Home » Modeling » GMF (Graphical Modeling Framework) » Display containment through link
Display containment through link [message #651393] Sun, 30 January 2011 06:09 Go to next message
Ralph Gerbig is currently offline Ralph Gerbig
I have two nodes (A and B) A is having a reference to B. This reference is set containment true. I only know how to display B inside A, but not how to make the containmen visible by drawing a line. Here is a Example:
-------         A.containment      ------
|Node A| -----------------------> |Node B|
When I define a link on the containment using the target feature I cannot start drawing a line from A to B.
Does anyone know how to solve this?
Thanks in advance!
Ralph
Re: Display containment through link [message #651478 is a reply to message #651393] Mon, 31 January 2011 05:35 Go to previous messageGo to next message
Romain Bioteau is currently offline Romain Bioteau
Member
Hello Raplh,
I think there is a semantic issue in what you are trying to achieve. The ecore containment can't be map directly with your "domain" containment.
You should create a ContainmentConnection object in your domain to represent your containment relationship and map it to Connection figure.
Hope that it's clear enough
Romain
R&D Engineer at BonitaSoft
Re: Display containment through link [message #651705 is a reply to message #651478] Tue, 01 February 2011 06:14 Go to previous messageGo to next message
Hi Romain,
adding an extra meta model element is what I wanted to get around. Is there no way to do this by children/containment feature? I could not find a good description of those two. I have also seen, that there is a way to affix containments outside of a container but could not find any documentation, too.
Ralph
Re: Display containment through link [message #651892 is a reply to message #651393] Tue, 01 February 2011 17:28 Go to previous messageGo to next message
Aurelien Pupier is currently offline Aurelien Pupier
Are you talking about boundary items?
Aurélien Pupier - BonitaSoft S.A.
My blog
My company Eclipse-related blog
Re: Display containment through link [message #651990 is a reply to message #651892] Wed, 02 February 2011 06:23 Go to previous messageGo to next message
I have seen this tutorial: http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-affi xed-nodes/ . I do not know how to do this with GMF. Would it be possible to have this with a line between the outer element and the container? Maybo border items would solve my problem. My use case would be something like having a UML Class and displaying the methods and fields outside of the class. I think border items would be great as they are deleted together with the containing node. How could I realize such a thing?
Thanks!!
Ralph
Re: Display containment through link [message #659693 is a reply to message #651990] Tue, 15 March 2011 05:38 Go to previous message
Hi Ralph,
it looks like phantom nodes are exactly what you need: http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-phan tom-nodes/
Ralph
Previous Topic:modify pop up menu in canvas
Next Topic:Finding difficulties to open a GMF editor from another GMF editor
Current Time: Fri May 24 08:31:58 EDT 2013
Powered by FUDForum. Page generated in 0.02385 seconds
