Home » Eclipse Projects » XML Schema Definition (XSD) » Auto Completion Classes for XSD
Auto Completion Classes for XSD [message #655371] Sat, 19 February 2011 22:48 Go to next message
zifiribir is currently offline zifiribir
I want to create an xml editor that has xml schema code completion property. However, it will be independent from Eclipse. How can I detach the classes for code completion? Or are there any external classes for this?
Can you help me?
I found this packages/classes:
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l(ModelQueryExtensionManager)
org.eclipse.wst.xsd.ui.internal.text (XSDModelQueryExtension)
org.eclipse.wst.xsd.ui.internal.util.(TypesHelper)
[Updated on: Sat, 19 February 2011 22:52]
Report message to a moderator
Re: Auto Completion Classes for XSD [message #655631 is a reply to message #655371] Mon, 21 February 2011 22:21 Go to previous message
Ed Merks is currently offline Ed Merks
Please ask about wst on the WTP newsgroup/forum.
zifiribir@gmail.com wrote:
> Hello,
> I want to create an xml editor that have xml schema code completion
> dispatch the classes for code completion? Or are there any external
> classes for this?
> Can you help me?
Previous Topic:NPE when running XSD Sample XSDGenerateHTML
Next Topic:XSD Graphic editor
Current Time: Tue May 21 08:20:13 EDT 2013
Powered by FUDForum. Page generated in 0.02340 seconds
