| Unable to create class BindingProcessingAddon [message #660628] |
Sun, 20 March 2011 07:53  |
Karl Weber Messages: 63 Registered: September 2010 |
Member |
I created a new E4-application from scratch with Eclipse SDK 4.1M6.
It has no java classes so far, only a product and an application definition.
The application definition contains the following
- the six AddOns that are also present in the contacts demo
- one TrimmedWindow
On running the product, I get the exception
!ENTRY org.eclipse.e4.ui.workbench 4 0 2011-03-20 12:38:59.229
!MESSAGE Unable to create class 'org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon' from bundle '35'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
What are the minimal requirements for an E4-application?
P.S. Since I got various other exceptions before, I successively added some plug-ins as required bundles to the plug-in definition of my application, but I have no idea, what (else) is really necessary... So here my current MANIFEST.MF
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: App
Bundle-SymbolicName: de.gps.app;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Require-Bundle: org.eclipse.core.runtime;bundle-version="3.7.0",
org.eclipse.e4.ui.workbench;bundle-version="0.9.1",
org.eclipse.e4.ui.workbench.swt;bundle-version="0.9.1",
org.eclipse.equinox.ds;bundle-version="1.3.0",
org.eclipse.e4.ui.bindings;bundle-version="0.9.0",
org.eclipse.e4.core.services;bundle-version="0.9.1"
Bundle-Vendor: as
The product contains all required plug-ins.
| Re: Unable to create class BindingProcessingAddon [message #660633 is a reply to message #660628] |
Sun, 20 March 2011 10:01   |
Member |
A minimal E4-application seems to involve the following:
[1] Create a bundle for the application with no java sources. The MANIFEST.MF has no dependencies.
[2] Create an Application.e4xmi. It should (must?) have the six AddOns from the contact demo and a TrimmedWindow.
[3] Create a product and add the following four bundles:
- the bundle of the application
- org.eclipse.equinox.ds
- org.eclipse.equinox.event
- org.eclipse.e4.ui.workbench.renderers.swt
[4] Press add all required bundles
Now the application starts up and shows an empty window -- as expected. The exception concerning BindingProcessingAddon, however, still occurs. What is still missing?
Edit:
The problem seems to be that I added the add-on
platform:/plugin/org.eclipse.e4.ui.workbench.swt/org.eclipse .e4.ui.workbench.swt.util.BindingProcessingAddon
to my Application.e4xmi without having defined a BindingTable. After I removed this add-on everything seems to work fine.
Is there any documentation about when which add-ons are necessary?
[Updated on: Sun, 20 March 2011 10:45] Report message to a moderator
| Re: Unable to create class BindingProcessingAddon [message #660638 is a reply to message #660628] |
Sun, 20 March 2011 10:46   |
Thomas Schindl Messages: 4463 Registered: July 2009 |
This looks like a bug in the M6. The offending code is in BindingCopies
which is not initialized appropriately in a pure e4 application!
Tom
Am 20.03.11 04:53, schrieb Karl Weber:
> definition.
> one TrimmedWindow
> 'org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon ' from
> bundle '35'
> !STACK 0
> at
> org.eclipse.e4.core.internal.di.MethodRequestor.execute(Meth odRequestor.java:63)
> Bundle-Name: App
> Bundle-Vendor: as
| Re: Unable to create class BindingProcessingAddon [message #660639 is a reply to message #660638] |
Sun, 20 March 2011 11:09   |
I've logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=340508 The
only possibility to fix the problem is to add org.eclipse.ui.workbench
(which is the compat layer) to your launch configuration which naturally
is by definition a stupid thing and we are going to fix this ASAP.
Thanks for reporting the problem and is very embarrassing that we didn't
spot such a problem ourselves.
Tom
Am 20.03.11 07:46, schrieb Tom Schindl:
> Tom
>> definition.
>> one TrimmedWindow
>> bundle '35'
>> !STACK 0
>> at
>> Bundle-Name: App
>> Bundle-Vendor: as
FUDForum. Page generated in 0.04873 seconds
