Home » Archived » IAM (Eclipse Integration for Apache Maven) » classifier dependency not working?
classifier dependency not working? [message #659103] Thu, 10 March 2011 21:56 Go to next message
No real name is currently offline No real name
I'm having problems getting a <classifier> dependency in pom.xml file to work. It works fine using maven standalone but not when using IAM/Q4E.
In one project I'm using the 'attachClasses' directive in the maven-war-plugin to create a jar file. In the repository this creates a war artifact and a jar artifact with a classifier of 'classes' (this is configurable).
In a second project (also of type war) I'm including this dependency:
<dependency>
<groupId>group</groupId>
<artifactId>project1</artifactId>
<version>1.0-SNAPSHOT</version>
<classifier>classes</classifier>
</dependency>
When I build this project using 'mvn install' it works fine. When I load the project in Eclipse it doesn't seem to bring in the dependency.
Is it possible to get this to work? If so, how can I troubleshoot. I would rather not refactor our structure to split it into 2 projects as there is no other reason to do this other than this issue.
Thanks.
icon9.gif  Re: classifier dependency not working? [message #660087 is a reply to message #659103] Wed, 16 March 2011 14:37 Go to previous messageGo to next message
Is this forum still active? Don't see much traffic. Sad
Re: classifier dependency not working? [message #660094 is a reply to message #659103] Wed, 16 March 2011 15:06 Go to previous message
Carlos Sanchez is currently offline Carlos Sanchez
Member
it might confuse Eclipse, because when a war depends on another war it
tries to do war overlay. It's better with Maven to have 2 projects, one
jar with the classes and a war depending on it
On 3/11/11 3:56 AM, aarosso@gmail.com wrote:
> configurable).
> <dependency>
> </dependency>
> Thanks.
Previous Topic:Dependency management with Nexus references
Next Topic:Problem with maven build for SWTBot Tests
Current Time: Sun May 19 12:03:40 EDT 2013
Powered by FUDForum. Page generated in 0.01547 seconds
