with every Jenkins build producing a p2 site this repository becomes bigger
as old entries (with another timestamps in filenames) are built again, too.
On 2011-02-27 15:41, Axel Guckelsberger wrote:
> Hi all,
> Is it possible to remove old bundles somehow?
The easiest way is probably to recreate the repository from scratch. An alternative can be to use the b3 aggregator to
create a clean repository. It will typically only select the latest revision from its input.
