Home » Archived » M2M (model-to-model transformation) » [ATL] MoDisco .javaxmi files(PSM2PIM Transformation)
[ATL] MoDisco .javaxmi files [message #656618] Sun, 27 February 2011 10:28 Go to next message
Rob is currently offline Rob
Hi!
I am working on a Modeling Project with MoDisco with the full workflow from Reverse Engineering to M2M to Forward Engineering.
I retrieve a Model from an application with MoDisco Discoverer which results in a x.javaxmi file.
For platform independence i want to transform this model in a PIM model but within the same metamodel (java.xmi or ecore?) but with less information.
I did some UML transformation earlier and I remember that I got a copy of the source model when I startet the ATL Transformation with an empty atl-file (without any rules).
I wanted to test the atl-file for the javaxmi transformation now without any rules but I keep getting an empty result file.
Is there any special meta model definition to use with the javaxmi transformation?
I am using: http://www.eclipse.org/MoDisco/Java/0.2.incubation/java for the uri.
Many thanks in advance
Re: [ATL] MoDisco .javaxmi files [message #660944 is a reply to message #656618] Tue, 22 March 2011 09:01 Go to previous messageGo to next message
Thanasis Naskos is currently offline Thanasis Naskos
Hello George,
I'm not aware of the "empty atl-file" but working on a project this period, I found something that could be useful in your case...
It's an atl transformation file that produces atl code for coping any model you want....
the link to this file
http://soft.vub.ac.be/viewvc/UML2CaseStudies/uml2cs-transfor mations/EModelCopyGenerator.atl
Smile
Re: [ATL] MoDisco .javaxmi files [message #662022 is a reply to message #660944] Mon, 28 March 2011 18:34 Go to previous message
Thx 4 your answer, Thanasis.
I was able to solve this problem. It was just a mistake with from/refine keyword in atl module.
But anyway I am running into some strange problems.
Still on javaxmi model based on java.ecore doing transformation from java to java - same metamodel.
I tried to create lazy rules to transfer type information from FieldDeclarations and Parameters, which works so far.
lazy rule F2F {
	from
		s: Java!FieldDeclaration
	to
		t : Java!FieldDeclaration (
			type <- thisModule.TA2TA(f),
lazy rule TA2TA {
	from
		f: Java!TypeAccess
	to
		t : Java!TypeAccess (
			type <- if (f.type.type.oclIsKindOf(Java!PrimitiveTypeVoid))
I am not quite sure, why I have to access type twice here - but this way the checks work - although I can not figure it out from the metamodel. From my understanding it should work with f.type.olcIsKindOf ...
the same code works for Parameters (i.e. SingleVariableDeclarations)
but when I try to transfer returnType in MethodDeclaration I get an error, that type is not valid for MethodDeclaration.
Maybe I am missunderstanding some concepts of ATL. But I dig through the Metamodel and from my point of view it should not matter whether it is type in SingleVariableDeclaration/AbstractVariablesContainer or returnType in MethodDeclaration.
Any hints would be appreciated.
Thx
Rob
[Updated on: Thu, 31 March 2011 05:14]
Report message to a moderator
Previous Topic:public2private launch
Next Topic:[QVTo] How to find specific object in a list
Current Time: Thu May 23 23:07:19 EDT 2013
Powered by FUDForum. Page generated in 0.01755 seconds
