| How to create a diagram connection using properties view ? [message #660565] |
Sat, 19 March 2011 10:03 |
Achim E. Messages: 7 Registered: July 2009 Location: Germany |
Junior Member |
Hi all,
i'm using a generated gef properties view to change diagram/model attributes. most of all works fine. if i change attributes the model/diagram was updated. but i have a problem with model attributes designed as relations between model elements. if i use the property view to add/remove relations, the diagram was not updates. the model changes are done, because when i close and re-open the diagram all is fine. can please anyone explain how to handle model/diagram changes for relations/connections because i want to replace the generated tabbed property by my own definition and i would like to know how to handle this problem. thx in advance.
FUDForum. Page generated in 0.01596 seconds
