Home » Modeling » Modeling (top-level project) » Referencing Ecore to Support ORM
| Referencing Ecore to Support ORM [message #656623] |
Sun, 27 February 2011 11:23  |
Glenview Jeff Messages: 79 Registered: September 2010 |
Member |
I am trying to add support to my existing meta-model for modeling an Object Relational Mapper (ORM.) I came across this very old post in the newsgroups, and first was wondering (Ed Merks) if the tutorial was ever written?
Specifically, what I'd like my meta-model to ultimately support is the creation of models that look something like this:
PersistentClass:
myName : "TestClass"
myTableName: "TestClass"
myOrmAttributes:
OrmBoolean: (Ideally extending the Ecore EBoolean, but I have read this is a bad idea.)
myName: "TestOrmBoolean"
myStoredType: "boolean"
EBoolean: (Ideally referencing the Ecore type)
and the meta-model would look something like this:
PersistentClass:
myName : EString
myTableName: EString
myOrmAttributes: [0..*] OrmAttribute
myEcoreAttributes: [0..*] EAttribute (I have to separate this from myOrmAttributes because I shouldn't extend Ecore, right?)
OrmAttribute:
myStoredType: EString
OrmBooleanAttribute: Extends OrmAttribute
myAttribute: EBoolean
OrmStringAttribute: Extends OrmAttribute
myAttribute: EString
This looks quite ugly because of being discouraged from extending ecore. Is there a better way to accomplish what I'm trying to do?
Thanks!
Jeff
[Updated on: Sun, 27 February 2011 13:05] Report message to a moderator
| Re: Referencing Ecore to Support ORM [message #656632 is a reply to message #656623] |
Sun, 27 February 2011 13:09   |
Ed Merks Messages: 24570 Registered: July 2009 |
--------------030408030102000101070007
Content-Type: text/plain; charset=UTF-8; format=flowed
Jeff,
Comments below.
> http://www.eclipse.org/forums/index.php?t=rview&goto=376 261&th=123211
> was ever written?
Tutorial: Generating an Extended EMF Model
< http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/slibmod/slibmod.html>
> PersistentClass:
> myOrmAttributes:
I'm not sure what it means to extend EBoolean. You mean extended
EDataType. java.lang.Boolean itself isn't extensible...
> PersistentClass:
> myName : EString
I'm not sure what it means to mix meta level things like EAttribute with
instance level things list EString...
> OrmAttribute:
> This looks quite ugly because of not discouraged from extending ecore.
Indeed. Annotating Ecore should suffice.
It's not entirely clearly what you're trying to do. Teneo and CDO both
to ORM mapping already...
> Thanks!
> Jeff
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Jeff,<br>
<br>
Comments below.<br>
<br>
<br>
glenviewjeff wrote:
<blockquote cite="mid:ikdtd6$for$1@news.eclipse.org" type="cite">I am
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/forums/index.php?t=rview&goto=376 261&th=123211">http://www.eclipse.org/forums/index.php?t=rview&goto=376261&th=123211</a>
was ever written?
<br>
</blockquote>
<a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/slibmod/slibmod.html">Tutorial:
Generating an Extended EMF Model</a>
<blockquote cite="mid:ikdtd6$for$1@news.eclipse.org" type="cite"><br>
<br>
<br>
PersistentClass:
<br>
<br>
<br>
myOrmAttributes:
<br>
<br>
</blockquote>
EDataType. java.lang.Boolean itself isn't extensible...<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
PersistentClass:
<br>
myName : EString
<br>
<br>
<br>
<br>
</blockquote>
with instance level things list EString...<br>
OrmAttribute:
<br>
<br>
<br>
<br>
myAttribute: EBoolean <br>
<br>
myAttribute: EString <br>
<br>
<br>
This looks quite ugly because of not discouraged from extending ecore. <br>
</blockquote>
Indeed. Annotating Ecore should suffice.<br>
<blockquote cite="mid:ikdtd6$for$1@news.eclipse.org" type="cite"> Is
<br>
</blockquote>
to ORM mapping already...<br>
Thanks!
<br>
Jeff
<br>
</blockquote>
</body>
</html>
--------------030408030102000101070007--
| Re: Referencing Ecore to Support ORM [message #656647 is a reply to message #656632] |
Sun, 27 February 2011 16:24   |
Member |
Ed:
Thanks very much for the super quick answer on a Sunday no less!
Please forgive the sloppiness of my rough sketch; I'm an EMF newbie and even an Eclipse framework novice as you can probably tell.
To give you some background, this all started with my listening to the model-driven software development podcasts on se-radio.net. I've been playing mostly with Acceleo to do M2T for Android Java development, with the ultimate goal of making generators for other platforms (web, desktop.) I've also spent a few days looking into Xpand as well as JetBrains MPS (outside Eclipse.)
During this process, I've had success in reverse-engineering/refactoring/modeling and generating of a fairly large Android application using EMF+Acceleo.
Recently, I began using an ORM that supports Android and other platforms called ORMlite (www.ormlite.com.) Hibernate doesn't support Android as far as I know. At your suggestion I just took a quick look at CDO and Teneo and at least initially, doesn't seem obvious that these have meta-models I could re-use.
Please recognize that I am not trying to use EMF's code generation to generate Android target code, as I believe this is impossible/infeasible. I'm only using the EMF generation to create the default model editor so I can create a model instance.
Ultimately, I want to to define a class in my model, define its attributes, mark some attributes as persistent, annotate some attributes to override the default persistent data types, etc. The generated Android code would look something like this:
@DatabaseTable(tableName = "accounts")
public class Account {
@DatabaseField(id = true)
private String name;
@DatabaseField
private String password;
@DatabaseField(DataType = DataType.DATE_STRING)
private Date date;
private Date nonPersistedDate;
I will create generators with Acceleo that annotate the generated class with the appropriate ORMlite annotations as above automatically.
I read a little about annotating the Ecore model in the EMF book at your suggestion, but it's not exactly clear to me how this would work.
If I were extending Ecore's EClass, I would do something like this (forgive the pseudocode.)
PersistentClass extends EClass {
EString TableName
which would enforce that a TableName is defined for the PersistentClass. Am I right in assuming that if I were to use annotations, one could create an inconsistent class where maybe the user uses an Eclass instead and then annotates some of the fields to be persistent?
I know this sort of thing could be addressed using something like the Check language, but I'd rather rely on the built in enforcement I'd get via inheritence.
I really appreciate all of your help and guidance.
Jeff
| Re: Referencing Ecore to Support ORM [message #656651 is a reply to message #656647] |
Sun, 27 February 2011 16:53  |
Jeff,
Comments below.
glenviewjeff wrote:
> Ed:
No rest for the wicked..
:-P
Outside of Eclipse! Perish the thought!!
That's cool.
I'm not so sure about that:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=296770
Not unlike Ecore...
> @DatabaseField
> private Date date; private Date nonPersistedDate;
Look at, for example, a model created from an XML Schema (like the
library tutorial example).
> EString TableName
Yep, that's exactly the kind of think you could do with an EAnnotation;
look at how ExtendedMetaData doesn't this for XML Schema-based Ecore
annotations.
> be persistent?
Of course, but one could create an inconsistent class with a tableName
that's empty, or uses bad characters. In either case, you'd need to
check for well formedness.
Other types of things like duplicate table names would also need
checking... In the end, you do end up writing code of some sort in some
language...
I suspect you could accomplish what you wanted with annotated Ecore,
though likely with a different generator...
> Jeff
Current Time: Tue May 28 15:58:51 EDT 2013
Powered by FUDForum. Page generated in 0.08298 seconds
