Home » Modeling » MoDisco » Integrating support for Javascript
Integrating support for Javascript [message #657834] Fri, 04 March 2011 04:06 Go to next message
Hallvard Traetteberg is currently offline Hallvard Traetteberg
I'm the main developer of Javascript for EMF (JS4EMF) and think it would
be interesting to add support for Javascript queries to Modisco, based
on JS4EMF.
What should I read and do to implement this?
Hallvard
Re: Integrating support for Javascript [message #657927 is a reply to message #657834] Fri, 04 March 2011 11:26 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
Hi Hallvard,
First, thanks a lot for your interest!
I agree it would be a really nice contribution to MoDisco.
To have more information on the MoDisco Query Manager, you can take a look to the available general documentation from http://wiki.eclipse.org/MoDisco/Components/QueryManager/Docu mentation/0.9 to get an overall idea.
For the implementation part, there is already an example of such an integration of a query language: JXPath.
You can take a look to the source code of the corresponding org.eclipse.gmt.modisco.infra.query.jxpath plug-in which is available from the MoDisco SVN.
There, you will have a concrete example of the extension points to use and interfaces to implement.
More information can also be found from the Javadoc of the org.eclipse.gmt.modisco.infra.query and org.eclipse.gmt.modisco.infra.query.core plug-ins.
I hope this help.
And don't hesitate if you need more information.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: Integrating support for Javascript [message #658133 is a reply to message #657927] Sun, 06 March 2011 17:22 Go to previous messageGo to next message
Good!
> I hope this help.
Thanks, that was what I needed. Based on this example I've implemented a
Javascript-based model query factory and adapter. It seems to work well.
Two questions:
- Do you have a test setup, so I can write an automated test instead of
just claiming it works?
- How to contribute the implementation?
Hallvard
Re: Integrating support for Javascript [message #658168 is a reply to message #658133] Mon, 07 March 2011 04:30 Go to previous messageGo to next message
Hi Hallvard,
Great!
Concerning the tests, you can find from the MoDisco SVN "tests" folder some projects providing tests on queries: org.eclipse.gmt.modisco.infra.query.tests for general tests on queries and org.eclipse.gmt.modisco.java.queries.tests for testing queries on a Java model.
Similarly, you could use a Java model to build your test plug-in...
Concerning the contribution of your implementation, here is some general information: http://wiki.eclipse.org/MoDisco/How_to_contribute
Basically, you will need to create a MDT-MoDisco "Contribution" bug and attach your plug-ins to it for initiating the process.
Hugo
Nantes - France
Re: Integrating support for Javascript [message #658378 is a reply to message #658168] Tue, 08 March 2011 04:37 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=339183
Hallvard
Previous Topic:Infix Operation Code Elements Missing from JavaCode Model to KDM Model
Next Topic:Modisco standalone
Current Time: Tue May 21 00:56:00 EDT 2013
Powered by FUDForum. Page generated in 0.01893 seconds
