| Create new SysML diagrams [message #651180] |
Fri, 28 January 2011 04:06  |
Dragos Messages: 1 Registered: January 2011 |
Junior Member |
I tried to create some SysML Diagrams by using a package contextual menu. Even if my model is a SysML one, in the New Diagram option it offers the possibility to create only the UML diagrams. To create a new SysML Diagram I have to click on the model package (the root package) and there I can create one which I move into the desired package. Is there another way to do it or this feature isn't implemented yet.
Thank you,
Dragos
| Re: Create new SysML diagrams [message #660658 is a reply to message #651180] |
Sun, 20 March 2011 14:18  |
Roby Gamboa Messages: 1 Registered: September 2010 |
Junior Member |
Hi, folks:
I'm seeing the same problem. The work-around that I use is, in the Model
Explorer, add the diagram that I want to the top-level model, then drag
the diagram to the sub-package or sub-model that I want it to be in.
Currently this only works for requirement or block definition diagrams.
For the other diagram types, I use the closest equivalent UML diagram
type, and manually add SysML child elements onto the diagram. This
strikes me as being extremely flaky. Any idea when this behavior will be
fixed?
Roby Gamboa
On 01/28/2011 01:06 AM, Dragos wrote:
> Hello,
> Thank you,
> Dragos
FUDForum. Page generated in 0.02219 seconds
