Home » Language IDEs » AJDT » AJDT 1.2.1 any new releases planned to fix memory usage
| AJDT 1.2.1 any new releases planned to fix memory usage [message #63239] |
Thu, 30 March 2006 14:54  |
Originally posted by: schuchert.yahoo.com
I noticed that there are fixes to the development build of AJDT 1.3 that
reduces the memory used by 50%. I could really use this but there is not a
development build for 1.2.1, which leads me to believe that 1.2.1 is
officially dead.
I'm stuck using RAD, which is tied to Eclipse 3.0. Are there any plans to
release another version of ADJT for Eclipse 3.0, or should I plan to stick
to using ant tasks to build.
When I use AJDT, eclipse will use all of 1.2 GB before, which causes
problems on my measly 2 GB system. I have given RAD more memory, but then
I start swapping when I am also running a server, which makes the
performance so bad it is not usable.
Thanks!
Brett
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #63262 is a reply to message #63239] |
Thu, 30 March 2006 18:13   |
Matt Chapman Messages: 429 Registered: July 2009 |
Hi Brett,
It's not dead, just resting! We have the capability to produce a 1.2.2
build - no-one has asked for one until now. Putting the upcoming release
of AspectJ 1.5.1 into AJDT 1.2 will take some work, but I think it should
be possible. It's not possible to backport many of the AJDT changes
because they are dependent on the eclipse version, but most of the memory
improvements are in the compiler. We will try this after AJDT 1.3.1 is
done (which should be next week).
Matt.
> officially dead.
> Thanks!
> Brett
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #63353 is a reply to message #63262] |
Fri, 31 March 2006 12:45   |
Matt,
First, thanks for your extremely quick reply. I appreciate it.
We've been using AspectJ since 11/04. In our initial uses we only needed
to weave one project (manually) to get our stuff to work (required for
both test and production). The build process weaves other aspects that
were really only required for produciton.
We've recently added a few more aspects for test support. One requires
weaving in 4 projects (minimum, 7 typically) for it to work. We organize
our applications by projects and layers within a project. Each project
has, typically, 8 projects (EAR, WAR, EJB, Business, Integraion, Domain,
Utility, Test). We also have a core application (reference architecture)
upon which other projects depend. A typical workspace as aroune 20
projects and I'd guess 500K - 1M SLOC.
This one aspect mocks out all of our DAO's by recording input and
responses and then plays them back on subsequent test executions. It
speads up our tests by roughtly 60 - 80%, which makes our developers more
likely to use them.
We have around 40 developers and AJDT would make their life much easier.
I'd go so far as to say that without it, this new mocking of DAO's would
effectivley be useless.
However, we only have 2 gigs of memory and without the memory improvements
we are right on the edge of usable. So any improvement there would be a
major boon.
We are less concerned with AspectJ 1.5.1, but given the opportunity to
move to it, we would. Since we are using RAD and WebSphere 6.0.2, we are
suck using JDK 1.4.2. I'm under the impression that most of the
differences from 1.2 to 1.5 are related to support for annotations and
generices, which we are ready to use as soon as we can. I'd love to see
IBM update WebSphere and RAD so we could use JDK 1.5. I suppose I should
be luck, we started with JDK 1.2 (10/02), skipped 1.3 and move to 1.4.2
around 8 months ago...
Again, thank you. I have no experience building eclipse plugings, but I do
have a lot of experienc with WSAD and a good deal with RAD (which is very
bugy). If you can use my help in any way, I'm happy to offer it.
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #63376 is a reply to message #63262] |
Fri, 31 March 2006 12:46   |
Matt,
were really only required for production.
has, typically, 8 projects (EAR, WAR, EJB, Business, Integration, Domain,
upon which other projects depend. A typical workspace as around 20
speeds up our tests by roughly 60 - 80%, which makes our developers more
likely to use them.
effectively be useless.
major boon.
generics, which we are ready to use as soon as we can. I'd love to see IBM
update WebSphere and RAD so we could use JDK 1.5. I suppose I should be
Again, thank you. I have no experience building eclipse plugins, but I do
have a lot of experience with WSAD and a good deal with RAD (which is very
buggy). If you can use my help in any way, I'm happy to offer it.
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #63582 is a reply to message #63376] |
Mon, 03 April 2006 11:38   |
Brett,
Thanks for the information, it's very interesting to hear about your
AspectJ usage.
I thought from your first post that you are using AJDT 1.2.1 (the release
versions, from December 20, 2005). Is that correct? If so, that contains
AspectJ 5, so you are already using it. It runs just fine on JDK 1.4.2 -
Java 5 is only required for those specific features.
The AspectJ 1.5.1 release will contain the memory improvements, so we can
then try to produce an AJDT 1.2.2 release containing that.
Matt.
> Matt,
> likely to use them.
> major boon.
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #63671 is a reply to message #63582] |
Mon, 03 April 2006 14:26   |
Matt Chapman wrote:
> Brett,
That is correct, we are using AJDT 1.2.1.
OK, then I was confused. I didn't realize that the memory performance was
in ApsectJ. For some reason I was thinking it was related to AJDT, not
AspectJ.
That being the case, we ARE interested in AspectJ 1.5.1.
Brett
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #592751 is a reply to message #63239] |
Hi Brett,
Matt.
> officially dead.
> Thanks!
> Brett
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #592803 is a reply to message #63262] |
Matt,
likely to use them.
major boon.
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #592817 is a reply to message #63262] |
Matt,
likely to use them.
major boon.
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #592943 is a reply to message #63376] |
Brett,
AspectJ usage.
Matt.
> Matt,
> likely to use them.
> major boon.
| Re: AJDT 1.2.1 any new releases planned to fix memory usage [message #592992 is a reply to message #63582] |
Matt Chapman wrote:
> Brett,
AspectJ.
Brett
Current Time: Thu May 23 08:10:15 EDT 2013
Powered by FUDForum. Page generated in 0.06640 seconds
