Home » Modeling » GMF (Graphical Modeling Framework) » Question according to http://wiki.eclipse.org/GMF_Constraints
Question according to http://wiki.eclipse.org/GMF_Constraints [message #661760] Sun, 27 March 2011 11:34 Go to next message
Ralph Gerbig is currently offline Ralph Gerbig
Hi all,
I did not find a better way to discuss this article. Maybe there is one existing. The artcle says:
Java is usually the option when the expression logic represents excessive complexity or requires direct access to Ecore reflective API
In my opinion this is not 100% right. I can access the Ecore API by using this cast:
self.oclAsType(ecore::EObject)
I think this option should be documented somewher. What do others think?
Ralph
Re: Question according to http://wiki.eclipse.org/GMF_Constraints [message #661768 is a reply to message #661760] Sun, 27 March 2011 13:17 Go to previous message
Ed Merks is currently offline Ed Merks
Ralph,
I think the OCL folks have documented how to use it for constraints;
something that wasn't so easy before the EMF 2.6 release...
Given the documentation is in the wiki, you should feel free to
contribute to it.
ralph. wrote:
> Hi all,
> Quote:
> using this cast:
> Ralph
Previous Topic:GMF Model to XML
Next Topic:Creating EditPart + setting size no longer working
Current Time: Wed May 22 19:15:39 EDT 2013
Powered by FUDForum. Page generated in 0.01613 seconds
