Home » Eclipse Projects » JFace » [databinding] JUnit tests, howto ?
[databinding] JUnit tests, howto ? [message #658044] Sat, 05 March 2011 08:20 Go to next message
Marco Maccaferri is currently offline Marco Maccaferri
Ho do you run JUnit tests with databinding ?
I can't find a way to set the default realm so every attempt to bind
widgets fails with an exception. How do you test databinding ?
Marco.
Re: [databinding] JUnit tests, howto ? [message #658156 is a reply to message #658044] Mon, 07 March 2011 03:14 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
The default realm is in RCP created by workbench for you so you need to
do it in your JUnit-Tests your own.
My JUnit code looks like this:
public void testA() {
Realm.runWithDefault(SWTObservables.getRealm(Display.getCurr ent()),new
Runnable() {
public void run() {
_testA();
private void _testA() {
// Real tests
Tom
Am 05.03.11 14:20, schrieb Marco Maccaferri:
> Marco.
Re: [databinding] JUnit tests, howto ? [message #658234 is a reply to message #658156] Mon, 07 March 2011 09:16 Go to previous messageGo to next message
Yes, I was hoping to find a ready to use solution.
I wrote a simple TestCase subclass that overrides the run(TestResult)
method:
public class DatabindingTestCase extends TestCase {
public void run(final TestResult result) {
Realm.runWithDefault(SWTObservables.getRealm(Display.getDefa ult()), new
Runnable() {
public void run() {
DatabindingTestCase.super.run(result);
If you derive the tests from that class they should all run with the
default Realm set without other changes. Looks to work right so far.
Marco.
Re: [databinding] JUnit tests, howto ? [message #658237 is a reply to message #658234] Mon, 07 March 2011 09:35 Go to previous messageGo to next message
Hi Marco,
In CVS you should a find a bunch of databinding tests and my wild guess
is that they all derive from such a base class too.
Tom
Am 07.03.11 15:16, schrieb Marco Maccaferri:
> method:
> @Override
> Runnable() {
> @Override
> public void run() {
> Marco.
Re: [databinding] JUnit tests, howto ? [message #659927 is a reply to message #658237] Wed, 16 March 2011 04:24 Go to previous message
budili Missing name is currently offline budili Missing name
Member
Here is a nice description for the Realm setup and Unit-Tests.
Previous Topic:Display Class Dispose method
Next Topic:Missing minimize, maximize buttons in Dialog on Linux
Current Time: Tue May 21 03:49:34 EDT 2013
Powered by FUDForum. Page generated in 0.01723 seconds
