Home » Eclipse Projects » Virgo » JMX and Spring bean
JMX and Spring bean [message #654796] Thu, 17 February 2011 03:20 Go to next message
Dan Tran is currently offline Dan Tran
For the classic Spring bean app, i can just annotate my spring bean classes and methods to add JMX functionanality ( so that I can invoke from jconsole ). However, when deploy my spring bean as a bundle to Virgo I dont see my JMX bean shows up in Jconsole.
Would it possible to do that with Virgo?
Big thanks aheahd
-Dan
Re: JMX and Spring bean [message #654805 is a reply to message #654796] Thu, 17 February 2011 04:10 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn Normington
That should certainly be possible because that's how Virgo publishes some of its own Mxbeans. Take a look at the Deployer interface.
The deployer runs in the kernel rather than the user region, but the user region runs its own instance of Spring framework, so I don't think that's the issue.
Re: JMX and Spring bean [message #655018 is a reply to message #654805] Thu, 17 February 2011 20:11 Go to previous messageGo to next message
I found org.eclipse.virgo.apps.repository has and implementation of MBean. However, the source manually register the bean.
I was hoping i could find some thing like
@ManagedResource(objectName = "com.mycomp.mc:name=helloWorld", description = "Hello World Via Spring DM.")
public class ExampleService
implements Service {
* Reads next record from input
@ManagedOperation(description = "Hello World!")
public String getMessage() {
return "Hello world!";
Btw, I also export ExampleService as bundle service bean and it does not help either
Big thanks ahead for advices
-D
[Updated on: Thu, 17 February 2011 20:35]
Report message to a moderator
Re: JMX and Spring bean [message #655109 is a reply to message #655018] Fri, 18 February 2011 06:06 Go to previous messageGo to next message
I don't think we use that approach in Virgo itself.
Please note we have a new source code search facility available for Virgo: http://virgo-opengrok.springsource.org/.
For instance, to find where we publish the Deployer mxbean, enter "Deployer jmx" in the Full Search box and "xml virgo" in the File Path box.
Re: JMX and Spring bean [message #656659 is a reply to message #655109] Sun, 27 February 2011 20:25 Go to previous messageGo to next message
I ended up to register my Spring beans with MBeanExporter
The below link shows how to to do it
http://tech-tauk.blogspot.com/2009/11/jmx-using-spring.html
-Dan
[Updated on: Sun, 27 February 2011 20:26]
Re: JMX and Spring bean [message #656699 is a reply to message #656659] Mon, 28 February 2011 03:08 Go to previous message
Glad you found a way through.
Previous Topic:Problems using Virgo Test Framework
Next Topic:Milestone 3.0.0.M02 is available
Current Time: Tue May 21 17:13:12 EDT 2013
Powered by FUDForum. Page generated in 0.01714 seconds
