Home » Eclipse Projects » EclipseLink » OneToMany list contains null entries when using OrderBy and shared cache
OneToMany list contains null entries when using OrderBy and shared cache [message #661117] Wed, 23 March 2011 05:14 Go to next message
Christoph John is currently offline Christoph John
we have a problem in our software when using EclipseLink with a OneToMany relationship. A colleague of mine already posted to the Glassfish forum some time ago:
http://www.java.net/forum/topic/glassfish/glassfish/gf-v3-ec lipselink-onetomany-list-contains-null-entries
@Entity
public class A {
@OneToMany( mappedBy="aInstance" )
@OrderBy( "someId" )
private List<B> list = new ArrayList<B>();
@Entity
public class B {
@ManyToOne
@JoinColumn( name="id" )
private A aInstance;
To get an instance of A the EntityManager.find() method is used. This returns an instance of A. Now
the list is processed using a for-each loop.
for ( B bElement : list ) {
// do something with bElement
Sometimes one of the elements in the list is null. If this is the case I have checked the following:
- Logged size of the list (e.g. 30)
- Checked database. The database contains 30 valid entries which should be in the list.
- The last element in the list was null.
- The last element was added in the previous transaction.
Another post we have found here: http://www.theserverside.com/discussions/thread.tss?thread_i d=60269
The strange thing is that it is working when turning the shared cache off, so I suspect that this is a bug.
In the meantime we have also tested this with EclipseLink 2.2-M6 and Glassfish 3.1 but the error still appears.
Any help is much appreciated since the disabled cache leads to a performance drop of about 35% for our application. We would not like to implement a caching concept or introduce some ordering concept of our own to work around this bug since this would mean to change the code in very much locations. Let alone the necessary effort to test the whole thing thoroughly afterwards.
Best regards and thanks in advance,
Chris
Re: OneToMany list contains null entries when using OrderBy and shared cache [message #661177 is a reply to message #661117] Wed, 23 March 2011 09:38 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris Delahunt
This issue looks similar to https://bugs.eclipse.org/bugs/show_bug.cgi?id=247041 but it was fixed already, so a reproduction will be needed so the problem can be stepped through to see where things are going wrong.
Please file a bug with a test case that can reproduce the issue. The simpler the test case the better.
As for workarounds, an alternative is to refresh the Image object. This might also have to do with change tracking, so another option might be to try different change tracking options as described here:
http://wiki.eclipse.org/Using_EclipseLink_JPA_Extensions_ (ELUG)#Using_EclipseLink_JPA_Extensions_for_Tracking_Changes
This will also help narrow down the problem if you determine one of the settings shows the problem but others do not.
Best Regards,
Chris
Re: OneToMany list contains null entries when using OrderBy and shared cache [message #661321 is a reply to message #661117] Thu, 24 March 2011 04:55 Go to previous messageGo to next message
Hi Chris,
thanks for the reply. Until now we could not condense a reproducilbe test case for this. But come on guys, there must be an official bug report somewhere. Wink
Found this:
http://download.oracle.com/docs/cd/E18930_01/html/821-2418/g bxjh.html#gezxw
Even Oracle mentions in the GF3.1 developer guide:
Using @OrderBy with a Shared Session Cache
Setting @OrderBy on a ManyToMany or OneToMany relationship field in which a List represents the Many side doesn't work if the session cache is shared. Use one of the following workarounds:
Have the application maintain the order so the List is cached properly.
Refresh the session cache using EntityManager.refresh() if you don't want to maintain the order during creation or modification of the List.
Disable session cache sharing in persistence.xml as follows:
<property name="eclipselink.cache.shared.default" value="false"/>
Chris
Re: OneToMany list contains null entries when using OrderBy and shared cache [message #661394 is a reply to message #661321] Thu, 24 March 2011 09:58 Go to previous message
That reference is out of context, and is not a warning that orderby does not work. It is a warning that the objects read in might come from the cache, but the @OrderBy only applies when the collection is read in from the database - essentially stating that the JPA provider does not maintain the list order for you. So if you make changes to the list, the next time you read the owner, you may see the list in the same order as you left it in - depending on if the object was in the cache or if it had to be built/refreshed from the database since your changes were made.
There was a problem with nulls, but is was a specific situation involving attribute change tracking and merging that does not seem to be occuring here. As your attempt to reproduce shows, it is not a common situation, or one that we have seen before (that I am aware of) and likely a product of a specific set of conditions in your application. As the last issue I was aware of dealt with change tracking, I figure that is a good place to start in isolating the issue though it is difficult to guess.
Best Regards,
Chris
Previous Topic:Duplicate key error when persisting a relationship
Next Topic:Some questions about logging
Current Time: Fri May 24 12:31:44 EDT 2013
Powered by FUDForum. Page generated in 0.01649 seconds
