Home » Eclipse Projects » BIRT » Simple Java Application Creating and Saving Different Charts
Simple Java Application Creating and Saving Different Charts [message #658614] Wed, 09 March 2011 04:26 Go to next message
Carl Emmoth is currently offline Carl Emmoth
The application will:
1) Fully configurable paths and database selection
2) Make charts (pie, line and 3d bars)
3) Save it to design, report and html
4) View the html in a JEditorPane
The application will use the test database to retrieve data with some restrictions. Only the two first columns from the sql-selection will be used, and the first one must be in string-format.
1) You need to include the follwing jar-files (included in birt engine, model and chart api):
engineapi.jar
coreapi.jar
com.ibm.icu...jar
modelapi.jar
js.jar
org.apache.commons.codec...jar
org.eclipse.birt.chart.engine...jar
org.eclipse.birt.chart.reportitem.source...jar
org.eclipse.emf.ecore...jar
org.eclipse.emf.common...jar
org.eclipse.emf.ecore.xmi...jar
scriptapi.jar
2) Create icons in "./resources" folder or ignore them.
3) If you need to write a report, change the IRunAndRenderTask to one IRunTask and one IRenderTask.
Source:
Pastbin:
http://pastebin.com/VUvyDsgW
Link to other forums:
"Charts Example with JDBC"
Home / DevShare / Deploying BIRT Reports
http://www.birt-exchange.org/org/devshare/deploying-birt-rep orts/1171-charts-example-with-jdbc/
[Updated on: Wed, 09 March 2011 04:28]
Report message to a moderator
Re: Simple Java Application Creating and Saving Different Charts [message #658642 is a reply to message #658614] Wed, 09 March 2011 06:07 Go to previous message
Get the jars from the Report Engine. Here's for Birt 2.5.2:
http://download.eclipse.org/birt/downloads/build.php?build=R -R1-2_5_2-201002221500
Also include the following jars (the sample database):
[report engine folder]\ReportEngine\plugins\org.eclipse.birt.report.data.od a.jdbc...\odajdbc.jar
[report engine folder]\ReportEngine\plugins\org.eclipse.birt.report.data.od a.sampledb...\sampledb.jar
Remember to have valid folders or create them!
Previous Topic:Problem importing BIRT code in GWT application
Next Topic:create a report in code
Current Time: Fri May 24 05:53:26 EDT 2013
Powered by FUDForum. Page generated in 0.02398 seconds
