Home » Eclipse Projects » SWTBot » How to access toolbar buttons of an Eclipse editor?
How to access toolbar buttons of an Eclipse editor? [message #656595] Sun, 27 February 2011 05:10 Go to next message
Ovidio Mallo is currently offline Ovidio Mallo
Member
Hi all,
I'm trying to access a button in the global toolbar which was
contributed for an Eclipse editor using the usual
EditorActionBarContributor#contributeToToolBar() method. I've tried
accessing the button in SWTBot using the following methods but neither
of them is able to find the button:
SWTBotEditor#toolbarButton(String tooltip);
SWTWorkbenchBot#SWTWorkbenchBot(String tooltip);
Is there another way of accessing the buttons in the global toolbar
which belong to an Eclipse editor?
Thanks in advance for any help!
Ovidio
Re: How to access toolbar buttons of an Eclipse editor? [message #656943 is a reply to message #656595] Tue, 01 March 2011 00:57 Go to previous messageGo to next message
Ketan Padegaonkar is currently offline Ketan Padegaonkar
On 2/27/11 2:10 AM, Ovidio Mallo wrote:
> Hi all,
> Ovidio
You need to use #toolbarButtonWithTooltip() as documented here:
http://goo.gl/nLgDm
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot | @ketanpkr
Re: How to access toolbar buttons of an Eclipse editor? [message #657476 is a reply to message #656943] Wed, 02 March 2011 17:15 Go to previous message
Member
Hi Ketan,
thanks for your feedback! I've tried to use
SWTWorkbenchBot#toolbarButtonWithTooltip() as you've suggested but this
seems not to find the button. The same method is working fine for
finding buttons in the normal global toolbar of the workbench but it
seems not to work for the buttons belonging to an editor. Is this method
also supposed to work for the toolbar associated to an Eclipse editor?
Thanks again & kind regards,
Ovidio
>> Hi all,
>> Ovidio
> http://goo.gl/nLgDm
Previous Topic:a question about view menu
Next Topic:How to get hover help in text editor?
Current Time: Sun May 19 00:45:06 EDT 2013
Powered by FUDForum. Page generated in 0.02233 seconds
