Platform 1.0.0.v20101206-1400-7IA37CFTy21UqDMStkB6mt (org.eclipse.e4.rcp.feature.group 1.0.0.v20101206-1400-7IA37CFTy21UqDMStkB6mt)
To: org.eclipse.e4.ui.bindings [0.9.0.v20110320-2300]
From: Eclipse e4 Modeled Workbench (Incubation) 0.9.1.v20110121-1000-7B9n7DFPJtAHosNOibp2U-26CA4 (org.eclipse.e4.ui.feature.feature.group 0.9.1.v20110121-1000-7B9n7DFPJtAHosNOibp2U-26CA4)
To: org.eclipse.e4.ui.bindings [0.9.0.v20110312-1200]
From: Eclipse Platform 4.1.0.v20110303-9IF70GdNFnUTMd2-CFDz-QD_eAInESefNt9ARU0xgcHG f (org.eclipse.platform.feature.group 4.1.0.v20110303-9IF70GdNFnUTMd2-CFDz-QD_eAInESefNt9ARU0xgcHG f)
To: org.eclipse.rcp.feature.group [4.1.0.v20110303-9ECRFiuFqGX6Kbfv0kTa7OeNTulC]
From: Eclipse RCP 4.1.0.v20110303-9ECRFiuFqGX6Kbfv0kTa7OeNTulC (org.eclipse.rcp.feature.group 4.1.0.v20110303-9ECRFiuFqGX6Kbfv0kTa7OeNTulC)
To: org.eclipse.e4.rcp.feature.group [1.0.0.v20101206-1400-7IA37CFTy21UqDMStkB6mt]
From: Eclipse Project SDK 4.1.0.v20110303-7T7fA7F8Yw_bVbIsTz-gFcejoUNkZRssWoR7mCPz0215 Y (org.eclipse.sdk.feature.group 4.1.0.v20110303-7T7fA7F8Yw_bVbIsTz-gFcejoUNkZRssWoR7mCPz0215 Y)
To: org.eclipse.platform.feature.group [4.1.0.v20110303-9IF70GdNFnUTMd2-CFDz-QD_eAInESefNt9ARU0xgcH Gf]
From: Eclipse SDK 4.1.0.I20110329-2200 (org.eclipse.sdk.ide 4.1.0.I20110329-2200)
To: org.eclipse.sdk.feature.group [4.1.0.v20110303-7T7fA7F8Yw_bVbIsTz-gFcejoUNkZRssWoR7mCPz021 5Y]
Re: e4 Workbenchmodel Editor in 3.6 [message #662453 is a reply to message #662436] Wed, 30 March 2011 12:44 Go to previous messageGo to next message
Looks like you try to install the Modeled Workbench-Feature. This is not
needed to get the model tooling working.
Tom
Am 30.03.11 09:20, schrieb Kevin Smit:
> Only one of the following can be installed at once: Eclipse Bindings
Re: e4 Workbenchmodel Editor in 3.6 [message #662546 is a reply to message #662453] Thu, 31 March 2011 00:55 Go to previous message
OK, thanks for the support
Previous Topic:obsolete plugins in e4?
Next Topic:adding a ILookupStrategy in an AddOn (to provide access to spring beans)
Current Time: Thu May 23 08:17:30 EDT 2013
Powered by FUDForum. Page generated in 0.03032 seconds
