Home » Eclipse Projects » EGit » Create Patch (standard format) from History view creates patch relative to a project
Create Patch (standard format) from History view creates patch relative to a project [message #658174] Mon, 07 March 2011 04:55 Go to next message
Esteban Dugueperoux is currently offline Esteban Dugueperoux
I want to create a patch in standard format (not git format) from a
local commit, then I create one from the history view by taking the last
local commit (a commit recording changes from several workspace
projects). The generated patch has path relative to project then I can't
apply it to a svn working copy (for example). While with the svn team
provider we have a option to create/apply a patch to a specific project
or to the whole workspace.
It is a know problem or a mistake of my part?
Regards.
Re: Create Patch (standard format) from History view creates patch relative to a project [message #658229 is a reply to message #658174] Mon, 07 March 2011 08:55 Go to previous messageGo to next message
Stefan Lay is currently offline Stefan Lay
Hi Esteban,
this is a missing feature in EGit. There was not much focus on patch support
in EGit so far. A reason could be that the EGit development itself does not
use patch files and therefore the developers are not familiar with the most
common use cases.
It would be very helpful if you could open a bug at
https://bugs.eclipse.org
Thanks and Regards,
Stefan
"Esteban DUGUEPEROUX" <dugueperoux.esteban@free.fr> wrote in message
news:il29lk$690$1@news.eclipse.org...
> I want to create a patch in standard format (not git format) from a local
> commit, then I create one from the history view by taking the last local
> commit (a commit recording changes from several workspace projects). The
> generated patch has path relative to project then I can't apply it to a
> svn working copy (for example). While with the svn team provider we have a
> option to create/apply a patch to a specific project or to the whole
> workspace.
> Regards.
Re: Create Patch (standard format) from History view creates patch relative to a project [message #658259 is a reply to message #658229] Mon, 07 March 2011 10:30 Go to previous messageGo to next message
Eclipse User
Originally posted by: esteban.dugueperoux.obeo.fr
On 07/03/2011 14:55, Stefan Lay wrote:
> Hi Esteban,
> support in EGit so far. A reason could be that the EGit development
> itself does not use patch files and therefore the developers are not
> familiar with the most common use cases.
> Thanks and Regards,
> Stefan
>> last local commit (a commit recording changes from several workspace
>> can't apply it to a svn working copy (for example). While with the svn
>> team provider we have a option to create/apply a patch to a specific
>> project or to the whole workspace.
>> Regards.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=339099
Re: Create Patch (standard format) from History view creates patch relative to a project [message #658294 is a reply to message #658174] Mon, 07 March 2011 12:37 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin Rosenberg
On 2011-03-07 10.55, Esteban DUGUEPEROUX wrote:
The git format patches generated by todays EGit don't use any extensions
and work with any decent patch tool I know of. Sometimes you have to
tell the tool to drop one level of directoris (the a/ b/ part), some
figure it out. I'm not sure about SVN, but the default patch tool in
Eclipse works.
-- robin
Re: Create Patch (standard format) from History view creates patch relative to a project [message #658359 is a reply to message #658294] Tue, 08 March 2011 02:46 Go to previous message
Eclipse User
> Eclipse works.
> -- robin
Yes it works thanks for this info.
Previous Topic:Can EGit support projectSet.psf?
Next Topic:JGit JavaDoc and get log only certain range
Current Time: Sun May 19 13:54:36 EDT 2013
Powered by FUDForum. Page generated in 0.01559 seconds
