| [Xpand] super() equivalent for DEFINE methods? [message #659411] |
Sun, 13 March 2011 13:51  |
Glenview Jeff Messages: 79 Registered: September 2010 |
Member |
If CHILD inherits from PARENT, and I want to factor out common behavior, there appears to be no language support for calling the DEFINE of the superclass. Maybe this is because multiple inheritance is allowed?
Is there any way to accomplish this in Xpand? Acceleo suports this.
Thanks!
Jeff
«DEFINE someOtherDefine FOR Z»
«EXPAND implClass FOREACH listOfParentsAndChildren»
«ENDDEFINE»
«DEFINE implClass FOR PARENT»
common behavior goes here
«ENDDEFINE»
«DEFINE implClass FOR CHILD»
«SUPER()» (This feature doesn't appear to exist)
specialized behavior
«ENDDEFINE»
[Updated on: Sun, 13 March 2011 13:55] Report message to a moderator
| Re: [Xpand] super() equivalent for DEFINE methods? [message #659609 is a reply to message #659607] |
Mon, 14 March 2011 15:37  |
Christian Dietrich Messages: 4426 Registered: July 2009 |
even if there would be something like a super call you have still the same problem:
the template for the parent class has to produce something that can be embedded in the stuff the child class - so you have the same problem as if you prepare "extension" points in the parent class.
maybe you can have a look at xpands aop feature and provide the child classes behaviours as aspects - but this might a bit ugly since the polymorphism stuff might not work as you expect / need it.
i guess you will have the same problem in xtend2 caused by muliple inheritance but i do not exactly know this since i did not play arround with xtend2 in that detail.
Update: I actually played a bit more arround with Xtend2 and it seems that you can solve the problem by Casting and en/disabling polymorphic dispatch.
package test
import java.util.List
class Test {
doSomeStuff(Model m) '''
model
«FOR e : m.getElements()»
«doSomeStuff4E(e)»
«ENDFOR»
endmodel
dispatch doSomeStuff4E(Element e) '''
element commons stuff
dispatch doSomeStuff4E(AElement e) '''
«_doSomeStuff4E(e as Element)»
aelement «e.name»
dispatch doSomeStuff4E(BElement e) '''
belement «e.name»
~Christian
[Updated on: Mon, 14 March 2011 17:49] Report message to a moderator
FUDForum. Page generated in 0.08308 seconds
