Home » Eclipse Projects » DTP » How can I import ModelBase package into my own application?(ModelBase)
How can I import ModelBase package into my own application? [message #658138] Sun, 06 March 2011 21:17 Go to next message
No real name is currently offline No real name
I want to employ the SQL Query Model in ModelBase module into a command-line based application. Who can tell me how could I do this? Does it offer public APIs to cosumer? Thanks.
Re: How can I import ModelBase package into my own application? [message #659309 is a reply to message #658138] Fri, 11 March 2011 21:27 Go to previous message
Brian Payton is currently offline Brian Payton
You can find a pretty good example of using the SQL Query Model in a
command-line environment in the test plugin for the SQL Query Parser,
particularly the SQLQueryParserInteractiveTest class.
The test plugin is named
org.eclipse.datatools.sqltools.parsers.sql.query.test, and you can
download it from DTP's CVS repository:
Host: dev.eclipse.org
Repository path: /cvsroot/datatools
Module:
org.eclipse.datatools.sqltools/plugins/org.eclipse.datatools .sqltools.parsers.sql.query.test
Connection type: pserver
User: anonymous
Previous Topic:CSV and XML "Databases"
Next Topic:Need Help about ODA Ecore
Current Time: Wed May 22 13:20:19 EDT 2013
Powered by FUDForum. Page generated in 0.01518 seconds
