Home » Eclipse Projects » SeMantic Information Logistics Architecture (SMILA) » What do the DeltaIndexing?
What do the DeltaIndexing? [message #660382] Fri, 18 March 2011 04:49 Go to next message
SMILANewBee is currently offline SMILANewBee
Member
we are looking at the DeltaIndexing and we are not sure about it. What it is doing? Our first assumption was that a crawled page isn't crawled twice if it was not changed on the web. But after considering the source we discover that delta indexing doesn't affect the crawling process but records changes of the records. So the change of a record is traceable over time.
Re: What do the DeltaIndexing? [message #660785 is a reply to message #660382] Mon, 21 March 2011 11:32 Go to previous message
Igor Novakovic is currently offline Igor Novakovic
Member
Under delta indexing we consider a revisiting/reindexing of a dataset.
Thereby we want to reindex/reprocess only data objects which have
changed since the last crawling of the dataset so that we can reflect
those changes in index structures and/or ontologies created during
initial crawling.
A quote from
http://wiki.eclipse.org/SMILA/Documentation/DeltaIndexingMan ager states
exactly what it does:
"The DeltaIndexingManager stores information about the last modification
of each record and can determine if a record has changed since its last
processing..."
Cheers
Igor
Am 18.03.2011 09:49, schrieb SMILANewBee:
> Hello,
> over time.
Previous Topic:Nightly builds are now also available for Mac OS X!
Next Topic:New SMILA tryout
Current Time: Sat May 25 12:24:06 EDT 2013
Powered by FUDForum. Page generated in 0.04587 seconds
