| Freescale looking for experienced Eclipse Developer [message #579019] |
Thu, 14 January 2010 15:26  |
Ed Martinez Messages: 2 Registered: January 2010 |
Junior Member |
This position is for a Senior Software engineer working on our Eclipse based CodeWarrior C/C++ IDE development tools. In this position, you will be required to take a lead role in the area of Eclipse UI (SWT/JFace) development on Trace & Profiling support in our tools for our PPC, ARM and StarCore based product lines. This will entail writing lots of new code in Java and C++, consulting with other lead engineers, mentoring of more junior engineers on Eclipse SWT/JFace, the Eclipse UI guidelines and improving the usability of some of our UI. You must be comfortable in an Agile/Scrum development environment and have a good grasp of design patterns. You should be very proficient in Java and C++ (since a lot of our non UI code is in modern C++), and especially these language's more modern features. Strong experience with Eclipse UI development using SWT, a component base framework (like COM, Corba) and XML. Any experience with data driven UI frameworks, like XUL or XWT would by a plus. Any experience working on any Eclipse.org projects would also be a plus.
More details at:
http://www.freescale.com/webapp/sps/site/overview.jsp?nodeId =0678430926
Search (choose your language) for Job ID: 61742
Please do not respond to this post directly.
| Re: Freescale looking for experienced Eclipse Developer [message #656749 is a reply to message #579019] |
Mon, 28 February 2011 07:47  |
Wassim Messages: 1 Registered: February 2011 |
Junior Member |
| Ed Martinez wrote on Thu, 14 January 2010 15:26 | This position is for a Senior Software engineer working on our Eclipse based CodeWarrior C/C++ IDE development tools. In this position, you will be required to take a lead role in the area of Eclipse UI (SWT/JFace) development on Trace & Profiling support in our tools for our PPC, ARM and StarCore based product lines. This will entail writing lots of new code in Java and C++, consulting with other lead engineers, mentoring of more junior engineers on Eclipse SWT/JFace, the Eclipse UI guidelines and improving the usability of some of our UI. You must be comfortable in an Agile/Scrum development environment and have a good grasp of design patterns. You should be very proficient in Java and C++ (since a lot of our non UI code is in modern C++), and especially these language's more modern features. Strong experience with Eclipse UI development using SWT, a component base framework (like COM, Corba) and XML. Any experience with data driven UI frameworks, like XUL or XWT would by a plus. Any experience working on any Eclipse.org projects would also be a plus.
More details at:
FUDForum. Page generated in 0.06676 seconds
