| 'Parameter Selection Page' window [message #661016] |
Tue, 22 March 2011 13:45  |
anna.w.teittinen Messages: 23 Registered: February 2011 |
Junior Member |
When the .rptdesign file is run within BIRT on Eclipse, and if user input parameter for the query is required, a "Parameter Selection Page" window is displayed.
Is it possible for the "Parameter Selection Page" to be displayed from within a Java application (e.g. stand-alone app or RCP app) when using the BIRT RE api to generate a report? As easy it is though, I am just hoping I do not have to create a window to prompt the user for parameter input. I would like to reuse BIRT's "Parameter Selection Page" if possible.
Thanks alot,
--Anna
| Re: 'Parameter Selection Page' window [message #661069 is a reply to message #661016] |
Tue, 22 March 2011 19:55  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
If you are using the re api you will need to create a parameter entry
screen. If you are building an rcp app you could always use the viewer
plugin and render it to a SWT Browser.
Jason
On 3/22/2011 1:45 PM, Anna T. wrote:
> Hello,
> Thanks alot,
> --Anna
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.01586 seconds
