Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] Update site problem(Read timed out)
[Acceleo 3] Update site problem [message #657617] Thu, 03 March 2011 08:43 Go to next message
steff is currently offline steff
When i try to install Acceleo 3, i can see in update manager the latest version : Acceleo 3.0.3.v20110302-0402.
It downloads everything. I have checked in ECLIPSE_HOME/plugins. Some files appear.
Unfortunately, around 49% of comleting the task, the install fails with the following error :
An error occurred while collecting items to be installed
session context was:(profile=epp.package.java, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Unable to read repository at http://download.eclipse.org/modeling/m2t/acceleo/updates/rel eases/3.0/R201103020402/plugins/org.eclipse.acceleo.doc_3.0. 3.v20110302-0402.jar.
Read timed out
Any idea ?
Stephan
[Updated on: Thu, 03 March 2011 09:56]
Report message to a moderator
Re: [Acceleo3] Update site problem [message #657823 is a reply to message #657617] Fri, 04 March 2011 03:52 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
--------------050603010305070005060908
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Stephan,
We've already updated to that version more than once, never observing
this failure. That might have been a temporary down time of the mirror
you were downloading the update on? Does it still fail if you try
re-updating Acceleo now?
If it does, you can download the archived update site for Acceleo and
use that one instead. It can be downloaded on
http://eclipse.org/modeling/m2t/downloads/?project=acceleo (direct link
to the archived update site :
http://www.eclipse.org/modeling/download.php?file=/modeling/ m2t/acceleo/downloads/drops/3.0.3/R201102231004/m2t-acceleo- Update-3.0.3.zip
). Once downloaded, use the following steps :
- From Eclipse, open Help > Install New Software...
- Click the "Add" button
- Click the "Archive" button
- Browse to the downloaded zip
- Select the distribution to upgrade
- Click "Finish" and follow the installation procedure.
Laurent Goubet
Obeo
On 03/03/2011 14:43, stephan.beuze@douane.finances.gouv.fr wrote:
> When i try to install Acceleo 3, i can in update manager the latest
> files appear.
> Quote:
>> action=).
>> Read timed out
>> Artifact org.eclipse.update.feature,org.eclipse.emf.codegen.ecore,2.6
>> .1.v20100914-1218 is a folder but the repository is an archive or
>> remote location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.codegen.ecore.ui,
>> 2.6.0.v20100914-1218 is a folder but the repository is an archive or
>> remote location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.codegen,2.6.0.v20
>> 100914-1218 is a folder but the repository is an archive or remote
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.codegen.ui,2.6.0.
>> v20100914-1218 is a folder but the repository is an archive or remote
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.common,2.6.0.v201
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.common.ui,2.6.0.v
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.converter,2.6.0.v
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.databinding.edit,
>> 1.2.0.v20100914-1218 is a folder but the repository is an archive or
>> remote location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.databinding,1.2.0
>> .v20100914-1218 is a folder but the repository is an archive or remote
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.ecore.edit,2.6.0.
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.ecore.editor,2.6.
>> remote location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.ecore,2.6.1.v2010
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.edit,2.6.0.v20100
>> 914-1218 is a folder but the repository is an archive or remote location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.edit.ui,2.6.0.v20
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf,2.6.1.v20100914-1
>> Artifact org.eclipse.update.feature,org.eclipse.emf.mapping.ecore.edi
>> tor,2.6.0.v20100914-1218 is a folder but the repository is an archive
>> or remote location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.mapping.ecore,2.6
>> remote location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.mapping,2.6.0.v20
>> location.
>> Artifact org.eclipse.update.feature,org.eclipse.emf.mapping.ui,2.6.0.
>> location.
> Any idea ?
> Stephan
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050603010305070005060908--
Re: [Acceleo3] Update site problem [message #657853 is a reply to message #657823] Fri, 04 March 2011 05:50 Go to previous message
Thanks for your prompt reply Laurent Goubet.
I have successfully installed Acceleo by using the zip archive.
Maybe one of the friewall at my work has blocked the jar.
Stephan
Previous Topic:[Acceleo 3] ServiceWrapper Problem during generation
Next Topic:How to invoke a JET transform
Current Time: Tue May 21 05:32:45 EDT 2013
Powered by FUDForum. Page generated in 0.01617 seconds
