Home » Modeling » BPEL Designer » Array as input in BPEL
Array as input in BPEL [message #513847] Thu, 11 February 2010 08:53 Go to next message
Christy  is currently offline Christy
Hi to everybody!
I have problems with getting arrays as input (or output) in bpel. I use Eclipse BPEL designer to design the process. the proces is simple: I just call one web-service. But the problem is that this web-service gets array as input. It means that the input value of the process must be array. how can I do it? Because when I use Assign "from" "to" I can't pass array throw process input. I just can pass only a String value. How can I change types of input/output values in process?
Thank you!
Re: Array as input in BPEL [message #515737 is a reply to message #513847] Fri, 19 February 2010 22:13 Go to previous messageGo to next message
grid.qian  is currently offline grid.qian
Member
These is a wsdl question. You should read the wsdl specification.
Re: Array as input in BPEL [message #658887 is a reply to message #513847] Thu, 10 March 2011 05:18 Go to previous message
sab  is currently offline sab
you can use this totorail :BPEL's example: Working with complex types and array type :
http://www-inf.int-evry.fr/cours/WebServices/TP_BPEL/complex type.html
Previous Topic:"element" attribute for OnEvent elements
Next Topic:deploy simple bpel project
Current Time: Mon May 20 02:16:40 EDT 2013
Powered by FUDForum. Page generated in 0.03994 seconds
