| xPand and TaggedValues [message #655940] |
Wed, 23 February 2011 07:57  |
Sir Wayne Messages: 172 Registered: July 2009 |
Hi together,
how can i read the tagged values in my templates.
My Uml looks like:
<MYDSL:BaseEntity xmi:id="_S-3Lnj9KEeCVJNzgZt5D1g" base_Class="{D4FC60F1-9EC4-4fca-8A5F-67DD4D6A3360}"/>
<MYDSL:BaseEntity xmi:id="_S-3Lnz9KEeCVJNzgZt5D1g" persistence=""persistent"" base_Class="{334D0B1E-F34D-4e13-B89D-4EE8C0A5C658}"/>
i have 1 entity with no tagged values and 1 entity with a tagged value persistence.
Now i tried to print the Attribute, but nothing happened.
«FOREACH this.getAllAttributes().typeSelect(MYDSL::BaseEntity) AS attr»
//«attr.name»
//«attr.persistence»
«ENDFOREACH»
[Updated on: Wed, 23 February 2011 07:58] Report message to a moderator
| Re: xPand and TaggedValues [message #656349 is a reply to message #656331] |
Fri, 25 February 2011 03:56   |
Christian Dietrich Messages: 4419 Registered: July 2009 |
as i posted before
org.eclipse.uml2.uml.Element.getAppliedStereotype(String)
org.eclipse.uml2.uml.Element.getValue(Stereotype, String)
similar ops shall be available from expand too.
alternativelay you should get direct access to
«DEFINE main FOR test::Bean»
«FILE getFQPN().replaceAll("\\.","/")+"/"+name+".java"»
//«this.tablename»
~Christian
[Updated on: Fri, 25 February 2011 05:01] Report message to a moderator
FUDForum. Page generated in 0.01570 seconds
