Home » Language IDEs » Java Development Tools (JDT) » Ant password InputHandler(Is there a password InputHandler in eclipse)
Ant password InputHandler [message #659631] Mon, 14 March 2011 16:57
JR  is currently offline JR
When running ant scripts from the command line you can specify that you don't want to echo your keystrokes (password input).
<input message="password:>" addproperty="password">
      <handler classname="org.apache.tools.ant.input.SecureInputHandler" />
</input>
Is there a class to do the same when running my ant script from inside eclipse? Eclipse "hangs" when I use the above handler from within eclipse.
The eclipse handler seems to be:
org.eclipse.ant.internal.ui.antsupport.inputhandler.AntInputHandler
which creates a InputDialog() and InputDialog instantiates a org.eclipse.swt.widgets.Text widget. The Text widger has a style of "PASSWORD" so it might be simple to implement a PasswordInputDialog and a AntPasswordInputHandler to allow inputting passwords.
Eclipse Version Information:
Eclipse Java EE IDE for Web Developers.
Version: Helios Release
Build id: 20100617-1415
JR
Previous Topic:Plugin context menu conditions
Next Topic:Problems with how to begin my android apps project?? HELP!!!?
Current Time: Sat May 25 13:06:19 EDT 2013
Powered by FUDForum. Page generated in 0.05356 seconds
